Author Topic: 350 front end options?  (Read 1823 times)
Offline Green550F
  • Nothing is as cool as that which you made.
« on: August 06, 2006, 07:13:48 AM »
what other front end hve beed fit to 350s? when I dissassemble mine for paint, I want to at least replace the bearings if not the forks also.  Any suggestions?
the work in process:
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: 350 front end options?
« Reply #1 on: August 06, 2006, 09:30:30 PM »
        Check out ohiocaferacers.com, you'll see that Greg has installed a set of inverted forks from an early GSXR (I think that was the model) I think it was mainly a matter of grinding the weld off the bottom of the stem (where it is welded in place on the tree) and replacing it with the 350 stem. There's pretty good details on the site and Greg can tell you more about it that I can. I'm sure there are several forks that will adapt, I just don't know what all they are. I figure the old 450, 500/550 four should fit. You may want something a bit more impressive. Anybody else?    Later on,  Bill
Member # 1969
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: August 06, 2006, 11:36:31 PM »
He's the 350 God ;D
