Author Topic: Let's see your non-SOHC4 on the road  (Read 416547 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Let's see your non-SOHC4 on the road
« Reply #225 on: September 10, 2014, 09:17:03 AM »
Obligatory Drippy Bird pic. First ride on my new '83 CB1000C after going through the carbs. That thing's quick!!
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #226 on: September 10, 2014, 02:07:43 PM »
...and just now, out near the Natchez Trace Parkway
Offline dhall57
« Reply #227 on: September 10, 2014, 03:12:07 PM »
How do you like the Custom Tug? Its looking good 8)
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #228 on: September 11, 2014, 09:41:06 AM »
It's fast! One thing I've noticed is that, similar to my GL1100, the riding position is such that at highway speeds your head gets blown around a little. Nothing that a little windshield won't fix. Brakes well. Redlines at almost 10k and real power kicks in at around 5k. I don't have the time or tools to do it myself, so I'm having the valves adjusted at the shop next week. After that I'll sync the carbs and I should be good to ride it to Savannah next weekend. Fingers crossed!
Offline dhall57
« Reply #229 on: September 11, 2014, 10:24:26 AM »
That's right its dohc. Need adjusting shims to do the valves. That's one thing that turns me off about those engines.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline ofreen
« Reply #230 on: September 11, 2014, 11:33:04 AM »
It is no biggie. A simple little tool is needed to hold the valve open to replace a shim if  adjustment is needed, plus a trip to the dealer for shims. So not as handy as screw adjusters.  But my experience with those engines was that the clearances stayed in spec for a long time once broken in.
Greg
'75 CB750F
Offline MoMo
  • Ride like you're invisible
« Reply #231 on: September 11, 2014, 06:25:02 PM »
Agree as they did stay in specs for a long time,  not bad at the shop but driving to a dealership to get shims would be a pain...Larry
Offline cheftuskey121
  • Super Newbie
« Reply #232 on: September 11, 2014, 07:52:58 PM »
how about my non-sohc4 OFF road? Honda nx650
« Reply #233 on: September 11, 2014, 07:55:34 PM »
Looks like fun Chef.  Down and dirty!
« Reply #234 on: September 11, 2014, 11:26:42 PM »
Thanks Terry I think you would like riding here - wide open country roads and ocean drives. Just need to watch out for deer and moose!
More Oz pics please! I like the Beemer very nice how does it compare to your Triumph? (still got that?)
cheers
Andy
Thanks Andy, I've still got the Triumph but haven't ridden it for almost 2 years? I really must pull it out of the garage and wash the dust off and take it for a ride, it's now 7 years old and hasn't even had it's second service yet! Cheers, Terry. ;D
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #235 on: September 12, 2014, 10:51:12 AM »
Ooh man that looks super fun!!
Offline 750cafe
« Reply #236 on: September 12, 2014, 11:28:03 AM »
It actually IS a SOHC Honda but, dirt worthy...
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
« Reply #237 on: September 12, 2014, 05:10:27 PM »
Ooooher, I think I've got that bike's grandfather in my garage mate, an early 1980's XR500? A customer left it here a couple of years ago and I haven't heard from him since, I think I might wheel it out and see if I can start it, I believe it hasn't run in many years? Cheers, Terry. ;D
« Reply #238 on: September 13, 2014, 02:58:44 AM »
Well Andy's post gave me pause to think about why I haven't ridden my Triumph Rocket III for so long. A motorcycle not ridden slowly morphs into little more than a parody of a motorcycle, and it's almost cruel to allow a perfectly good bike to slowly rot, untouched, and regardless of good intentions, unloved. I've got 4 other registered bikes, so it was easy to leave the Triumph in a cold dark corner of my garage while I enjoyed the pleasures of Bargain Basement motorcycling.
Today I decided to make a stand against my own negativity. I dragged all my other bikes out of the way, and fired the big beast up. Well, not initially, even though the battery was fully charged it takes a lot to crank over 2300cc's of unwilling engine, and the 2 year old gas had lost most of it's "Ooomph", so it fired once or twice before the battery gave up the ghost.
No biggie, I pushed it out into the brilliant morning sunshine, and treated it to a wash. Things were looking up, so I drove my car around to the gas station and bought 20 litres of Mobil's finest 98 RON, then over to Repco for some Penrite coolant and semi-synthetic 10W40.
I pumped the old gas out of the tank into a Jerry can to use as weed killer and refilled it with the fresh fuel, with a couple of additives that I like to use. I hooked up my jump start pack and this time it fired right up and settled into a lumpy 3 cylinder idle. I let it run for awhile then switched it off, and checked the oil. Just like our old CB750's, it has a separate oil tank, and to my horror, I realised that I could see the bottom?
Now that's odd, with less than 7000 miles since new it doesn't leak oil or blow smoke, and as it'd done less than 200 miles since the Triumph dealer stripped the engine to replace the output shaft bearing, it's pretty apparent that they didn't top up the oil tank. I managed to put a full litre of oil into the tank before it came up to the "full" mark on the dipstick. Similarly, I had to top up the coolant tank too. Finally, I inflated the tyres to the recommended 42 psi (rear) and 34. (front) By now it was mid-afternoon, and time to go for a ride.
Lately I've been enjoying the 150 mile round trip to Yea (Yay!) on my other bikes, but I hadn't done the trip on the Rocket, so decided that it was time. I stopped along the way for a photo opportunity when I discovered that an old country pub I'd always meant to stop at for a drink had closed down, another missed opportunity, hopefully someone will buy it and I'll get another chance to wet my whistle there too.
