Author Topic: 1975 CB550K1 - Stock-ish Restomod - More Mods  (Read 210700 times)
Offline Blackfin5
Re: 1975 CB550K1 - Stock-ish Restomod
« Reply #100 on: June 12, 2014, 06:27:40 AM »
Original, but upgraded - very nicely done.  It looks like you just uncrated a 2014 CB550.  I like it.  Let me know if you ever ride through the S.D. back country.
« Reply #101 on: June 12, 2014, 06:49:03 AM »
Thanks. I wanted the bike to retain its stock character since my other projects embrace more modern upgrades. I've been up Palomar and Julian a few times. Great roads.
« Reply #102 on: June 12, 2014, 08:35:14 AM »
Re the oil pan o-ring, I have found those new Honda O-rings have become thinner over time (valve cover, breather cover, oil pan etc.) I bought some replacements from 4into1.com and found the cross section is thicker. I have always been true to Mother Honda for OEM replacement parts but I was about to make my own cover O-rings when I discovered these guys. Their prices seem good and they shipped quickly.
« Reply #103 on: June 12, 2014, 12:27:55 PM »
Bummer.  They are out of stock on the rubber o-ring gasket!
« Reply #104 on: June 19, 2014, 04:25:06 PM »
The brake calipers needed new seals.  Although they were new from Godffrey, they managed to be leaking after installation.  New Honda OEM seals and repainted calipers (since the brake fluid ate some of the paint off).
« Reply #105 on: June 22, 2014, 05:31:38 PM »
They're more fun when they run.
I took the 550 for a ride over the South Bay bridges into San Pedro.  She ran like a champ with the new idle jets.  I only wish she had as much power as my 836 with that lighter 550 weight.  Unfortunately, on the turn around, the bike started fluttering and missing.  I pulled off to one of the port exits (off the bridge) just in time for her to sputter and stall.  There was plenty of juice in the battery, and the starter was working fine -- just no spark.  I checked and reconnected all of the wiring connections to the Dyna 2000 box, the coils, the plugs, etc.  Nothing was loose.  I ended up getting a flatbed tow home.
I let her rest a couple of hours and then she started again, but after running about five minutes the same thing happened.  It's almost like my Dyna ignition is overheating or something.
Suggestions??
image_zps8f469c9d by Donald Leonhardt, on Flickr
« Last Edit: July 05, 2017, 10:30:23 AM by SOHC4 Cafe Racer Fan »
Offline Tews19
  • I am no
« Reply #106 on: June 22, 2014, 07:48:32 PM »
I have read the dynas will take a #$%*. I would call them up. Tell them you did troubleshooting for other issues and everything points to the Dyna. Maybe put the points plate back on and see if the problem is still there.
1970 Honda CB750 survivor.
« Reply #107 on: June 23, 2014, 12:25:16 AM »
I will have to do some more troubleshooting to see if the Dyna took a dump. It's a brand new unit with maybe a few hundred miles on the clock.
« Reply #108 on: June 23, 2014, 04:08:59 AM »
How long did you ride before it ran into trouble? I'm just wondering about the tank vent, inline gas filter??, fuel issues first. If you rode it any distance first then likely not.
I have had my issues with the D2K's. If we were closer I'd send a box & trigger plate for you to try. As suggested you can install a points plate to know for sure.
Offline flatlander
« Reply #109 on: June 23, 2014, 05:34:38 AM »
keeping an eye on this... interested to find out if this is due to the dyna2000 or something else.
« Reply #110 on: June 23, 2014, 07:55:34 AM »
After the latest round of tuning, I rode it about 40 miles.  No apparent fuel issues.  It started as a "miss" issue with noticeable power loss and bogging. At first, I though it was a loose wire to one of the coils or the plug wires, since it felt like I lost two cylinders.  Then as I pulled off the road, it felt and sounded like I lost the remaining cylinders into a stall.  I couldn't get the bike to fire.  I pulled and reconnected the wires to the Dyna box, to the coils and to the plugs.  No joy.
After a few hours of non-running, I fired the bike straight up but after five minutes of running the same thing happened.
