Author Topic: CB750 K3F - AKA The Red  (Read 177276 times)
Re: CB750 K3F
« Reply #75 on: September 05, 2013, 07:51:13 PM »
Looks good. How'd you strip, wire wheel?
Re: CB750 K3F
« Reply #76 on: September 06, 2013, 02:48:25 AM »
Yes.  The cup wheel works the best.  I was not planning on stripping the whole frame but now it looks like I will have to - it would bother me not to  :)
« Last Edit: September 06, 2013, 02:50:06 AM by 70CB750 »
Re: CB750 K3F
« Reply #77 on: September 13, 2013, 04:52:24 PM »
What are you doing to the head and is it ready to go on?
Re: CB750 K3F
« Reply #78 on: September 13, 2013, 05:15:03 PM »
The head is what keeps me from moving forward.  It needs new guides, valves, springs and retainers.
Most likely I will need to cut valve seats too to make them seal - means to get Neway cutters.
Re: CB750 K3F
« Reply #79 on: September 24, 2013, 01:42:35 PM »
Looks like phenolic bushings in the swingarm, I will use old style bolt with zerks.  To help the grease flow I drilled holes in the sleeve and also cut spiral groves to distribute the lubricant where it is needed the most.
Re: CB750 K3F
« Reply #80 on: October 03, 2013, 05:04:30 AM »
Finally past the point of return, new valve guides.
Prehoned too.
Re: CB750 K3F
« Reply #81 on: October 03, 2013, 05:05:15 AM »
I spent so much time striping the frame...
« Last Edit: October 03, 2013, 05:07:23 AM by 70CB750 »
Re: CB750 K3F
« Reply #82 on: October 03, 2013, 05:06:03 AM »
... just to paint over it again.
Re: CB750 K3F
« Reply #83 on: October 03, 2013, 01:50:08 PM »
Swingarm bushings from Germany.  Febay seller kenosha_kid.  Purchased on 9/18, got it today, not bad.
The first idea how to press them in,  looks like it's working.
« Last Edit: October 03, 2013, 01:54:45 PM by 70CB750 »
Re: CB750 K3F
« Reply #84 on: October 03, 2013, 01:50:51 PM »
I like it, $30 invested.
« Last Edit: October 03, 2013, 01:55:30 PM by 70CB750 »
Offline spazz1984
Re: CB750 K3F
« Reply #85 on: October 03, 2013, 03:05:01 PM »
I've used threaded rod with waser to do that
Sent from my SPH-L710 using Tapatalk 2
Offline Roach Carver
Re: CB750 K3F
« Reply #86 on: October 04, 2013, 06:13:40 AM »
Looking good!
Re: CB750 K3F
« Reply #87 on: October 04, 2013, 06:41:13 AM »
Good idea on the pipe clamp, I have one, but wouldn't have thought to use it for that
Re: CB750 K3F
« Reply #88 on: October 04, 2013, 06:45:17 AM »
Thank you.
For the peace of mind I had the sleeve holding bushings lined up while pressing, but I don't think it was necessary.
Now the next challenge, valve guides installing  ;D
Re: CB750 K3F
« Reply #89 on: October 07, 2013, 04:12:38 AM »
I made an adapter to install guides without the heat and hammering.
Re: CB750 K3F
« Reply #90 on: October 07, 2013, 04:15:05 AM »
It worked.
Offline edwardmorris
  • Youngish
Re: CB750 K3F
« Reply #91 on: October 08, 2013, 10:31:10 AM »
What primer and paint are you using for the frame?
Re: CB750 K3F
« Reply #92 on: October 08, 2013, 10:36:16 AM »
Re: CB750 K3F
« Reply #93 on: October 09, 2013, 12:42:57 PM »
  • Youngish
Re: CB750 K3F
« Reply #94 on: October 09, 2013, 01:07:15 PM »
Very nice! Stealthy.
Re: CB750 K3F
« Reply #95 on: October 09, 2013, 01:32:44 PM »
Thank you.
Offline Cragdog
Re: CB750 K3F
« Reply #96 on: October 09, 2013, 04:11:50 PM »
Looking good! What's next???
If you like it, then you should ride it.
1970 cb750 K0
1983 VT750c
1974 Suzuki GT550
Re: CB750 K3F
« Reply #97 on: October 09, 2013, 04:34:50 PM »
Next?  Valves, after that likely Neway cutters, springs and retainers.
But now it looks like I have to invest in the jeep's windshield frame and glass and also blower motor for the house HVAC :(
It's gonna take a while.
Offline Cragdog
Re: CB750 K3F
« Reply #98 on: October 09, 2013, 04:41:47 PM »
My jeep needs a new windshield as well! Small crack though, but it's been there a couple years now haha.
1970 cb750 K0
1983 VT750c
1974 Suzuki GT550
Re: CB750 K3F
« Reply #99 on: October 23, 2013, 03:10:39 AM »
I would not pass inspection with the windshield, due this month.
