Author Topic: 74 CB750K A Bike For My Pops  (Read 11228 times)
Re: 74 CB750K A Bike For My Pops
« Reply #25 on: January 21, 2015, 08:33:19 PM »
What's with the Saran Wrap -- protective against fingerprints or some layer of minimal protection against dings/abrasions?
Offline FridgeRaider
« Reply #26 on: January 21, 2015, 08:51:47 PM »
 ;D The thought was to try and keep polishing/media blasting dust off of it for as long as I could.
1972 CB750K2 Resto-mod (836cc Upgrade) - http://forums.sohc4.net/index.php/topic,161782.0.html
« Reply #27 on: January 22, 2015, 04:25:29 PM »
Since day 1, the bike didn't want to roll when in gear with the clutch pulled in. This issue was always in the back of my mind and on my checklist of things to troubleshoot. With the front end of the bike buttoned up (for the most part) and a replacement clutch handle in my possession (original was broken), the clutch was up next. I originally figured that after sitting so long with the oil drained that the friction plates had simply fused together. I was correct, but had a little extra surprise to go along with it.
Blue RTV silicone is always a sign of PO modifications to come:
No surprise here, friction plates were dried out and stuck together:
The surprise:
Previous owner apparently lost the 4th bolt for the lifter plate/clutch springs and decided to instead use a bigger SAE size and jam it in sideways. This effectively ruined the threads and I'm honestly surprised it didn't crack the lifter plate to boot. So now I get to go on the hunt to replace the stripped base plate. Luckily Stev-o lives right down the road from me and said he might have something stashed away in his batcave.
This was his answer:
Stev-o is an exceptional guy but I think I have him in the looks department.  8)
From the the two sets of friction plates and an entire clutch assembly, I was able to hand pick the parts still in spec and install them in the bike. I wish I could say it was easy to do but ended up being a 4 hr+ job. The base plate in the clutch basket didn't sit flush at first and it ended up being a couple mm short for the clutch plate. Finally figured it out and got it installed correctly.
Clutch plate polished with new SS fasteners:
« Reply #28 on: January 22, 2015, 04:57:50 PM »
Ha!   Glad it worked out for you, want to see this on the road when you are done with it.
Offline Brittreynolds93
« Reply #29 on: January 22, 2015, 07:24:54 PM »
I can vouch for others who are curious, you are quite the handsome man FridgeRaider
« Reply #30 on: January 23, 2015, 07:43:18 AM »
Take a girl on a motorcycle ride and look at the results, I should have gotten one a long time ago  ;D
I'm hoping to get it running before my return to Florida, even better if I can get it on the road to Austin for a visit. The full engine tear down and M-unit install is on hold till I can set up shop with my dad.
« Reply #31 on: January 23, 2015, 09:14:06 PM »
Let's be honest, you just got lucky with me! Also don't pretend that you only took me on your motorcycle once.  ;)
Now get to work on that beautiful motorcycle
« Reply #32 on: January 24, 2015, 03:07:12 AM »
All of a sudden, I feel like an awkward third wheel!
« Reply #33 on: January 25, 2015, 03:56:39 PM »
And then some, Stev-o. Didn't realize it had flipped from SOHC to eHarmony overnight!
Saves me the trouble of joining eharmony   8)
Yes ma'am!
I forgot to mention in my previous post that I followed HondaMan's clutch basket modification and drilled 8 holes total as opposed to the 4-6 he suggests. Thanks again to Stev-o, I do have an extra clutch basket if that turns out to be a little to much modification. I'm still trying to figure out what after market friction plates were put in the bike. I believe OEM Honda were small straight cut (those were the ones I put back in) and the later ones were slanted cut. The friction plates I pulled out were straight cut into quarters. Any idea who makes those?:
This is a great walkthrough by 72hondacb750 for rebuilding oil pump & countershaft oiler:
http://forums.sohc4.net/index.php?topic=78643.0
I replaced the O-rings as well the oil stopper seal (provided by Elan). The original stopper was still pliable and in good shape so I saved it for a rainy day.
