Author Topic: My 1976 Cb750 Cafe Build  (Read 9708 times)
Offline SOHC
Re: My 1976 Cb750 Cafe Build
« Reply #25 on: December 23, 2014, 03:44:48 PM »
Fellow Minnesotan here, nice work so far, and i understand the heater not working, i havent gotten my new furnace installed in my garage yet, and i really need to lol. what part of MN do u hail from, I'm down here in SE MN.
Current:
1979 Honda CB650 (Hardtail Build)
1983 Suzuki GS850L (Fix and Minor Restore)
Old:
1989 Suzuki Katana 600
1978 Honda CB400T "Hawk"
1983 Honda VF750
Offline Kustomizer
« Reply #26 on: December 23, 2014, 03:51:50 PM »
Yeah, the stupid heater is still being a pain.  I'll have to get it serviced.  I'm from Lakeville, a south suburb of Minneapolis.  Nice to know there are few locals on here.
Offline Kustomizer
« Reply #27 on: December 27, 2014, 07:51:46 PM »
Got the wheels torn apart, ready to be blasted and painted.  Ordered new spokes and I'm going to give re-lacing a shot, a little nervous about that.
« Reply #28 on: December 27, 2014, 09:30:06 PM »
Ok, I need to know what the switch in the clutch handle is for?  Can I remove it and if I do is there something I need to do to the wiring?  Because the wiring is cut and messed up in my stock clutch lever and because I'm not running wires in the handlebars and would have to try and modify it anyway I'm going to replace it with an aftermarket switch and clutch lever, but I first need to know what to do about the clutch switch in that lever.
That is/was the "Clutch Safety Switch" that prevents the electric start from operating unless you pull in the clutch lever (if in gear) or else the bike must be in Neutral. To avoid all that claptrap, just unplug the Safety Module under the left side cover and jumper the Grn/Red wire there to the Green in the harness connector. Or, go simpler yet and connect the Grn/Red wire from the Start solenoid to the loose Green dangling under the left cover, and still remove the Safety Module. Or...(I have a bunch of options!). You can see how this stuff all works together in my book.
Offline Kustomizer
« Reply #29 on: December 27, 2014, 09:42:03 PM »
Thanks  for the info Hondaman, I'll pick up a copy of your book too first chance I get.
Offline Nuffsa Fugginnuff
« Reply #30 on: December 28, 2014, 07:48:10 PM »
Subscribed
Alcohol & explosives, the key to a lasting relationship.
Offline Chad
« Reply #31 on: December 28, 2014, 08:10:49 PM »
Subscribed. I wanted to get new wheels (rims & spokes) from Buchanans, but using stock rims, ordering spokes, and doing the work myself is SO much cheaper. You may inspire me to go that way.  :)
Offline Tree
  • CB750K5
« Reply #32 on: December 28, 2014, 08:25:22 PM »
subscribed.
« Reply #33 on: December 28, 2014, 10:07:40 PM »
I understand if you have budget constraints but if you can swing it, you might want to buy aluminum rims (Suns are fairly affordable). They are much lighter than the heavy stock DID rims. If your goal is to cafe the bike - not just in looks but in purpose - it will reduce weight.
Offline Kustomizer
« Reply #34 on: December 29, 2014, 08:13:28 PM »
Thanks for the info guys, I'll look into the the rims.  I'm not good with puzzles, so I hope I can figure out the pattern for putting the spokes back in correctly, we'll see.
Offline SOHC
« Reply #35 on: December 30, 2014, 05:24:33 PM »
Nice I was Born On the north end of the cities in Anoka. I have been thru lakeville many, many, many times haha.
Yeah its nice to know other Minnesotans, with similar hobbies, i met a few mustang guys on a forum, one i became friends with lives in Burnsville, your neighbor to the north.
GL with the build, i will stay tuned!
Current:
Old:
1983 Honda VF750
Offline Kustomizer
« Reply #36 on: January 02, 2015, 05:44:33 PM »
Got the engine painted and all the engine aluminum sanded and polished:
I put a couple of scratches in some of polished stuff when I took the motor out, so I'll hit all of that again after I put the motor back in.
Got the frame mostly blasted:
Taking it and the wheels, hubs and a few other parts down to my buddies body shop to blast them and get them ready for paint.
Offline Kustomizer
« Reply #37 on: January 21, 2015, 05:59:54 AM »
Got a few more things sanded and polished:
Carb bowls and caps:
Fork cases:
Next is the rear brake hub and then re-assemble the forks and then paint rims and frame.
Offline WhyNot2
  • I'm finally an
« Reply #38 on: January 21, 2015, 06:29:08 AM »
Great work......polishing is sooooooooo much fun, ain't it?
NOT..........but cool looking when done.....satisfying too.
Offline 750cafe
« Reply #39 on: January 21, 2015, 08:01:29 PM »
She is definitely going to draw a crowd where ever she goes. You should have warning signs handy stating Sun glasses required!  ;)   ;D
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #40 on: January 22, 2015, 05:45:28 AM »
I always laugh to myself as I guess where guys on any of the forums I'm on are from when they say Minnesota. Like 80% of the time they're from somewhere near the cities. I spent most of my life in Grand Rapids before moving to Bovey!  Most people don't even know where that is! haha. Lakeville is a nice area though. Far enough down 35 that the traffic isn't so horrible..  I lived in Burnsville for a while and I had to commute to Crystal every morning. That was horrible.
Awesome work on the bike, man! I wish I had a damn polisher in the shop. The stuff I've shined even slightly I had to do with tiny 1" polishing wheels on my dremel...  better than nothing I suppose.
Do you know anything about the health of the engine?  How many miles on it?
On the gauges... I ended up just pounding the studs out of place and then flipping the gauges to the opposite side to lower them a bit. That way I didn't have to fab any bracketry (I'm REALLY limited in my shop right now...no welder, no compressor (died), no grinder...)
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline Kustomizer
« Reply #41 on: January 23, 2015, 08:39:05 PM »
A dremel, wow, that would be a ton of work.  The 6" does a pretty good job for a cheap Harbor Freight buffer.  The bike has 18K on it and ran pretty good.
Offline Kustomizer
« Reply #42 on: February 15, 2015, 09:40:36 PM »
Got the frame painted:
And the wheels painted and laced:
Still have to true them, then I'll assemble the front forks and get it into a roller.
Offline Kustomizer
« Reply #43 on: March 22, 2015, 05:50:58 PM »
Ok, started putting things back together.  Put the motor in this weekend.
Offline Kustomizer
« Reply #44 on: August 31, 2015, 06:01:50 PM »
Ok, it's been awhile since I posted, but I did finally finish my project.  Took it for it's maiden ride today!  Here are a few pics:
Still have a few minor things to finish, but for the most part it's done!
Offline Kustomizer
« Reply #45 on: August 31, 2015, 06:03:17 PM »
A couple more:
« Reply #46 on: August 31, 2015, 08:12:50 PM »
She's a looker, Kustomizer. Very, very nice.
Is those foil decals on the tank and sidecovers or hand applied leaf?  I could not tell from the light in the photos.
Offline Kustomizer
« Reply #47 on: August 31, 2015, 08:53:19 PM »
Thanks!  Those are hand applied leaf applied by my friend Cliff Anderson.
« Reply #48 on: August 31, 2015, 09:49:13 PM »
Well done, Cliff (Claven)!  ;)  I'm a fan.
The paint looks great, too.  And I like how the taillight meets the cowl.
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
« Reply #49 on: September 01, 2015, 06:58:02 PM »
Great looking bike! Well done!
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
