Author Topic: Hondssa Short tracker...CB 350  (Read 6660 times)
« on: February 11, 2013, 10:49:58 PM »
 I have been yearning for a proper tracker for a lot of years. I did the 750 in a rigid frame last year, but its heavy and has too much rake.
 I picked up an Ossa rolling  frame in Dec, that looked promising. Has Betor forks, and good rake angle.. So i figured why not..
« Last Edit: February 11, 2013, 10:51:37 PM by 754 »
Re: Hondssa Short tracker...CB 350
« Reply #1 on: February 11, 2013, 10:55:32 PM »
 Then i found a 350 twin in late Dec..so I got that..got it delivered about 3rd week of January..
 Looked like this..
« Reply #2 on: February 11, 2013, 11:01:43 PM »
Hi 754...will be cool to finally see what comes of all your planning.  I bet you ain't gonna use those cb350 stock mufflers...but I sure could.  PM me if you want to work out a deal.
« Reply #3 on: February 11, 2013, 11:08:01 PM »
The guys around here put dibs on that stuff right away.. I am hoping I can make it work in that frame, but it is fighting me. I wil have to raise the swingarm pivot, and frame backbone about  2inches, which means major frame surgery..no way around it..
« Last Edit: February 11, 2013, 11:11:41 PM by 754 »
« Reply #4 on: February 12, 2013, 01:17:29 PM »
Looking forward to seeing this build.
« Reply #5 on: February 12, 2013, 01:52:13 PM »
I would be looking for an engine that fits the frame Frank, you really don't want to move the swingarm pivot, its where it is for a reason and would be a real shame to cut up a vintage tracker frame...
« Reply #6 on: February 12, 2013, 02:10:10 PM »
 It was 1970 trials bike, bought it for the Betors and Akronts.. What is really good on it is the rake that fits the bill and almost unlimited turning angle. 2 stroke engines  however,are not as high from sprocket shaft to bottom of engine.
 So I got nuthin to lose..but dont have the welding equipment to do it myself. I mentioned that I have to lift the top 1/2 of the frame, to a buddy that builds bikes and frames. He said..So...start cutting.. At least I can get it tacked next door. I will have to do it in 3 stages..
 Another thing that makes this frame a great choice is that the tube behind engine, actually goes backwards, in the carb area. This is pretty rare,and I plan on running a Dellorto or Weber 2 throat..of course (need the clearance)....and a really cool set of TT headers that I have waiting to have a bike built around them..
« Reply #7 on: February 12, 2013, 02:20:11 PM »
Can't wait to see a weber hanging off the engine,  ;D   You could always knock up a quick jig to bolt down the frame and go from there..
« Reply #8 on: February 12, 2013, 02:26:12 PM »
 My buddy has several frame jigs (well known builder) he will probably weld it up but if I can tack things, nearby, it will help a lot..
 Back in the day I had a hopped up 350,  with KO carbs. I have lots of 2 throat jetting, if I run anything else, will have to pick up lots of jets..
« Reply #9 on: February 13, 2013, 09:37:25 PM »
What kind of sick joke are these Spaniards playing..??
Turns out that the rear axle is 15 mm, and worse than that the swingarm plvot is only 12 mm...that is not going to work with the mighty CB 350..... More work ahead..
« Reply #10 on: February 20, 2013, 03:23:25 PM »
 I dug out the side spacers off that wheel, heavy 80,s style beasts carrying extra weight.
Lucky the register lip was correct for the sprocket I planned to use boot pattern correct too.Disc fits but need to redrill for bolt pattern.
 Put the spacers on a diet..went from 915.17 grams to 671.53... Still a bit to come off right on target for my estimated. 3 lbs for sideplates and bearings..
« Reply #11 on: February 20, 2013, 04:14:26 PM »
Why not lower the motor by modifying the frame at the bottom?
Offline brandEn
« Reply #12 on: February 20, 2013, 05:15:01 PM »
Looking forward to seeing this one Frank. Keep the pictures coming man!
Offline Roach Carver
« Reply #13 on: February 20, 2013, 05:38:51 PM »
intreresting. very interesting.
« Reply #14 on: February 20, 2013, 06:56:07 PM »
Subscribed....
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #15 on: February 20, 2013, 07:13:54 PM »
Can't wait to see this one Frank!
Offline AbbyRider
« Reply #16 on: February 21, 2013, 07:40:50 AM »
I'm really digging the look of that frame. Looking forward to seeing the progress. Hopefully the snow doesn't hit too hard this weekend. Or maybe that's good for progress.
'98 VTR1000 Superhawk
'78 CB750F
'77 CB750F (in the works)
'81 KZ650 sitting in pieces in my basement
Offline Syscrush
  • Sold. :(
« Reply #17 on: February 21, 2013, 01:03:07 PM »
Watching with interest...
« Reply #18 on: February 21, 2013, 01:16:20 PM »
Is it done yet?
I got TAIL today !!
« Reply #19 on: February 27, 2013, 09:21:25 PM »
Got  my Champion style tail section today from a member in Texas.. Thanks Hosa..
Of course revamping the entire. Seat area of the frame will be required..nothings easy..
 Looks like so....was thinking of runnning XL 250 tank.
« Last Edit: February 27, 2013, 09:24:10 PM by 754 »
Offline Free Booter
  • My Build: CB750k5
  • Meh.
« Reply #20 on: February 27, 2013, 10:36:29 PM »
Good choices.
Definitely matches the look and feel of a proper tracker.
Offline chris mcshifty
« Reply #21 on: February 27, 2013, 11:38:46 PM »
Liking the tank and seat combo
Offline Viktor.J
  • Breaking in the forum
« Reply #22 on: February 27, 2013, 11:58:58 PM »
Me to !
That tail looks sweet !
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
« Reply #23 on: February 28, 2013, 02:28:55 PM »
 I may run an aluminum tank,much lighter..
 The seatbase fender and tank in this pic, is about 5 or 5 1/2 lbs..
« Last Edit: February 28, 2013, 02:31:57 PM by 754 »
« Reply #24 on: May 13, 2013, 09:28:36 PM »
Well that sure got back-burnered..
But today I got this.. Race is2 months away, so i just may run this, should still run..
« Last Edit: May 13, 2013, 09:31:09 PM by 754 »
