Author Topic: 2 month old oem clutch cable getting sticky  (Read 2343 times)
Offline kajtek
« on: September 30, 2012, 08:36:26 AM »
so ive got a fairly new oem clutch cable on my bike, 2 months or so, and i didnt lube it as per advice i saw on this forum.
its now getting 'catchy' as a pull it in and release. not stiff but as i release i cant do it smoothly. now admittedly ive done about 3000km in this time but i didnt think an oem cable would cause a fuss so soon?
im running clip ons but the are above the top triple (forks lowered), and the cable doesnt to me seem to be binding anywhere?
should i lube it? between this and my snatchy clutch this bikes gonna end up in a river soon unless i can sort it out..
thank
ashley
1978 honda cb400f supersport
Offline LesterPiglet
  • 1977 CB550F2
Re: 2 month old oem clutch cable getting sticky
« Reply #1 on: September 30, 2012, 08:38:19 AM »
Try removing the cable and check the action, just to make sure it isn't a routing problem.
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #2 on: September 30, 2012, 11:51:55 AM »
Provided it isn't bound up somewhere, you pretty much answered your own question.  Of course you should lube it.  You knew you should have before you installed it.
« Reply #3 on: September 30, 2012, 01:56:01 PM »
OEM means from Honda?  Was it teflon lined?
Was it installed with sharp bends?
Becasue some lubes will soften the liner, I us "Dry Slide" for a lube on those that need it.  Goes on wet and flows where needed, dries out and leaves lube where needed to improve sliding action.
But, if you have small bend radius in your installation, you'll wear out cables rapidly.
Offline kajtek
« Reply #4 on: October 01, 2012, 12:07:48 AM »
Hi yeah sorry oem means honda. Had a look last night and its hard to tell if the bend radius is too tight. Not sure what it should be! But not bad points as far as i can see. I clean and oiled (dont have grease with me) the lever pivot, made no difference. Will have to find that dry lube somewhere, im in france and my french isnt great which makes it harder..
The lever isnt stiff it just has a kindof dry sqeak feel to it when i pull ir realease it. One thing i can say is that it started after i had to ride in torrential rain.
Ashley
« Reply #5 on: October 01, 2012, 12:42:03 AM »
Do they have Gun shops in France?
The straighter the cable, the less resistance the inner cable has from rubbing on the casing.
In stock form and proper routing, the cable doesn't get a smaller bend radius than about 12".
bollingball
« Reply #6 on: October 01, 2012, 04:14:19 AM »
 ;D ;D ;D ;D ;D Do they have guns
Offline Deltarider
« Reply #7 on: October 01, 2012, 04:39:15 AM »
Do they have guns
In principle only the people that are entitled to. Violence is regarded as the monopoly of the state as in all civilized countries. Less toys, less prisons. ;D ;D ;D
Honda OEM cables don't like lubes. With Teflon inside there's no use for lube anyway.
CB500K2-ED Excel black
bollingball
« Reply #8 on: October 01, 2012, 05:11:58 AM »
Do they have guns
Why do you think Guns = Violence?
Offline Deltarider
« Reply #9 on: October 01, 2012, 06:57:47 AM »
OK, forget the violence. I think free possession of arms and the largest numbers of prisons and inmates in the world by far. Ofcourse the NRA is willing to finance all that or...
Besides all that: I will never be able to travel the USA the way I did in '73, much to my regret.
Offline Deltarider
« Reply #10 on: October 01, 2012, 07:22:04 AM »
Nah... I was only kidding you there, Bollingball. Ofcourse guns are fun and we overhere deerly miss scenes in gunshops as in:
 http://forums.sohc4.net/index.php?topic=105860.msg1184240#msg1184240
« Last Edit: October 01, 2012, 07:25:27 AM by Deltarider »
Offline kajtek
« Reply #11 on: October 01, 2012, 11:50:22 AM »
ok..
so ive definately seen a sporting gun shop in town.. just gotta remember where.
im gonna go down and check all the bits at the engine end, make sure it hasnt dried up or isnt binding etc. that way i know its definately the cable.
ashley
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #12 on: October 01, 2012, 12:02:34 PM »
Bicycle shops also sell the Dri Slide for cables, you can look there too.
bollingball
« Reply #13 on: October 01, 2012, 03:01:20 PM »
Hey you are welcome to my place any time. I have a range out to 300m. So you can relive what ever you did (with in reason) in 73. I will supply the ammo. It will be fun. No violence except to your shoulder with the 30-30 ;D
Ken
