Alright, made some more progress this week. Swing arm back on with bronze bushings, rear fender mounted, repaired all the damaged termanal connections, and terminated all the connectors.
Seats back on and I cleaned up the tail light wiring.
Oil tank mounted and vent lines ran. Just need to get that dang clutch removal tool to get the clutch in and the oil lines ran.
Put the original side cover on it, man I wish I could find a OEM Planet Blue cover for the fuse box. Most likely going to get some new side covers painted and just have the stock one on the wall some where.
And we are now dealing with the rats nest. Got to go through the wiring diagram to make sure the connections are right. I am going to wait since I need to order blinkers and I need to put new gauge faces in the spedo and tach to finish out the wiring.
I'm seeing the light at the end of the tunnel. Just need to get some more cash saved up so I can get the last few parts.
