Author Topic: Randakk spin on and carpy exhaust  (Read 5882 times)
Re: Randakk spin on and carpy exhaust
« Reply #25 on: March 12, 2013, 11:45:46 AM »
Is it a problem?
Taking off the exhaust is easy done. Change oil each driving season when the exhaust might be off anyway.
I ride wayyyy more than 1500 miles in a year. Probably change my oil twice a month in the summer time.  Taking the exhaust off for each oil change is a pain-  a pain that would be worth it for a track bike or something you don't ride much, but for daily driving it's a deal breaker, IMO.
It was long time ago I used my bike, but in those days I changed oil+filter each season or at 5000miles (8000km). Street and touring, not racing.
« Reply #26 on: March 12, 2013, 04:32:30 PM »
Its a race designed pipe, not a bad design, maybe bad for some on the street but not a bad design.... ;D ;)  I actually like removing my pipe a couple of times a year, keeps the threads on the studs clean and makes removal of the pipe easier when needed... ;)
JWExperience
« Reply #27 on: March 12, 2013, 05:03:13 PM »
I found a few filters with OD's of 3" on ebay. one by hastings and one by K&N. Im gonna contact the people at randakk to make sure the diameter of the gasket will work because their website only says 3" or less on the gasket. The Hastings gasket is 2.75 in diameter. I just measured my carpy header and it looks like i have a 3 1/4"- 3 3/8" gap between the two middle header pipes= Im buying a randakk with spin-ons and ill never have to remove the pipes. I'll try to post back ASAP on my final results but it looks good on paper.
Offline prov431
  • '76 CB550K
« Reply #28 on: March 13, 2013, 05:29:27 AM »
A wee bit off topic - I have a 76 Cb550 with carpy exhaust, can you tell me how you have your carbs jetted and air screws set, as well as what carb air filters your using?
Offline tjfisher
« Reply #29 on: March 13, 2013, 06:47:28 AM »
Well pipes are not hard to remove maybe anoying but i think i might still get a set . maybe due to the issue ill be able to find a used set  ;)
77 cb750
71 norton commando 750
IF its not broken ..... i cant afford it
Offline andrewk
  • doin' it.
« Reply #30 on: March 13, 2013, 01:26:19 PM »
Is it a problem?
That would make it easier, however, the oil change interval for the 750 is 1500 miles, or every 3 months.  Air cooled engines are a lot harder on oil.
JWExperience
« Reply #31 on: March 14, 2013, 09:27:57 AM »
The folks at Randakks emailed me back and the minimum ID spin on filter you can use with their system is a 2.25" I have found several filters with a OD Of 3" and an ID of 2.4-2.5" My exhaust headers are 3.25" apart so I will now be spending 65$ and using modern filters with better tech and not have to take off my exhaust. I appreciate the effort from u guys.
JWExperience
« Reply #32 on: March 14, 2013, 09:31:33 AM »
My bike is a 76 750 so I'm not sure exactly of your setup but seems like going up 2 on the main would be a good start if no other engine mods or air filters.
Offline Ricky_Racer
« Reply #33 on: March 14, 2013, 12:42:59 PM »
Did they suggest a particular filter brand and model (or application)? Thanks. RR
JWExperience
« Reply #34 on: March 14, 2013, 01:54:34 PM »
No they did not. It doesnt really matter which filter you use brand wise. Just make sure its 3/4" 16 thread and from research I've done on filters I would purchace K&N, Napa, Bosch among others which are also good quality. The bosch is a rebrand of purolator pure one i believe. I picked a K&N HP- 1002 but several others will fit. I tried to stay away from the taller ones to keep it away from the exhaust pipes and heat but also didnt want to go too small so the filter would have more than enough cleaning surface inside. I also picked the K&N because it has a 1" nut welded to the top for easy install and removal.
Offline Ricky_Racer
« Reply #35 on: March 14, 2013, 02:27:56 PM »
Thanks, JW. RR
Offline Gregorymoto
  • SOHC Aficionado
« Reply #36 on: March 21, 2013, 08:27:03 PM »
http://www.m-tecchukyo.co.jp/honda_cb750/honda_cb750_top.html
This is the high end option. Look around you will find the pipe i was talking about.
Yep, i have issues with this sort of stuff.
