Author Topic: '78 CB750k conversion to cafe racer (yes, more issues)  (Read 61157 times)
Offline harisuluv
Re: '78 CB750k conversion to cafe racer (move up to 120 mains?)
« Reply #275 on: May 10, 2014, 11:46:38 PM »
so you have pods and you didn't change your needle height?  pretty standard if you want to run pods, you raise your needles and then go up on the main jet.
Since you have a 78, this has no adjustment clips, so you would have to use shims.  You could probably go to a 105 or 110 main jet.
It usually isn't necessary to change the idle jet.
« Reply #276 on: May 11, 2014, 12:17:55 AM »
I had to do the same with my carburetors on my 550 when I went to pods.
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #277 on: May 19, 2014, 07:33:19 AM »
I actually have '73 carbs so I should be able to raise my needles another notch.
Finally got a day off so I can take the carbs off and do this, at last.
Is there any way to unscrew the needle from it's position inside the slider cylinder without messing around with the slide adjuster screws? I am dreading the possibility of messing up the carb syncs.
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
« Reply #278 on: May 19, 2014, 07:41:40 AM »
As soon as you touch those slides, you're going to need to bench and vac sync again  :P
Re: '78 CB750k conversion to cafe racer (raising needles)
« Reply #279 on: May 19, 2014, 10:17:27 AM »
Ugh..
Will have to save up to get a vac sync.
Still a little flat towards the upper range, and a slight lag on sudden acceleration- can live with that for now.
Thanks anyway.
« Reply #280 on: May 19, 2014, 11:29:20 AM »
Did WOT then chops as best as I could on a small hill near me- considering I live in an intense populated area.
Light gray look- which is normal, right? Or maybe I did not WOT enough to build up a residue...
« Last Edit: May 19, 2014, 11:38:46 AM by deafcaferacer »
« Reply #281 on: May 19, 2014, 12:13:14 PM »
If my chop was as good as I could do....i'd say thats a bit lean still, and IIWM, i'd go up by a 5.
(ie. 120 ->125)
pics are good here...
http://www.turbododge.com/forums/f4/f62/624186-reading-spark-plugs-troubleshooting-guide.html
« Last Edit: May 19, 2014, 12:15:19 PM by flybox1 »
« Reply #282 on: May 19, 2014, 12:15:08 PM »
(ie. 120 ->125)
Could I do that over raising the needles? I have 115 so I'd go up to 120.
Not sure what the benefits are for raising needles vs. going with bigger mains.
« Reply #283 on: May 19, 2014, 12:30:10 PM »
needles are mid-range....leave them where they are.
up your mains to 120, and then do another plug chop, should be really close.
once you're satisfied, do a mid range plug chop (1/2 - 2/3rds throttle position) to determine if your needles are in the right spot to give you the correct mixture.
« Last Edit: May 19, 2014, 12:32:42 PM by flybox1 »
« Reply #284 on: May 19, 2014, 07:07:24 PM »
Thanks, Rob.
Have ordered 120 mains. Sitting tight until they arrive.
Going to go back to reading everyone else's builds in the meantime.
« Reply #285 on: May 22, 2014, 09:00:48 AM »
Question, could I swap the main jets with the carbs still on the bike?
Or do I have to pull the carbs to change the jets?
« Reply #286 on: May 22, 2014, 09:10:07 AM »
you dont have to pull them, but if you have big hands like me, getting the bowl screws out sucks.
its faster for me to take the carbs off.
« Reply #287 on: May 23, 2014, 12:36:21 PM »
I do have big fat hands, but fortunately the bowls are clip ons.  ;D
Had a window today to put in the new jets before it started to rain again and took her out for a ride, she kicks like a mule now and I have power in the upper range now.
Tried to do a WOT, but did it improperly. I think I know another place to do it to get much closer to the 2-3 minutes of WOT necessary to get an accurate read. Will report on this when I can get another ride in.. raining now and more rain tomorrow, but Sunday will be perfect.
« Reply #288 on: May 23, 2014, 12:43:13 PM »
8)
Re: '78 CB750k conversion to cafe racer (new mains in)
« Reply #289 on: May 26, 2014, 09:31:22 AM »
I just noticed that the rear brake isn't engaging very well and that the rear brake pedal doesn't spring back firmly.
I suppose this warrants a look inside the rear brake cylinder? Feels like a worn spring at work here.
« Reply #290 on: May 26, 2014, 10:27:33 AM »
Disconnect the long footbrake connecting rod(spring and adjustment screw) from the drum brake lever.  Actuate both the foot lever and the drum lever manually and you'll be able to tell where to focus.
Offline iron_worker
« Reply #291 on: May 26, 2014, 11:46:27 AM »
Are you using fresh plugs for your chops? Doesn't look like it.
IW
« Reply #292 on: May 27, 2014, 09:01:03 AM »
I did this and could not find anything wrong at either end.
But what I noticed was that when I activated the drum level with the tire off the ground, it stopped easily enough.
But when riding the bike, and testing the rear brake by using it isolated, it doesn't brake good. Could the shoes be worn out?
« Reply #293 on: May 27, 2014, 09:01:57 AM »
IW
No, I'm not. I suppose I should get some new plugs?
« Reply #294 on: May 28, 2014, 11:54:52 AM »
possibly, but you'll want to pull the drum apart and check.
if you've got good meat on your pads, you can put some emery paper to the ID of the drum to deglaze it a bit, and dry rag wipe all the brake dust (dust mask suggested - asbestos maybe) and clean it up.  Blow out(outside) with air if you have it.
Re-assemble, and give the brake lever adjuster spring nob a turn in, or three, from its last position to allow the pads to engage earlier in the brake lever travel.
« Reply #295 on: May 28, 2014, 01:11:05 PM »
Thanks for the tips. Will do this tomorrow and report back.
Re: '78 CB750k conversion to cafe racer (rear brake shoes worn out?)
« Reply #296 on: May 28, 2014, 01:46:51 PM »
PS...have someone firmly depress the rear brake lever as you are torquing down your axle castle nut.  Allows for better drum centering/more even wear of your pads  ;)
« Reply #297 on: June 30, 2014, 07:36:30 AM »
Thanks, ended up being just a few turns on the brake lever adjuster that did the trick.
Been riding the bike quite a bit and some new issues have come up- smoke coming through the air filters, a strong smell of gas. I checked the bowls and #1 seems to  be consistently overflowing despite the fact that I cleaned the carbs just a few months ago.. checked and rechecked, nothing seems blocked or stuck or jammed, and yes I checked to make sure float was right side up.
Pretty baffled.. maybe I should just order a float replacement set?
Re: '78 CB750k conversion to cafe racer (yes, more issues)
« Reply #298 on: June 30, 2014, 11:37:34 AM »
Update: looks like the flat washer for the float valve set is shot.
I took off the bowl and turned on the petcock while manually holding the float in and immediately it started to drip, drip, drip and I was able to isolate it to the flat washer seeing the gas swell up around the valve set and flow down from that.
So either way, have to order a new float bowl kit.
