Author Topic: 1977 CB750 K7 /// Rebuild 2.0, Project Anna  (Read 60876 times)
Offline mkoski
Re: 1977 CB750 K7 Rebuild into a Cafe Racer
« Reply #175 on: October 16, 2018, 03:36:34 PM »
Now, into the meat of the project. Over the weekend I tore into the engine, split cases, did an inspection of everything and have sorted things out. Take a look at this shifting dog!
https://imgur.com/JERPk6n
It's worn into the 4th gear (which engages first) by quite a lot, no wonder that first wasnt happy to stay in. I'll pull the gear later and take a picture of that as well. Other than that, the bottom end was just gorgeous. Clean, in tolerance, very little wear. The primary chain tensioner is supple still (somehow) and everything looks good. I'm going to simply replace the tranny parts I need to and close it back up and get into the top end next.
https://imgur.com/5I47e80
Very happy to be back here and working on my CB again. This is a great community and I love reading everyone's projects! I have some fun ideas for this time around and cant wait to try em out!
Offline mkoski
Re: 1977 CB750 K7 /// Rebuild 2.0, Project Anna
« Reply #176 on: October 17, 2018, 08:17:50 AM »
Member Bill Benton can probably hook you up with new dogs.
Thanks Cal! I sent him a message.
Turns out there is wear inside the groove of the shift drum on the right dog as well. The mating pins from 4th gear into 1st on the countershaft are really rounded off too from slipping out so often. Found a cheap parts engine in town so I might pick that up this weekend to open up in hopes of finding nice transmission bits. Probably worth the risk for an easy win with no shipping delays.
While the engine is pending I started working on the frame. Need to fix the rear shock mount tapped holes, install a frame kit for the cutout I have, install new bronze swingarm bushings and paint it! Should keep me busy until the the engine is ready to drop in when I get my parts sorted.
Offline mkoski
« Reply #177 on: October 17, 2018, 10:35:36 AM »
Hahah. My build pace has been really good lately! Partly from having a new shop (my work) that I can use and partly from better planning! That XL600R was built in 30 days, front to back, including the engine rebuild. Guess there are some advantages of being single and childless!
Offline mkoski
« Reply #178 on: October 23, 2018, 07:44:16 AM »
Ended up fairly busy this weekend but managed to get a few key items accomplished! Picked up what might be the ugliest engine I have seen but I was hopeful that the transmission would be okay.
https://imgur.com/wzPadRU
As I started stripping it I saw that it had both had a valve meet a piston top and it had thrown a chain through the case, which broke several pieces off. The PO had repaired the massive hole with fibreglass! Never seen that before. I ended up getting extremely lucky though and found a full transmission set and forks in near perfect condition! Just a bit of dirt to clean off and then I'll be buttoning my case back together this week.
https://imgur.com/vYEEgTQ
https://imgur.com/dbEOOhf
Besides that I made a frame kit to reattach my cut section of frame and I also epoxy-painted the frame and swingarm a nice, even black. Didnt snap any pics but I will next time I'm working on er.
Offline mkoski
« Reply #179 on: November 20, 2018, 03:20:11 PM »
Almost a month later! Jeeze! I have been crazy busy in the last while on not-my-CB750-things, which isnt ideal... But I ran across a really nice Bandit 650 for a low price so I fixed it up to make some money on it and I also ended up starting a custom-fit supercharger project for my car. Between that and work, time flies!
I have made some really great progress with my CB750 though! Old transmission - out. New transmission - in. Case put back together, all covers re-installed, engine painted, engine re-mounted to frame. Really really happy with how clean the engine came out to be!
https://imgur.com/ryfTtsZ
Going for brushed-aluminum look with a nice automotive clear-coat for the bits that arent black...
https://imgur.com/Mm3bz3c
And here's the final result!
https://imgur.com/Djy8KcG
Tonight I'm going to install my oil tank and fill er up. I'll cycle through with the kick-start I think until I have full circulation. Just want to ensure no leaks at this stage of the game. Then I'll be re-assembling the rear and front ends next!
Offline mkoski
« Reply #180 on: April 10, 2019, 10:00:58 AM »
After finishing a DIY supercharger and with the approach of summer, I'm back on the CB750!
I have put together the rebuilt engine, installed the front and rear ends and now I'm into the rest of the mechanical and electrical. Here is how she currently sits:
I am registered for a garage-built show at the end of the month, so I have three weeks to a polished, completed motorcycle.
The major changes that I am going to be making are to the tank and seat, adding knee-dents and re-shaping the seat. Besides that I'm going for a better fit and finish this time around (a few years after my first build of this bike now!) and even splurged on those gorgeous cognito moto rearsets and new rear suspension (everyone was right about the ride quality of the Chinese RFY's)!
Nice to be back working on the CB!
Offline mkoski
« Reply #181 on: April 15, 2019, 06:12:37 AM »
Spent some time this weekend on the bike, polished up the front caliper and clear-coated it, did the rear brake linkage in black, installed the electrical harness and started getting that going.
Looks like I'll have my headlight, turn signals, the stainless steel bolts for the entire bike and a few other finishing touches in this week. Hopefully I can get all the detail work done up by the weekend and then start on the body-work and paint for the seat, tank and side-covers! I'm excited to refine the profile of the motorcycle a bit more and make the seat something really comfy to be in. Right now it looks saggy and sad. Right now it's just sitting in place as I need to build a new seat pan out of aluminum.
Not a huge update but electrical is never a pleasure for me.
