Author Topic: The Quest for Brakes and Suspension: GSX-R Treats  (Read 69886 times)
Re: The Quest for Brakes and Suspension: GSX-R Treats
« Reply #200 on: May 06, 2014, 01:00:10 AM »
Sweet! ;D
Offline timbo750
« Reply #201 on: May 06, 2014, 01:14:47 AM »
This might be a silly question, but did you try to match the pattern on the fuel cap and the top of the tank.  Or will it not matter.  The pattern used on the top of the tank seemed to be more uniform.
Project 1 CB750 - http://forums.sohc4.net/index.php?topic=126864
Offline sethdhawkins
« Reply #202 on: May 06, 2014, 02:23:51 AM »
I chose a smaller pattern for the center stripe. The fuel cap pattern was cut from the same portion of cloth, so they match.
If you look closely, this picture kinda shows it.
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
Offline timbo750
« Reply #203 on: May 06, 2014, 12:09:55 PM »
Well done, cant wait to see the final paint finish
« Reply #204 on: May 08, 2014, 01:23:49 AM »
Mmmmmm...butter.
This is how much I bevel the edges on a stock boot to install the RS34's.
They're in! Much easier with a friend. I just about gave myself a hernia putting them in solo :-/
I've seen people ratchet them on with tie-down straps. Not looking forward to it.
Just bevel them like in the photo, heat them up, put on a little lube, and I promise it won't be that bad. Learn from my mis-steps. The first time I tried to put them on, I only beveled the insulators a tad and didn't use heat. Even with the help of a friend, I was unable to get them on. I smartened up, and used heat. With a friend, they slipped right in. This time around, I knew how much to bevel, and to hat them up. They went on (relatively) easily compared to the first go around.
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #205 on: May 08, 2014, 01:27:24 AM »
Wanted to pick folks brains a bit on two slight annoyances. The first is the starter gear clutch. I rebuilt it with the little kit from David Silver Spares. At the time, when I had everything apart, I inspected both the large and small starter gears, and they looked just as decent as the set I bought of eBay (from an unknown mileage bike). Nonetheless, the bike, on one of the 15-20 times I started it, made that godawful clang again! I'd rather not tear the damn thing apart again, put in the used gears, and have it do the same thing. Am I missing something, or should I just throw starter gears at it till it stops, or could it be an issue farther upstream? Kinda sucks, especially now that I have the rearsets and can't kick it.
The second issue may or may not be an issue. I installed the cycle x clutch kit (pretty damn confident it was done correctly) and reinstalled my Barnett clutch springs, modified my clutch basket per Hondaman, and filled the bike with Valvoline 20w-50 motorcycle oil and my ZDDP zinc additive, and fired her up. I can shift just fine through the gears while running, but finding neutral is damn near impossible. With the bike shut off, no problemo. I've never run 20w-50 (last three oil changes were 10w-40 and Rotella Diesel oil cause it's what I ran in my Cummins), or Valvoline bike oil before. I never had a problem with this prior, unless it was a super hot day and I was sitting in traffic...and even then, I could just rock the bike back and forth a lil' and find the sweet spot. Without getting into an oil discussion, anybody else out there have an upgraded clutch, and have a proven oil and weight that the clutch enjoys?
On the same vein as oil, I saw this on eBay the other day, and thought it pretty nifty, and maybe an easier solution to the wet sumping problem that so many seem to encounter.
http://www.ebay.com/itm/201086220345
I just got back to work, so there's not going to be any progress on the bike for the next three weeks :( I do hope to see the completed paint via photo (might even be able to get him to set the tins on the bike).
Seth
« Last Edit: May 08, 2014, 01:55:21 AM by sethdhawkins »
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #206 on: May 08, 2014, 03:45:06 PM »
Some photo documentation with a good camera. We had fun with this, as we were both a few drinks in ;)
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #207 on: May 08, 2014, 03:49:58 PM »
How is she running, Seth?
« Reply #208 on: May 08, 2014, 03:53:27 PM »
I didn't fire her back up after the carb insulator replacement. I imagine it'll be fine. I actually didn't see a huge lean out with that tear in the insulators, surprisingly. The bike has always run well with those carbs, but after all the miles I've logged, I think there's room for improvement. See my post above about the two nagging problems I have at the moment that seem to be eluding me. I cannot wait to ride the crap out of this thing when I get home; she ain't no trailer queen ;)
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #209 on: May 08, 2014, 04:00:57 PM »
I've been getting some false neutrals lately on my 750.  It'll read neutral in 2-4 gear sometimes, and then be a biyatch actually slipping into neutral at a stoplight.
