Author Topic: 1975 CB550 won't start ** now rev's too high  (Read 2406 times)
Offline cnd_guy
« on: September 13, 2014, 03:54:31 PM »
Hey guy,
Finally got the bike back together and now it won't start.  The starter will turn the motor over but it seems like there is no spark.  Here is what i have done to the bike:
Gas Tank - repaired and sealed
Petcock - cleaned (checked and fuel does flow thru)
Carbs - cleaned, new jets, gaskets, bench synced.  There is fuel in the bowls
New plugs, oil and battery.
The bike ran before i left it for 10 years, not sure why it wont turn over.
I'm pretty green when it comes to bikes but if you talk slowly like I'm a 5 year old i could probably figure out what to do.
Thanks
« Last Edit: June 19, 2015, 09:02:30 AM by cnd_guy »
1974 CB550 Four
Offline cnd_guy
Re: 1975 CB550 won't start
« Reply #1 on: June 19, 2015, 09:01:54 AM »
New issue with the bike.  I was able to get it running.  It would start great and idle nicely (1100 rpm).  I took it to the mechanic to finish the safety and it passed.  While talking to him he said that the idle is broken and that the engine rev's too high.  I was confused bc when i left the bike she was purring like a kitten.  I went to start the bike to drive home and sure enough she reved up to 3000 rpm's without even touching the throttle.
I'm super confused, the carbs have been rebuilt and sync'd, new throttle cables, it was running great, what's happened to my bike? lol
1974 CB550 Four
Offline Tews19
  • I am no
Re: 1975 CB550 won't start ** now rev's too high
« Reply #2 on: June 19, 2015, 10:12:19 AM »
What did the mechanic do to the bike? Idled fine and now the idle is broke? Does he mean the idle screw is broke?
1970 Honda CB750 survivor.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: June 19, 2015, 10:51:42 AM »
He broke it... he should fix it!
--Evan
1975 CB750K "Rhonda"
Offline harisuluv
« Reply #4 on: June 19, 2015, 10:53:53 AM »
sometimes the high idle symptoms start after the bike is warmed up/hot.  if you just got it running for a bit yourself, then you might not have even known about it.
Offline evanphi
  • Apparently I'm an
« Reply #5 on: June 19, 2015, 10:58:03 AM »
Ride around for awhile to warm up bike, then lower the idle speed.
--Evan
Offline cnd_guy
« Reply #6 on: June 19, 2015, 11:00:05 AM »
@evanphil
That's exactly what i've done, it's better but not totally fixed.
As always, thanks for the responses guys!
1974 CB550 Four
Offline DaveBarbier
« Reply #7 on: June 19, 2015, 07:33:58 PM »
He said, "the idle is broken?" What the hell does that even mean? Does it fluctuate or once warm does it stay at 3k steadily? Check for air leaks?
1978 Honda CB550K
Offline cnd_guy
« Reply #8 on: June 22, 2015, 02:13:47 PM »
It does fluctuate, how do i check for air leaks?
1974 CB550 Four
« Reply #9 on: June 22, 2015, 02:21:54 PM »
i agree the bike should be returned to the owner in the same condition.
sounds like a vacuum imbalance....when was the last vacuum sync performed?
Offline harisuluv
« Reply #10 on: June 22, 2015, 04:36:13 PM »
Just search for vacuum leaks, there are many ways to do it.
So what the heck does the idle is "broken" mean.  Can you please elaborate on this?  Or at least elaborate on what your mechanic told you?  This word is so vague, it really tells us nothing save for you have some kind of issue with your idle?
Offline cnd_guy
« Reply #11 on: July 01, 2015, 09:24:44 AM »
First: the mechanic in question is just the guy who's filling out the safety inspection for the bike.  He doesn't work on the bike nor repair bikes.
Second: the bike was reving at 3000 rpm after the inspection.  I was able to adjust the idle screw and now it's much better, reving at 1200 rpms.
I had it out today and i noticed that while riding at approx 4500 rpms it starts to sputter/lose power.  I'm guessing that the carbs need to be synced and checked for leaks.
Btw it was AWESOME to get out for a ride.  It's been 14 years since i rode her last.... legally lol!!
1974 CB550 Four
Offline Vinhead1957
« Reply #12 on: July 01, 2015, 01:46:25 PM »
Those pesky orings on the intake manifold!
Offline cnd_guy
« Reply #13 on: July 01, 2015, 02:51:42 PM »
That's what I'm thinking!!
1974 CB550 Four
« Reply #14 on: July 01, 2015, 02:59:56 PM »
this is the transition between pilot jet needle jet and main jet.
recheck and clean these....especially the emulsion tubes.
Offline eigenvector
« Reply #15 on: July 01, 2015, 04:28:43 PM »
Yeah, my thoughts exactly.  The mains need to be scrubbed down.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline cnd_guy
« Reply #16 on: July 02, 2015, 04:36:56 PM »
Okay, thanks guys!
1974 CB550 Four
Offline Deltarider
« Reply #17 on: July 03, 2015, 01:44:42 AM »
Before you go at the needles and their jets (which has become almost a folklore here in this forum) I suggest you first ride a tank empty with some stuff added (here we have Forté and Tunap, I believe overthere it's called Seafoam). Easy to do. Make sure you ride with all possible throttle openings. My experience is that, if there still are openings, such an additive can help. If it's clogged up, sensitive hands are needed and NO materials that can damage. I would use stranded copper wire which is just a bit softer than brass.
« Last Edit: July 03, 2015, 01:46:48 AM by Deltarider »
CB500K2-ED Excel black
