Author Topic: Oil Pressure Gauge - Handle Bar Mounted CB750  (Read 4198 times)
Offline CG2000
« on: January 30, 2015, 02:04:30 PM »
Has anyone rigged up a oil pressure gauge on the handle bars? Where did the feed come from and how do you ensure the line isn't full or air? Or does that not matter? OR can it be done electronically?
I don't want to put an ugly guage on the side of my shiney new engine. It's a '76 CB750F. Cheers, C.
'76 CB750 | '72 CB350 | '96 XR650L | '06 KTM EXC 450 | '02 KDX220R
Online PeWe
Re: Oil Pressure Gauge - Handle Bar Mounted CB750
« Reply #1 on: January 30, 2015, 02:25:20 PM »
« Last Edit: January 31, 2015, 02:17:30 AM by PeWe »
Offline CG2000
« Reply #2 on: February 04, 2015, 06:57:57 AM »
Thanks PeWe!
« Reply #3 on: February 04, 2015, 08:09:30 AM »
For years and years I had one peeking through the hole in the unicorn style triple tree. FEd by a hose from the nub where the idiot light went, You could retain the light with a Y connector.  You could make a bracket to hang it anywhere off the Hbars you want.
Bleeding not a problem. Did it on its own.
Now I have an uglyone on the side.   :D
« Reply #4 on: February 04, 2015, 08:39:08 AM »
 My K0 had one between the gauges mounted to the top handlebar bolts on an aluminum plate. functional and easy to see. Harder to do on a later model or an F.
« Reply #5 on: February 04, 2015, 08:43:37 AM »
 Drag specialties sells a small diamater cup mount,  gauge and a clamp that fits over the handlebars. Old school appearance, my drag bike has a small tach mounted like that.
« Reply #6 on: February 04, 2015, 05:34:15 PM »
member J Webster makes and sells a kit to do this easily
http://forums.sohc4.net/index.php?topic=114969.msg1637747#msg1637747
Online PeWe
« Reply #7 on: February 07, 2015, 01:46:38 AM »
I guess that a gauge covering up to 80 PSI will be enough, right?
I might need one too!
For me its not an option with a gauge under the carbs, not visible on engine. I need it visible when driving.
Oil temp, exhaust temp and oil pressure would be nice to see while driving.
« Reply #8 on: February 07, 2015, 03:17:20 AM »
I have 60 psi gauge and on cold start, presssure is out of scale, 80 will do nicely.
Offline Whaleman
« Reply #9 on: February 07, 2015, 05:19:21 AM »
I have a handlebar mount oil temp gauge that is fed from a sensor tapped into the left side sump plug. Side mount oil pressure. Dan
Offline bert96
  • past ride
« Reply #10 on: February 07, 2015, 08:12:51 AM »
not to hijack but, anyone know the thread gauge of this plugs? (under the motor)
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Whaleman
« Reply #11 on: February 07, 2015, 09:44:30 AM »
The hole I drilled and tapped or the big thread. No idea on the big thread.  Dan
Offline bert96
  • past ride
« Reply #12 on: February 07, 2015, 09:45:50 AM »
The big one.
Bert
« Reply #13 on: February 08, 2015, 01:43:11 AM »
The oil galley plug? M20x1.5mm, same as the oil filter bolt.
« Reply #14 on: February 08, 2015, 01:45:33 AM »
Bert
Edit: sorry for the double, tablet is acting up :)