« Reply #210 on: May 08, 2014, 04:43:58 PM »
Don,
Since your new project is getting the full treatment anyway, I think you should forge the path for the use of a set of re-racked FCR's ;)
http://www.dynoman.net/carb/keiFCR.html
Seth
« Last Edit: May 08, 2014, 04:46:09 PM by sethdhawkins »
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #211 on: May 08, 2014, 04:48:42 PM »
I am still jonesin' to put RS34s on my new 750.
Too much bike porn and bikes and not enough time to ride them.  I had a "weak moment" today when I thought of selling my very pristine RC51, since I've been neglecting to ride it much lately.
« Reply #212 on: May 08, 2014, 05:08:13 PM »
I've been looking at putting together a sidecar rig for myself and the hound dog.
 I'm thinking a new Bonnie or a sportster for the propulsion, and trying to find a cheap Chang Jiang/Ural car...budget around $8k. I'd love to just cruise the back roads with her.
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #213 on: May 08, 2014, 06:26:26 PM »
I'd love to have a sidecar for the dog.
« Reply #214 on: May 08, 2014, 08:19:20 PM »
You do understand!
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #215 on: May 08, 2014, 11:41:01 PM »
I run all of my errands with the dog in my mini-pick-up.
« Reply #216 on: May 09, 2014, 05:01:48 AM »
That starter clutch thing is weird Seth, I've had over 20 CB750's over the past 36 years and I've not had a problem with the actual gears. I did have a bad starter motor that made some horrible noises when I was riding the bike, while barely able to turn over my stock F2 engine, but nothing like you've described?
I hate Valvoline oil in bikes. I had all the same problems you've described the one time that I used it in my Z1, the clutch was either "on" or "off", with nothing in between, I either had to rev it up and wheelie away, or stall it, and there was no way I could find neutral. I dumped that crap out and refilled it with some cheaper Mobil oil, and never had that problem again.
Change your oil Seth, and I bet the problem goes away. Cheers, Terry. ;D
Offline Syscrush
  • Sold. :(
« Reply #217 on: May 09, 2014, 06:11:46 AM »
It's looking just great.  Some of these 750 builds are making me question my preference for the 550. :)
I've had a few bikes that didn't want to go into neutral if the idle speed was set above a certain threshold.  On my wife's M620, if the idle is above 1500RPM, it just won't go into neutral with the bike stopped and the clutch pulled in.
This can be exacerbated during testing/shakedown riding, because the engine doesn't have the chance to get up to temp, so you're more likely to have the choke on and have a higher idle speed.  Before you go making clutch changes, try letting it warm right up, and dial the idle speed down a bit and see what effect that has (if any).
« Reply #218 on: May 10, 2014, 10:10:36 AM »
Thanks, Terry. I think I'll probably give her a drain, as I need to modify my oil drain line anyway. I may try some bel-ray that my buddy gets in bulk. All the local vintage triumph guys seem to love it.
The starter issue is annoying. I'll see if it does it again. If so, I'm gonna replace everything I can get my hands on...it's such a terrible sound, and not one that should ever emanate from a motorcycle.
Seth
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #219 on: May 10, 2014, 10:13:14 AM »
Have no fear, I'll only be changing the oil first ;) Thanks for the kind words!
1972-ish CB750K
1974 CB450
1974 CB360
Offline Syscrush
  • Sold. :(
« Reply #220 on: May 12, 2014, 11:09:54 AM »
Good luck!
« Reply #221 on: May 15, 2014, 11:35:57 PM »
Don, I stole your fender idea, and ordered an alloy fender from:
http://7metalwest.com/motorcycle_parts.html. Thanks for the link in your build (http://forums.sohc4.net/index.php?topic=132734). I'll mount it with some 1/4" round bar and a few bungs I have leftover. Thinking it'll be polished with black struts.
Seth
« Last Edit: May 15, 2014, 11:39:14 PM by sethdhawkins »
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #222 on: May 15, 2014, 11:51:51 PM »
Seth
That's cool.  I like the idea of it polished with black struts.  I'll be leaving mine brushed to match my tank and seat.
« Reply #223 on: May 15, 2014, 11:55:43 PM »
Those "stock" rear fenders he's producing would make a very subtle and cool upgrade to stockish cafe. I wish my 450 hadn't had the seat hinges cut off before I received it, or that would be my direction.
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #224 on: May 16, 2014, 12:07:01 AM »
More food for thought on the stockish 550.
