Author Topic: Cb750 K7 Jetting Recommendations  (Read 7912 times)
Offline KrautKoffin
« on: November 08, 2013, 03:05:13 PM »
Picked up my first bike (77k7) a little while ago and just moved into a house with a garage.. So I tear into the bike that's been at a buddies for 2 months not running. Had a mobile mechanic rebuild the carbs and I went to check the jet sizes today and the carbs are full of oxidized aluminum. Oh well. I'm cleaning all that out now and wanted to get your opinions on jetting for APE pods and the MotoGPWerks pipe. Right now I have 110 mains and 35 slows. The bike has been running lean lately and has been a pain in the dick to start and idle. I think this is because of the clogged slows in 3 cylinders, but that'll be fixed today. Should I upset to compensate for the amount of air that the PO didn't compensate for? Get all of your pod rants out in another thread, I'll be sticking to pods.
Thanks,
Jordan
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: Cb750 K7 Jetting Recommendations
« Reply #1 on: November 08, 2013, 03:38:41 PM »
No anti pod rants from me.
On my 77F2 I have increased the main to 125, and raised the needles one notch. IMS screws one and a quarter turns out. Like you, I have 35 slows stock. I thought I had it running good, but I intend to up the mains to 130 over the weekend as after a recent sustained ride I think it's still a little lean from midrange to WOT. I don't intend to change the slows, it has a good idle and doesn't stumble on take off.
This is my third CB750 that I have jetted for pods. They are not all the same. My old F2 for example didn't need the needles raised whereas this one absolutely did. Make sure those carbs are super clean and that the accelerator pump is doing it's job. Make sure your ignition timing is absolutely on the money before you even think about jetting, and that there are no air leaks at the inlets as even the slightest leak will have you running around in circles. Keep an eye on the plugs to give an indication of too rich or too lean.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline lucky
« Reply #2 on: November 08, 2013, 04:31:19 PM »
Thanks,
Jordan
Dear Jordan,
I am very familiar with that carb and that set up.
This is my recommendation:
#120 main jets.
#42 idle/slow jets
Needle clip moved down one notch from the stock position.
One turn open on the mixture screw.
It will start right up.
Make sure the accelerator pump system is working and
make sure that "mechanic" did not throw away the small brass restrictors in the three accelerator pump hoses.
You will have to make sure the two steel one way check valves work properly.
The one in the bottom of the accelerator pump is prone to corrosion problems.
Then when the float bowls are full,engine off , air filters off. Look into the intakes at the brass spray jets and twist the throttle a few times and make sure you see all 4 nozzles squirt gas.
Use a small pocket LED light to see that.
Sync the carbs.
The 1977 had mixture needles that were adjustable. LUCKY
« Last Edit: November 08, 2013, 04:37:54 PM by lucky »
Offline KrautKoffin
« Reply #3 on: November 09, 2013, 10:49:10 AM »
Thanks Lucky, these are PD42 carbs. Are the needles still adjustable?
74 cb550
Offline KrautKoffin
« Reply #4 on: November 09, 2013, 12:09:27 PM »
And where can I get new slows?
74 cb550
Offline lucky
« Reply #5 on: November 09, 2013, 05:08:05 PM »
On the 1977 they were adjustable with the clip. 1978's were not.
Offline KrautKoffin
« Reply #6 on: November 09, 2013, 08:16:44 PM »
These are PD42s..
74 cb550
Offline martin99
  • UK Based, Non-
« Reply #7 on: November 10, 2013, 01:53:03 AM »
PD42s do not have adjustable needles, so if necessary you will have to shim them. As long as you have the correct shims to hand, the job is no longer to do than if you had adjustable needles.
Lucky knows his stuff when it comes to pod tuning, as I said I have only tuned three CB750s (but plenty of others). I would still caution that you make sure everything else is in order too though (3K tune-up) if you want to get the best from your set-up.
Build threads:
1977 CB750 F2
Offline KrautKoffin
« Reply #8 on: November 10, 2013, 07:46:25 AM »
Thanks, I will definitely check into everything before running the bike!
74 cb550
Offline lucky
« Reply #9 on: November 10, 2013, 11:37:50 AM »
Best source for new slow jets is Sirius Consolidated .
Go to Ebay and look for the CB750 #42 (push in) idle jets and make sure the seller is Sirius Consolidated.
Or you could go to their website and order by phone.
« Last Edit: November 10, 2013, 11:40:09 AM by lucky »
Black 750K8
« Reply #10 on: November 10, 2013, 12:07:28 PM »
Sounds like you have a 77 with 78carbs.