O-ring in the countershaft oiler was replaced as well. The four screws were a PITA and took at least an hour because I stripped everyone of them even with my impact driver. New fasteners were a must:
« Reply #34 on: January 27, 2015, 06:24:26 PM »
Why can't rebuilding carbs ever be easy  :-\
The carbs aren't anywhere near the worse I have seen/dealt with, outside is grungy with minimal old gas residue in the float bowls and jet passages. I guess I wasn't paying attention when removing the slow jet on the #2 throttle body because the top portion was unknowingly cemented in the passage and I managed to torque it in two. I ended up having to drill it out, I believe I got it all out but I cant be 100% sure. I can spray carb cleaner through it and thread in one of my still good slow jets. Best case scenario is I have to source out a new 40 Slow Jet, worse case is I have to replace the whole #2 carb body.
Another learning experience is unlike the carbs off of my CB550s and later style PD carbs, Honda staked in the linkage rod which I should have drilled out before fully disassembling.
Currently dipping the parts in Berryman's chem dip and will finish the outside of the throttle bodies with soda blasting.
« Reply #35 on: January 30, 2015, 11:16:29 PM »
I decided to take a break from the carbs until I figure out how I should proceed with them and got the entire rear end disassembled:
All new rubber parts were bought a while back in anticipation for this step in the restoration from http://www.vintagecb750.com/ (except passenger foot pegs, they were out of stock  >:()
Both front and rear foot pegs got a home powdercoating from yours truly in super gloss black and the original fasteners got a quick shine. The result is probably one of my favorites for the bike so far because it cost me next to nothing and looks absolutely top notch.
I have always had mixed feelings about the rear shocks. I know that popular opinion for them is that they have been the weak link (performance wise) since Honda rolled them off of the factory floor. Many suggest upgrading to Koni, Ikon, Progressive Suspension, and others for better performance and handling but those come with a hefty price tag. Even still they don't have the stock look that I want with my restoration(ish). I decided that I would try to see how well the original shocks cleaned up before shelling out a good portion of my budget for aftermarket shocks. Here's one of the rusty shocks ready for disassembly:
I was all ready to make a spring compressor similar to the one in the Honda workshop manual until I was digging around my buddy's tool cabinet for a drill bit and came across his custom bearing puller (ends were grinded down to fit narrow openings). It ended up being exactly what I needed. Word of advice: set the shock to the lowest compression setting before compressing the spring (you would think this would be obvious but I didn't realize until after I had them disassembled that I could have made it easier on myself):
40 years taking it's toll:
The shields are rust magnets, before pic:
After media blasting the insides (blue painters tape to protect the chrome for any wayward slag):
It's hard to believe that this is the end result after cleaning the rust off (more proof Quick-Glo works under the right conditions) and polishing the parts up:
Final conclusion: With the exception of minor imperfections the shocks now look almost NOS. I'm still open minded for arguments towards upgrading the rear shocks but I highly doubt that my Dad will push the bike past the ability of the stock shocks to warrant losing the original look and the accompanying price tag that goes along with them.
Offline Restoration Fan
  • My wife will never call me
« Reply #36 on: January 31, 2015, 05:43:10 AM »
Love the way those shocks cleaned up!
The good thing about your approach towards keeping the original shocks is that the shocks area very quick and easy piece to replace if you do decide to upgrade.
Great job with the bike.  I'm really enjoying all the photos of the progress.
« Reply #37 on: January 31, 2015, 07:35:46 AM »
Cosmetically, they look great, but they are still 40 year old springs.
« Reply #38 on: January 31, 2015, 11:10:49 AM »
Thanks! I've been following your build from the sidelines, anxiously waiting to see the engine back in the bike and running!
40 year old springs on a 40 year old bike  ;)
What are my alternatives that don't break the bank? I have a pair of cheap EMGO shocks sitting in a drawer collecting dust but they are bulky and longer than stock. They wont work for my vertically challenged father. This thread here http://forums.sohc4.net/index.php?topic=27343.0 is a tad bit old but andy750 has a similar mindset as myself on the matter.
« Reply #39 on: February 04, 2015, 08:09:03 PM »
As with the front, the rear wheel got a full rebuild. I switched out the bearings with a new kit from All Balls and replaced the old sprocket with a 48 toothed one from JT. The rest of it got a good polish.
Buying all new SS spokes from Buchanan's would have been nice but I decided long ago to just spend the extra time on the old spokes. Plus it seems that some members are having fitment issues with them in rear hub (granted I think it's with the later year hubs).
