Author Topic: The amazing tape  (Read 1677 times)
The amazing tape
« on: July 12, 2013, 07:51:34 AM »
We were in Denver, when the radiator on our 04 Grand Cherokee sprung a leak.
Before we left from Virginia, I changed all I could and checked everything, including pressure testing the cooling system.  No matter, there was the leak, spraying coolant at the engine.
First I tried BARs leak fix, but it did make a little difference, after the day drive from Denver to Black Canyon campground, the leak was back.
I decided I have to have better access than through the shroud and cut a hole in the shroud.  Than I carefully saw off the radiator frame C channel, with a flat piece of wood cleaned off the fins and tried the old trick of pinching the leaking part of the radiator.  The old aluminum sprung another leak in response to my efforts.  I guess the pinch fix is for copper radiators.
Luckily I had a piece of plumbers tape in my kit and with a bit of effort and quite a bit of strong words I was able to wrap it around the trouble spot.  The next day I stopped at Home Depot and got more of the tape, wrapped another layer or two or three over the fix and hit the road.
Except for checking the coolant level several times a day it did not give me more trouble, the tape is truly amazing.
Re: The amazing tape
« Reply #1 on: July 12, 2013, 07:52:39 AM »
And here is the radiator fix that lasted 5000 miles.
Also I learned about the tape here on the forum, I am sure electrical or duct tape would never hold the same as the Nashua tape:
http://www.homedepot.com/p/Nashua-Tape-Stretch-and-Seal-1-in-x-3-33-yds-Silicone-Sealing-Tape-684201/100206050#.UeAYpazzlWU
I am going to write the maker a letter, it truly saved our vacation.
« Last Edit: July 12, 2013, 07:55:17 AM by 70CB750 »
Offline dusterdude
« Reply #2 on: July 12, 2013, 01:28:32 PM »
Cool,what part of va you in
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: July 12, 2013, 02:31:49 PM »
I am near Warrenton.
« Reply #4 on: July 12, 2013, 03:26:59 PM »
Amazing, would have bet against that, I'm buying some.
Hope your going to replace it now.
« Reply #5 on: July 12, 2013, 06:42:03 PM »
I have been using that stuff for years. It is great stuff, it actually only sticks to itself and it bonds chemically to itself. It come off with no residue. Much better than electrical tape for insulating.
« Reply #6 on: July 12, 2013, 09:09:07 PM »
If Nissens brand is available for your Cherokee I would recommend them. Very good quality product. Have used them for a couple Volvo 240s I have owned... used same one in 2 cars for more than 150k miles...
David
Offline dusterdude
« Reply #7 on: July 13, 2013, 05:46:21 AM »
groovy,hopewell
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
« Reply #8 on: July 24, 2013, 03:58:20 AM »
So I changed the radiator, took it for a spin and it sprung significant leak from the water pump.
That truck is a kidder  ;D
Offline Raul CB750K1
« Reply #9 on: July 28, 2013, 06:51:58 AM »
It seems to be what we call over here self-vulcanizing tape. We use it to make electrical connections weatherproof, but apart from that I haven't given it much use. Seems it saved your day though.