Offline KrautKoffin
« Reply #11 on: November 10, 2013, 04:28:57 PM »
They are, my pd41s were in bad shape. Élan has them now!
74 cb550
Offline KrautKoffin
« Reply #12 on: November 11, 2013, 07:43:29 PM »
Ordered my jets from Sirius, can anyone link me to the shims for the needles for the PD42 carbs?
74 cb550
Offline lucky
« Reply #13 on: November 12, 2013, 07:18:07 AM »
Shims are just washers.
All washers are not the same thickness.
If you get the little brass washers they can vary by as much a .005 thousands.
Otherwise you will have to sand the washers so they all measure the same thickness.
Some places sell aluminum shims that fit inside the pocket in the bottom of the slide.
On those carbs use one shim .020 thousandths if it sits on TOP of the pocket in the bottom of the slide.
There is a pocket in the bottom of the slide that is .012 deep so with the .020 shim and the .012 deep pocket that is .032 thousandths or about 1/32 of an inch total.
IF the shim will fit inside that pocket in the bottom of the slide then you will need shims =to .032 +or - .005 thousandths.
You could just try to get some 1976 needles and use those, because they are the same taper and they have 5 grooves. Or find some 1977's.
The 77 and 78 carbs are the same but the needles were different.
Those are EPA needles that have only one groove. They did not want anybody adjusting anything. Even if it was too rich and polluting. Like high altitude places other than Colorado. That is why Honda came up with vacuum operated carbs in 1979.
The vacuum slide made operation in different altitudes possible.
Make sure this does not happen.
(photo coming)
Check out that float measuring coincidence. !977-78 ONLY.
« Last Edit: November 12, 2013, 07:28:56 AM by lucky »
Offline 750K
« Reply #14 on: November 12, 2013, 07:53:52 AM »
Sirius has the shim washers on their website also.
77 Cb750, 78 Kz1000
Offline lucky
« Reply #15 on: November 12, 2013, 09:28:22 AM »
Thanks 750K.
 Do you happen to know if those shims sit in
 the bottom of the pocket of the slide, or what thickness they are?
Offline 750K
« Reply #16 on: November 12, 2013, 10:39:20 AM »
Not to sure lucky, I have the adjustable needles in my pd's so I've never checked the shims for fit. They have them listed as carb needle shims and for use as mixture screw washers, I have a pack I bought and have a spare set of pistons out my spare pd's. I can check next time I'm in the garage tinkering.
http://m.siriusconinc.com/products-detail.php?product_id=2188
77 Cb750, 78 Kz1000
Offline KrautKoffin
« Reply #18 on: November 12, 2013, 01:29:32 PM »
http://forums.sohc4.net/index.php?topic=71245.msg791509#msg791509
Thanks for the link! I just went to my local hardware store and they don't carry them. I'll keep looking around. To move up one position I need to use 2 washers, correct?
74 cb550
Offline martin99
  • UK Based, Non-
« Reply #19 on: November 12, 2013, 01:47:21 PM »
http://forums.sohc4.net/index.php?topic=103805.0
Take a look at reply #7 in this link, might be helpful if you can't find washers locally.
Build threads:
1977 CB750 F2
« Reply #20 on: November 12, 2013, 01:58:40 PM »
YES.
you have GRAINGER in your area?
Offline lucky
« Reply #21 on: November 12, 2013, 04:45:33 PM »
ONLY if that washer sits down inside  that recessed pocket in the bottom of the slide.
IF the washer sits on top of the pocket it will only need one washer.
First you have to measure the washer with a pair of calipers and find out how thick it is. Make sure they all match. The pocket is .012 thousands deep.
You want to raise the needle about .032-.035 thousandths.
About 1/32 of an inch.
« Last Edit: November 12, 2013, 04:48:23 PM by lucky »
Offline KrautKoffin
« Reply #22 on: December 20, 2013, 09:52:23 AM »
Bump from the dead with updates!
Got my carbs back, swapped the slows to 42s, mains to 125s, and am shimming the needles now. Élan was nice enough to mail me back my old pd41s, can I use those needles with the adjustable needle positions in my pd42s or should I just shim them with the pd42 needles?
74 cb550
« Reply #23 on: December 20, 2013, 10:03:46 AM »
I like the shims.  Its easy.  2 shims is about 1 clip position.  Allows for a 1/2 step if needed.
Offline KrautKoffin
« Reply #24 on: December 20, 2013, 11:25:44 AM »
I used the adjustable needles for shats and giggles, I can always switch back later if they don't work out. The 42s are stamped 15A and the 41s are F2051E.
74 cb550
