Author Topic: 77 CB592 CR!  (Read 15154 times)
Re: 1977 CB550SS Orange Caferacer!
« Reply #25 on: May 07, 2014, 03:37:23 PM »
Nice work on the notched brake lever.  I'm not sure if you will gain any appreciable speed with those holes in the rear brake lever!   ;)
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #26 on: May 07, 2014, 07:20:34 PM »
Well done!
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
Offline Roar
« Reply #27 on: May 08, 2014, 03:33:58 PM »
Ha ha! I think you may be right, but I like the look!  ;)
Well done!
Thank you, Decaff!  :)
1977 CB550SS Caf Racer
Offline Roar
« Reply #28 on: May 11, 2014, 03:08:20 PM »
Had a little ride today and the bike feels good on the road and corners really well. I guess it will be even better with the forkbrace in place.(it is on the way)
I have some carburetor work to do however.
« Reply #29 on: May 11, 2014, 04:02:40 PM »
Looks good.  What fork brace did you get?
« Reply #30 on: May 11, 2014, 05:05:28 PM »
Can I be dumb for a second?  What's the deal with the taped X on the headlight?
Offline Roar
« Reply #31 on: May 11, 2014, 11:59:20 PM »
Thanks! I ordered a Tarozzi fork brace.
Racing cars and bikes in the old days were the inspiration. They taped the lights so the glass would not shatter all over the racetrack in case of a crash.
I taped it at the start of the project for inspiration, and it kind of stuck...;-)
« Last Edit: May 12, 2014, 12:02:24 AM by Roar »
« Reply #32 on: May 12, 2014, 07:28:21 AM »
I've seen plenty of taped up lights and signals at track days but you have to fully cover the glass and plastic with tape.
I think I've seen some vintage race track photos with the x - come to think of it.  I'm not a hipster so some of those things fly over me. ;)
Offline flatlander
« Reply #33 on: May 12, 2014, 08:02:08 AM »
you're not dumb. just not hip.
if that's of any consolation  ;)
« Reply #34 on: May 12, 2014, 09:31:19 AM »
I lost being cool after turning 40 a few years back!  I had a couple of hipsters come up to me and check out my 750 cafe bike in Venice, Cal.  One said, that must be a girl magnet.  I laughed and said it's anything but -- and only a gearhead magnet.  I told him my better half seems to think it's alright.  Frankly, I think she likes my stockish 550 better, and a good thing because that's the only one with a 2-up seat.
Offline Roar
« Reply #35 on: May 19, 2014, 12:44:57 AM »
So, I have noticed an increasing amount of blueish smoke coming out of the exhaust when warm and idling. Thats not good..... I was hoping to ride the bike this summer and overhaul the top end in the winter. I realize this has to be handeled ASAP! Probably valveseals and/or piston rings...?
« Reply #36 on: May 19, 2014, 04:27:37 AM »
Sorry to hear that.
BTW - how do you like your Avon tires?
Offline Roar
« Reply #37 on: May 19, 2014, 08:44:29 AM »
Sorry to hear that.
I love them! They are very grippy and give good feedback!
Certainly an indication of oil being burned, but until you know whether it's top end or lower end, don't get too rattled.
Have you done a compression check yet? A leak down test? Are the valves adjusted properly? How badly does the engine smoke at WOT?
If it is only the top end, you could get a second head that is either good-to-go and run it while you rebuild yours, or vice-versa. If the amount of oil being burned is not so significant, then run the bike, top the oil regularly and rebuild over winter. As you remove the head during a rebuild, you'll undoubtedly go farther into the engine anyway.
I am going to get a compressiontester tomorrow and check. The valves are adjusted, yes.
I dont see smoke in the rearview mirror when I ride at full throttle, it seems to get worse when it idles. That said, it is drops of oil on the wheel and on the rear cowl after a ride.....
I have to buy a gasket set!
Thanks for replying guys!:-)
Offline LMN
« Reply #38 on: May 19, 2014, 09:31:36 AM »
Great work Hvermansen ;)
Keep us posted when you start working on the engine
Lars Magnus
CB500 K0
Offline Roar
« Reply #39 on: May 19, 2014, 02:37:21 PM »
Thank you! Will do! :)
Offline CB550moseby
« Reply #40 on: May 19, 2014, 11:43:26 PM »
Kul sykkel Hermansen! Har fulgt med på CR siden på Facebook også:)
Hva slags eksos har du og hvor kjøpte du den?
Keep up the good work. A true inspiration for us fellow Norwegians!
Offline Roar
« Reply #41 on: May 20, 2014, 12:14:11 AM »
Thanks!
The exhaust is Yoshimura replica from Carpy, bought on ebay. Ceramic coated by Fiske in Norway.
Looks and sounds brilliant!!  ;)
« Last Edit: May 20, 2014, 12:16:25 AM by Roar »
Offline Roar
« Reply #42 on: May 20, 2014, 12:23:33 AM »
Got a package from DCC, Tarozzi forkbrace installed!
« Reply #43 on: May 20, 2014, 05:38:39 AM »
Looks good, I need one!
Offline Roar
« Reply #44 on: May 20, 2014, 12:00:35 PM »
The results are in.....
Procedure:
Bike warmed up, plug out, choke off, full throttle, push startbutton untill the needle stops moving.
What say the experts?
Offline Roar
« Reply #45 on: May 21, 2014, 05:02:40 AM »
That bad, huh? ;)
Offline CB550moseby
« Reply #46 on: May 21, 2014, 01:34:46 PM »
Looks really good Roar!
What was the final price to Norway, if I may ask
Offline Roar
« Reply #47 on: May 21, 2014, 02:40:05 PM »
Ble vel rundt en tusenlapp tenker jeg, kostet 99$ på DCC +frakt +moms.
Offline Roar
« Reply #48 on: May 21, 2014, 03:33:00 PM »
you dead certain about the results of #1? Seems a very large swing...
Its obvious that you're headed for some rebuild... I'd re-run the compression test but this time, squirt some oil directly into the cylinder just prior to test. This may increase the results giving you a better indication if the problem is top or bottom end.
I tested all cylinders 2 times and nr1 cylinder 3 times because of the high result. Could it be that oil is dripping down through the valveseal making compression higher?
If oil is dripping down it would make the same effect as squirting oil in the cylinder and get higher compression...?
Offline Roar
« Reply #49 on: May 25, 2014, 08:43:50 AM »
I took a little ride to get it varmed up.
Then i took a compressiontest
Here are the results. First line is the test I took the other day, warmed up by idling only. The rest is from today.
Does anyone have an opinion...?  :)