Trying to remove the casting marks from the inner portion of the rear hub was an absolute pain and I still didn't get it all sanded out! It still looks good though! Lacing and truing went fairly smooth but I didn't run into a problem until I got to putting the new rubber on. The IRC motorcycle tube I bought to use was for tire sizes ranging from 4.00 to 5.10, which meant that it was within limits but still on the large size for the 4.00-18 Roadrider. I think this was a big factor in me pinching a hole in the tube when working the tire onto the rim. I sat there for a good 10 mins in denial trying to inflate it.  :'(
The big powersport dealership in town had a tube more in the range I needed.
« Last Edit: February 04, 2015, 08:15:30 PM by FridgeRaider »
« Reply #40 on: February 11, 2015, 12:19:19 PM »
Next up: Changing the grease zerks in the swing arm bolt to a more modern one that fits an American style grease gun. My swing arm bolt had the earlier style press in grease zerks so it required me to tap new threads. Honestly this modification was fairly easy despite my lack of experience. Here's a list of things needed:
  • Irwin Tools 2727- 3 Piece Set - 6.0 mm - 1.00 mm
  • Schroder 4.006.4 Ratcheting 1/4-Inch Tap Wrench, 3-1/2-Inch Long
  • 6mm Assorted Grease Fittings Set (cheaply sourced from local auto-parts store)
  • 5mm Drill Bit (I substituted a close equivalent SAE sized one)
  • Cutting Fluid (helpful but not 100% necessary)
  • Blue loctite
I decided to keep it metric, mostly because I can reuse the 6mm tap set on other parts of the bike. If I had used a 1/4" tap, it most likely would have just collected dust in a drawer. After practicing on a couple of times on scrap piece of metal I had the confidence to tackle the swing arm. I don't have access to drill press (that would have been nice) so I put the bolt in a vice and eyeballed the drill bit straight. In hindsight I should have put a piece of tape on the drill bit for a visual for maximum depth because before I realized it, I was quite a bit deeper than I needed it to be. Next up was to use the tap set to cut the threads. I didn't have any cutting fluid on hand so I just used some of the assembly lube I used earlier for the front brake, it worked well enough. Steady torque and backing the tap out a bit after every 1/4 - 1/2 turn was the key.
The bolt liked to turn with the tap so I had to rig it to stay in place. This was my solution so it wouldn't be marred by the vice:
Once the threads were tapped, I sprayed out the extra metal filings with some carb cleaner (I had previously cleaned the grease passages out with a Q-tip). Last step was to put blue loctite on the new 6mm grease zerks and gently screw them into place. Here is the finished piece, read to be installed and pumped full of grease.
« Reply #41 on: February 14, 2015, 09:34:53 PM »
Making progress and giving myself a mild heart attack in the process. The swing arm is too big for my oven so I had to forgo giving it a powder coating, I did however replace the stock OEM bushing with brass ones from ebay seller "kenosha_kid". Great product for the price and surprisingly fast shipping considering it was coming all the way from Germany.
I was playing around with my new grease gun and the swing arm bolt when again inexperience got the best of me. I didnt quite understand how to remove the grease gun from the zerk after done pumping grease into it (simply unscrew the tip to release pressure). While I was trying to separate the two, I snapped the zerk in half:
For half a second all hope was lost and I considered abandoning ship. Good thing for my sanity the fix was simple, all I had to do was grab a small EZ Out and the broken fragment I had Loctite'd in place unscrewed itself out. A new grease zerk went back in and now I have real world knowledge on how fragile these things are.
This is the high pressure grease I'm going with:
« Reply #42 on: February 19, 2015, 09:54:23 PM »
I've been busy squaring away the rear of the bike. The underside of the rear fenders got the same Caswell coating treatment as the front fenders, rims, and tank did. Hopefully they will all stay rust free for another decade or two.
As per the suggestion of Hondaman in his book, I purchased a Diamond Powersport 530 chain. I purchased the 100 link based on the fact that the original chain count was 100. In hindsight, I should have bought the 102 link one instead. I find the 100 ct. is about as short as you could physical use on the bike and pulls the rear axle forward of the first adjuster notch on the swing arm. This in turn makes me have to choke up on the rear brake actuator to get it to engage. I later found out that it is suggested purchasing the 102 ct. for this exact reason, here's a thread for reference http://forums.sohc4.net/index.php?topic=77514.0.
And it's a roller:
« Reply #43 on: February 19, 2015, 10:03:45 PM »
Looking good!
« Reply #44 on: February 24, 2015, 08:35:26 PM »
Looking good!