The starter motor is working fine too.
I've never had a Dyna crap out on me on my 750, even when riding in the heat here in Southern Cal -- and yesterday was not hot, either.  This Dyna unit maybe has a few hundred miles on it.
« Reply #111 on: June 23, 2014, 08:59:48 AM »
Dyna 2000, Dyna suppression wires and Dyna coils.
Rick's regulator/rectifier, in a spot where it gets plenty of ventilation.
« Reply #112 on: June 23, 2014, 10:16:38 AM »
If it was a coil, it would continue to run on the opposite two cylinders. I have had two separate issues with these crank triggers. In both cases the bike idled fine on all four but wouldn't rev past 5500 or so. This is obviously a different issue but could still be ignition.
When it happened the second time was there spark at the plugs? I'm sure you're all over this, but try it again & when it stalls check for spark.
I have seen goofy things happen with fuel lines breaking down and blocking flow, so if there is actually spark after it stalls you'll have a new avenue to follow. I've been frustrated with fuel line the last while, maybe it's junk line, possibly ethanol.
« Reply #113 on: June 23, 2014, 12:57:01 PM »
No spark. After cooling overnight, it fired but was dead missing on a cylinder. Fuel is running fine. Then another cylinder misses after more running and eventually a stall. Then no spark.
« Reply #114 on: June 23, 2014, 01:10:19 PM »
Better call Dynatek.
« Reply #115 on: June 23, 2014, 02:01:03 PM »
Yep. Hopefully they will stand behind their product.
« Reply #116 on: June 23, 2014, 05:49:32 PM »
They will know the manufacturing date but not how many hours it has run! (that was my problem  :P) Hopefully you didn't but it three years ago otherwise they should look after you. It doesn't happen overnight however.
« Reply #117 on: June 24, 2014, 09:41:46 AM »
I bought it in December so it still falls under the 1 year warranty (and I have a proof of purchase) so hopefully Dynatek will just replace it.
UNRELATED QUESTIONS:  What year did Honda switch to longer fork legs on the 550?  My 1975 fork legs are too short to fit both a fork brace and fender.  I've heard that in later years, the fork legs are longer and provide more clearance so you can fit both.
« Reply #118 on: June 24, 2014, 11:12:04 AM »
Just got an answer on the fork legs in the sohc/4 bikes forum.  It looks like Honda changed the length of the 550 fork legs with the 1977-78 models.  This seems to make sense, because they changed the frame passenger peg mounts, the gas tank, upper dash and carburetors.
« Reply #119 on: June 24, 2014, 03:46:35 PM »
Yes & the 77-78 750K forklegs interchange.
« Reply #120 on: June 25, 2014, 07:13:25 PM »
Electrical issue debugged!!!  Not a Dyna failure, but apparently a faulty ground wire.  Enough of a ground to run intermittently but fail.  When I last started it, it just ran like crap.  Jay at Lossa diagnosed and fixed the bad ground wire and the bike was instant gold.  I'm not sure why it behaved to make me think it was an overheating issue, but I'm glad it's fixed.
« Reply #121 on: June 25, 2014, 08:20:18 PM »
Yahoo! Its funny how many issues with these old bikes are in fact, ground(ing) problems. My re-wire took 2.5x as long due to improper grounds. Once corrected, well, golden!
Jay seems to be a very cool dude to take time despite their celebrity. Must be nice to have them, and others alike, so nearby.
Definitely.
Offline Blackfin5
« Reply #122 on: June 25, 2014, 08:36:49 PM »
Me too.  Against my better judgemeny I just picked up a Dyna 2000 kit.  Byzz assured me that the new units are "99.5%" fail safe and that the "forums" only rage about those 0.5%.
Let us know.
« Reply #123 on: June 25, 2014, 08:39:08 PM »
Let us know.
Blackfin,
Nothing wrong with my Dyna 2000. See above.
Offline Blackfin5
« Reply #124 on: June 25, 2014, 08:40:41 PM »
Ooops.  Should have read to the end.  Ground wire.
Again - nice bike!