Offline mkoski
« Reply #182 on: April 22, 2019, 10:51:57 AM »
Well this weekend was a good one (and a long one here in Canada). I spent a couple days in the shop and got to add a bunch of parts that came in. I mounted up my headlight ears, the headlight (with a nice LED H4 bulb), the exhaust went on, got the electrical system working, added some nice progressive-style LED turn signals, finished wiring up the alternator, ran a few more misc cables and (my favorite) got a wireless push-button ignition system running. I used to have RFID installed but it took up a lot of space and this solutions is much more elegant and functional. One button press on, bike is ready to go, one press, its all off and disabled. Simple latching relay system (20$) that leads into an automotive 12V relay (4$). Now I dont need a keyed ignition and it keeps everything sleek.
I also got lower rear suspension, so I dropped the front just over 0.5" to level it a bit. By my calculations this should ensure that the front wheel doesn't contact the headers at all. That's probably important...
The tank, seat and sidecovers will be re-done to give a betting riding position and updated paint, as the old stuff is all scratched up now. Besides that, I need to mount the speedo/gauge and make a seat pan. Last, I need to mount the rearsets when they come in. Then shes done and ready to ride once again! Very excited!
Offline mkoski
« Reply #183 on: April 23, 2019, 01:12:54 PM »
Just a small question I wanted to ask you guys:
What is the most elegant way to attach cables to the lower forks? I used to use electrical tape with a zip tie over top but I think I have grown past that level of quality in my builds these days. I just need something secure, non-marking and low-profile for the front speedo cable and brake cable. Also my clutch cable I suppose!
On another note, just got my cognito moto rearsets. They are gorgeous! Almost cost as much as my bike when I first bought it hahah! Too excited.
Offline mkoski
« Reply #184 on: April 29, 2019, 02:01:06 PM »
More progress updates! Things are flyin along! Good thing too, bike is due Friday for the show!
Rearsets, check:
LOVE these things. Smooth as hell, beautiful shift feel, perfectly positionable, gorgeous. Worth the money!
Front gauge, brakes, cable maangement and wiring: Check
Ended up running the clutch cable below the headlight, much straighter line and it's smooth as butter now.
Tail pan with under-side brake and signal lights: Check.
A paper template, a hacksaw, sandpaper, a few hours. Happy with it, fits great. My clearance to the brake light isnt quite enough but I'll set the rear end stiff for now until I have time to suck it up a bit higher into the underside of the pan.
Points set, valve lash set, final wiring connected and managed, quick carb cleanout, final bolt check through the bike annnnnd shes a runner!  ;D ;D ;D Back to being the first kick engine she always has been for me! So excited! First gear feels very solid (transmission replaced due to it jumping out before) from a short indoor ride in the shop. It snowed 20cm this weekend in Calgary!
Tonight I am repainting the tank and side covers, starting on the seat template to carve it out.
Here's the design plan... A bit taller, farther forward (single-seat bike) to keep the visual weight of the bike even, build up the rear a bit and put the seated position into exactly where I actually sit.
Tuesday, finish and glass the seat. Apply my secret decal layout to the tank and covers.
Wednesday, finish the seat, sand, bondo, paint.
Thursday, if all is well, drink some beers! Maybe a once-over on the bike again, polish it up.
Friday, drop-off at the show!
A few minor odds and ends as well, registration, insurance, tail wiring, more cable management, charge the battery up and put a plate/tag bracket somewhere. The seat is top priority though!
Offline mkoski
« Reply #185 on: May 01, 2019, 01:44:07 PM »
Two days remaining!
Side-cover and tank are painted. Just need a good polish to even out some orange-peel from the clearcoating.
Had to bondo the emblem-mounting points to keep it smooth all the way around. Had a couple small dings to fill as well.
Started the seat shaping process. Happy with how it has taken form thus far. Tonight I'll shape the front and blend it into the tank, then cover and fiberglass it for paint tomorrow. Need to adjust the seat length I currently have as well, as it's too long with the pushed-forward seat design I went with.
Friday I'll have final pictures with everything done up!
Offline mkoski
« Reply #186 on: May 03, 2019, 08:01:37 AM »
Well, shes done! Again! Two frame up builds, one blown engine, one engine without first gear, another engine with a hole in the case to donate a transmission, a one or two casual hours in the shop  ;) and my bike is back to being ready to ride every weekend all weekend for the summer!
Here's the 'finished' seat:
If I had more time I would have refined it more, smoothed it out and not just laid thick paint to cover up as much of the imperfections as I could. That's what happens when you budget time poorly I suppose! Happy with the shape and the fit though!
I created some designs with decals and chose the one I liked the most, a big Honda wing across the tank to balance the black/gold ratio and a little 750 on the covers to give them some detail.
Last two items, velcro the seat to the seat pan, connect the tail lights up. I'll do that this afternoon before I drop the bike off at the show for the weekend.
Thanks again to everyone at this forum, I learned so much since I first bought this bike 5 years ago and it has sparked a huge interest of mine into automotive and motorcycle projects!
Offline rippen2wheels
« Reply #187 on: May 03, 2019, 09:12:25 PM »
Your bike looks great I like the changes you made, nice machine work too
« Reply #188 on: May 03, 2019, 09:41:17 PM »
Does someone want to second this bike as a nominee for BOTM? Do it in the following thread:  http://forums.sohc4.net/index.php/topic,176614.0.html
« Reply #189 on: May 16, 2019, 10:55:29 AM »
Bump!!
« Reply #190 on: July 18, 2019, 02:29:25 PM »
mkoski,
Congratulations! You're bike has been nominated and seconded as a candidate for a future Bike of the Month.  Please post that you "accept" the nomination in the following thread so it can be eligible for voting:  http://forums.sohc4.net/index.php/topic,176614.0.html
Don
Offline CarbonK
« Reply #191 on: August 10, 2019, 05:37:47 AM »
Nice bike, I got the same tank decals on my 550.