Thanks! Sad news is that I wont be getting it running before I move back to Florida like i had planned (ultimately my choice). This is why:
The mess of a stock wiring harness. The electrical parts of the bike is what I have the least experience with and it's what intimidates me most. The best I can do (and what I did) is label each corresponding connection when disassembling and upon reassembly, match the numbers. Simple enough, but doesn't really help when it comes to trouble shooting faulty connections and so forth. I had connected everything that I could, hooked up the terminals, flipped the key to on and...................nothing...... no dummy lights, no headlight, no power. There could be a dozen reasons to explain this with most likely it being that I did omit hooking up the front turn signals, back left turn signal, safety switch that runs to the clutch handle (PO broke that back in 2001), and the turn signal buzzer. With the limited knowledge I do have, I was able to chase the power to the 15 amp fuse and that was the end of it. So it came decision time, I could expend money, effort, and most importantly time trying to track down and fix the issue with the old wiring harness within my two weeks left in Tx or set in motion what my father and I had decided to do the bike anyways a month back. That was to scrap the wiring harness entirely and bring the bike into the modern day with this bad boy!
<a href="https://www.youtube.com/v/HNF-h6oBczg" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">https://www.youtube.com/v/HNF-h6oBczg</a>
So many features! I know it isn't time period correct but my goal in this build was/is to keep the outward appearance of the bike original while upgrading the internals (CB750 purists move along! I'm not planning on taking an angle grinder to it  ;)). So the decision was made to just start buying the parts necessary to make it happen (M-unit, Rick's reg/rec combo, electrical connections from http://www.vintageconnections.com/) and ship them to Florida so they will be waiting for when I get there. Forum member Calj737 has been incredibly kind answering my preliminary questions on how to run it, even offering to draw me up a wiring diagram to fit my needs. Clearing the Army has kept me from following up on it with him this week, hopefully that will change in the next couple of days.
I did get ahead of myself with this post and would like to highlight some of the things I did before trying to turn the power on.
The carbs were cleaned, polished, and assembled (with some issues). I used a couple of different products to help clean: acetone and Berryman's chem dip, but I think the best product overall for cutting through gelled up gas was Berryman's brake cleaner in the aerosol can.
Broken slow jet was replaced with a new Keihin #40:
Parts were polished and fasteners were replaced with SS Socket Head Caps to match the rest of the bike.
When I disassembled the carbs, I was unaware the stay plate was staked in place and broke a couple of small pieces off of the inside bushing (see previous post for pics). With a little bit of grinding, I was able to grind down a jagged edge and reassemble (without the two fragments). I know that this isnt the best route to go but I don't have a spare plate to replace it with. Once reassembled there didn't seem to be any major side to side play.
« Reply #45 on: February 25, 2015, 03:20:08 PM »
Looking pretty dang good! Where to in Florida?
Thanks! I'm headed back to my hometown of Lakeland (45 mins east of Tampa). I have some kayak fishing/motorcycling planned for the 80+ temps there.  8)
« Reply #46 on: February 28, 2015, 11:19:15 AM »
I know Lakeland. Mom lives in New Port Richey. I'll have to stop over this Spring for some wrench turning fun!
I could always use the help, saves me the trouble of researching the thousand questions I have if I can just ask you in person!
« Reply #47 on: February 28, 2015, 12:27:03 PM »
I haven't been able to do much on the bike in the past 3-4 days due to work constraints and my hatred of working in anything below 70 degrees. The garage I work in now is unheated and soon to be central Florida doesn't require a space heater for the two weeks of "winter" it has a year. Thankfully I'm not in a rush anymore to get it running before then. I do however plan on making a special trip to San Antonio because of this unused Pamco Ignition Kit for sale http://sanantonio.craigslist.org/for/4907679747.html. There is quite the debate on which ignition system for the CBs is best and I figured at that price it's worth it just to try it out. Pamco vs. Dyna vs. Stock points vs. Hondaman's ignition. The previous owner on my 78 CB750F installed a Dyna S and it hasn't given me any trouble after a year and 3000 miles.
I did forget to mention in my previous post that I purchased and installed the headlight washers that Crush makes and sells in the parts section, and they are awesome. Simple and cheap replacement for the disintegrated originals.
« Reply #48 on: February 28, 2015, 12:43:39 PM »
How did I miss that Pamco on my daily Craig's search??
Lucky for you....
« Reply #49 on: February 28, 2015, 01:06:28 PM »
Lucky for you....
You still have a chance to ninja it out from under me! Im not gonna make it down there until tomorrow.........just kidding, dont do that  :P
