Author Topic: Alternator Up Grade 32amps  (Read 107987 times)
Offline grasscutter
  • Love the CB650.
Re: Altenator Up Grade 32amps
« Reply #50 on: February 10, 2013, 07:43:30 AM »
I drag raced air cooled VW's for many years.  Lightened flywheels had a significant difference on a street driven race car.  VW crankshafts are much heavier than a Honda crank.   Surprised to hear it makes no difference on bike, but did in a car.
Not sure if VW cranks are counterweighted.  I'm pretty sure the CB's cranks have huge counterweights.
The stock VW cranks were Not fully counter-weighted. They were statically balanced, but with out counter-weights would flex above 5K RPM, wiping out the main bearings, and/or the case and crank. From memory the 750 crank was as heavy, if not heavier than a stock VW crank. The VW flywheel, on the other hand, was MUCH heavier than a 750 rotor, with much of the mass located in a diameter 2-3 times larger.
Agreed.  There are differences.  Merely stating a fact that it had a significant effect on our street driven race cars, and our flywheels were NOT lightened by half, as this new CB rotor is.  (and with so many people running pods, they already have an idle issue.)  Sorry if the comment seemed to throw water on the excitement of a 32amp rotor.  Not my intent!
Come on!  We're burning daylight!
Offline Elan
    • Vital Motor Parts
« Reply #51 on: February 10, 2013, 08:30:35 AM »
subscribed
76 750k
Offline bert96
  • past ride
« Reply #52 on: February 10, 2013, 10:49:23 AM »
For those who don't have EFI or heated grips,20amp is it enough to keep the electric start?
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
« Reply #53 on: February 10, 2013, 12:18:04 PM »
Have we discussed what affect the extra extra amps will do to our existing gauge of wiring on the rest of the bike?
I'm not versed on this like anders or TT but my take is that say for example a turn signal will only DRAW so much juice so it's wiring SHOULD be ok unless a short were to occur? But, what about the wiring from/to the alternator, rectifier, regulator, etc? Is the WHOLE system an on-demand thing only and will not fry existing wiring UNLESS there is a full 32amp demand? At what point in the system would the demand be distributed from? IE where would those 32amps go to as a single power source before being distributed throughout the bike to each demand? And would that part of the wiring also need to be upgraded? Sounds to me that this could require a possible solution.
Offline anders288
« Reply #54 on: February 10, 2013, 01:13:19 PM »
        Hi Jerry,
 The three wires from the stator connect to the gray plug on the reg. the black plug connects to the battery there are no other wire. If you kick over the motor with the key off it will produce voltage. I hope this helps.
« Reply #55 on: February 10, 2013, 01:16:17 PM »
Now that I don't have to fiddle with the cover I am interested. I was looking into just having a stock unit rewound, this looks better.
« Reply #56 on: February 10, 2013, 01:18:54 PM »
        Hi Jerry,
I think Jerry really wants to know if the stock wiring harness is up to the upgraded charging system....
Offline anders288
« Reply #57 on: February 10, 2013, 01:31:50 PM »
Bert
  The stock system puts out around 17 amps and discharges at idle. The upgrade system produces voltage if the motor is turning key on or off.
          I'm expecting around 14 volts at idle witch means higher voltage to the coils. Bike will run with a dead battery. Yes it sound be able to kick
          start using a battery eliminator / capacitor will need to eb tested.
Offline anders288
« Reply #58 on: February 10, 2013, 01:38:58 PM »
        Hi Jerry,
               It doesn't in any way connect to the bikes wiring it connects to the BATTERY ONLY it will in no way do anything to bikes wiring.
« Reply #59 on: February 10, 2013, 02:07:37 PM »
 Everybody should be running a separate relay with upgraded gauge to the coils anyway.  ;) ;D This system will work very well IMO. Truthfully ....a "slimmer" cover is just about achieving a look right?  Cutting it down saves about 30 grams of weight (maybe). I mean....have any of you fellas dragged the alt cover lately. ;D ;D
« Reply #60 on: February 10, 2013, 02:28:05 PM »
No, but why risk it... :P j/k....   I was just wanting a more balanced look to the engine.... ;)
Offline larecords
  • love,love, love this
« Reply #61 on: February 10, 2013, 03:04:14 PM »
Sounds very inarestin' Anders be great to extend a more comfortable riding season up here in Canada. Now just have to work on studs for tires!!!!
1977 550K Honda in storage
1978 550K Honda
1978 750K Honda a work in progress
1975 750F Super Sport Honda present ride
« Reply #62 on: February 10, 2013, 03:50:57 PM »
SNIP
Don't crush our dreams!   ;)
Offline anders288
« Reply #63 on: February 10, 2013, 04:14:37 PM »
   I have been looking at that alternator cover since 1969 it would be like my girl friend having a breast vasectomy :'(
« Reply #64 on: February 10, 2013, 04:24:32 PM »
 Well as you know there are a lot of buggered covers around that were 750 dynocovers..  And they get buggered every time. It gets laid down on that side..We like modding our bikes and looking different.. A no lose situation.
 And it can be batteryless.. Even better..
« Reply #65 on: February 10, 2013, 04:34:46 PM »
Well then I guess we need to see a picture of Anders girlfriend!?  ;D ;)
Retro had my back on that. I was wondering where all that additional power would initially go and how would it get there ie larger wiring and to where. Heavier gauge wires to the battery so the extra juice doesn't melt them then the individual demand of the existing circuits being handling by it's existing wires. More demand therefore not handled by existing wiring but rather with new circuits thus protecting our precious unavailable wiring harness. Therefore a non-issue.
Cool, I got it  :)
ccmclane
« Reply #66 on: February 10, 2013, 04:48:42 PM »
Consider me interested in the alternator upgrade.
« Last Edit: February 10, 2013, 05:18:50 PM by ccmclane »
Offline anders288
« Reply #67 on: February 10, 2013, 04:57:36 PM »
I would show you a photo but she only exists in my mind.
« Reply #68 on: February 10, 2013, 05:14:43 PM »
She has tubes in her breast... :o
Mastectomy     ;) ;D
Offline anders288
« Reply #69 on: February 10, 2013, 05:34:29 PM »
Mastectomy     ;) ;D
     I know it was something ectomy.
« Reply #70 on: February 10, 2013, 08:02:24 PM »
Mastectomy     ;) ;D
Yes, i know some people that need a "something ectomy".... ;D
« Reply #71 on: February 11, 2013, 12:49:29 AM »
alternectomy?=the act of changing an alternators gender from electro magnetic field to permanent whilst upping the output.
Offline MJL
  • Don't listen to me, I'm no
« Reply #72 on: February 11, 2013, 06:26:32 AM »
I'm interested in going batteryless. My issue is this is a chopper type bike with not a lot of room to hide electricals.
« Reply #73 on: February 11, 2013, 08:34:02 AM »
The Alternectomics thread... All about alternectomies..
Offline mjstone
  • I'm definitly not a
« Reply #74 on: February 11, 2013, 09:54:27 AM »
I guess I've been away from the forum too long.  I've got to keep an eye on this thread.  I give a vote on a 500/550 kit.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