As I rode into Yea, I was surrounded by a swarm of Honda CT110 scooters, what we call "Postie Bikes", because the Australia Post delivery men ride them. I counted around 20 of these little Honda's and mused that all 20 bikes were still collectively smaller in capacity than my Triumph engine. I pulled up at the "Red Plate Cafe" and Dave made me a coffee and a meat pie, and I yacked to him and his wife's sister who was really into bikes, and then turned for home.
I arrived home around 6pm, tired, but happy. The Triumph had run flawlessly, no leaks or rattles, I let it have it's head for a couple of short bursts, and saw 220 KPH (136 MPH) at one stage, then thanked God for modern brakes and tyres when I overcooked it in a bend. All in all, a great day! ;D
Offline azuredesign
  • Knupping pin
« Reply #239 on: September 13, 2014, 05:07:31 AM »
Sounds like a nice day Terry. Thanks for inspiring me to reacquaint myself with some of the neglected residents of my own garage! ;)
Offline dhall57
« Reply #240 on: September 13, 2014, 05:48:11 AM »
Glad you got the big guy out and let him stretch his legs at 136mph!! Terry Im sort of in the same situation as you. I've got five bikes, four being road ready. I've got to start wrenching on my 750K4 and get it going. No matter how many bike's you got I haven't figure ed out how to ride more than one at a time ::) I'm in the same fix with my 97 Wide Glide as you are with your Triumph. I know many don't have good thoughts about Harley's and say they wouldn't take one if it was give to them. And it's true I've got more $$ in it than I do all my Honda's. It's been idle for 6 months and I just got current tags back on it and a new battery and gave it a bath. Still not detailed like it should be but alot better. It came to life on the 2nd hit of the switch. The potato, potato sound of the Evo 1340 big twin ;D  Not riding it much I forget what a good bike it really is and how much I like it. But since getting back in the sohc4 Honda world in 2009 taking me back to my youth in the 70's when these Honda's were king I've been focused and my priority has been on them and it so easy to jump on one of my Honda's and leave the Glide neglected and gathering dust. But like you and your Rocket Terry I'm going to try to spend more time in the saddle of the Glide ;) because it's to nice of a bike to be neglected.
« Last Edit: September 13, 2014, 06:45:29 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #241 on: September 13, 2014, 05:29:42 PM »
No worries guys, and yep, get those bikes out of your garages before they become someone else's "Barn Finds"!
Dwight, I'm a Harley fan too, I bought a 1985 Sporty in 1987 and loved it, but had to sell it after less than a year's ownership (needed a second car) and have promised myself that I'll buy another one eventually.
I suppose I could have bought one when I bought the Triumph, but I only bought it to help my brother out of a jam, but I'm glad I did, it's a wicked ride! Cheers, Terry. ;D
Offline 750cafe
« Reply #242 on: September 13, 2014, 09:28:16 PM »
Good on ya to get the big beast out of its cage and let it roam free.  8)
I also have several that have been neglected and look forlorn.  :(
Only so many hours in your time off with plenty of project bikes and work that needs to be done around the old homestead.
Eric
« Reply #243 on: September 13, 2014, 11:00:16 PM »
Yeah Eric, my current contract expires in 6 weeks, and although I'll be offered another position I'm seriously thinking about taking a redundancy package and enjoying some time off.
If it was the middle of winter I might not have the same recurring dream of waking up late on a brilliant spring morning, wandering out to my garage with a cup of coffee and a cigarette, throwing my leg over whatever bike I want to ride today, and just blasting off into the hills for lunch and a beer at one of my favourite watering holes.
It might not last forever, but I reckon I could enjoy at least a couple of months of finishing various projects and maybe starting a few more........ ;D
Offline dhall57
« Reply #244 on: September 14, 2014, 06:32:34 AM »
Here's the Wide Glide. Trying to ride it more.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline saltcitycafe
« Reply #245 on: September 14, 2014, 06:56:35 AM »
2005 Suzuki SV650S its my daily rider :)
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #246 on: September 16, 2014, 01:46:24 PM »
Had our 3rd Annual Pseudo Moto Rally in Nashville this past weekend. Over 70 bikes on the ride. My view from the front:
And about 150ish at the event. More pics here:
http://www.danielmeigs.com/pseudo/
And here:
https://plus.google.com/photos/116737628974558341706/albums/6059545512950066865?sort=1
You may be able to spot the winners, which were voted on by the attendees:
Best Custom: 1972 Triumph Daytona 500
Best British: 2009 Royal Enfield Bullet 500
Best Euro: 1967 BMW R50/2
Best USA: 1999 Custom Sportster
Best Japanese: stock 1970 Honda CB350
Best In Show: 1971 BSA A656
Offline 23tbucket
« Reply #247 on: September 16, 2014, 08:02:10 PM »
Some very nice rides being posted.
I've been on two wheels since 1964.
You can always tell an old biker: he adds a wheel!
Honda 1983 DOHC 900cc, fuel injected, N/A.
Offline dhall57
« Reply #248 on: September 17, 2014, 01:04:12 AM »
I'm sure it's a conversation piece where ever you go T 8) Did you build it?
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #249 on: September 17, 2014, 01:43:48 AM »
That's a beautiful bike Dwight, it'd be in good company with my Triumph! ;D
