Author Topic: 73 CB750 Rear Hub Help  (Read 4940 times)
Offline Powderman
Re: 73 CB750 Rear Hub Help
« Reply #25 on: February 23, 2015, 05:55:27 PM »
I knocked the nipples off the backs of the rubbers and was able to hammer the drive hub out. Now I am still having trouble breaking the bearing retainer loose on both hubs. They weren't meant to come out were they. They should thread the four holes so you can thread some bolts in to get leverage with a bar.
« Reply #26 on: February 23, 2015, 06:07:31 PM »
Referring back to my post #10. They definitely will come out fairly easily IF you drill out the locking stakes first. The stakes were done by the factory, essentially punch marks at the line where the internal and external threads meet. By deforming the first several threads with the factory punch, the retainer is locked from turning. If you drill them out with a bit sligtly larger dia than the stake, adn drill slightly deeper that the stake, like an 1/8" deep. Then the retainer will break loose with a slight effort and turn.
IF you  need guidance on a pin spaner DIY or otherwise let us know. This bridge has been crossed many times on the forum. In the worst case, where the stakes are not drilled, severe damage can be done to the hub. With drilling, the retainers come out and can often be reused.
Offline Powderman
« Reply #27 on: February 23, 2015, 06:32:27 PM »
The stakes have all been drilled and the hub heated with a torch to ease disassembly. All of this would be easier if the hub were not disassemble so there 's no real way to hold everything tight while working on it. I've been using a drift and hammer but it is causing more deformation of the holes than I prefer.
I was considering making my own spanner. Any threads you can direct me to on the subject?
Offline chewbacca5000
  • I polish covers!
« Reply #28 on: February 23, 2015, 06:56:16 PM »
Can you mount it to a piece of plywood or something?  Maybe a few drywall screws through the spoke holes will stop the hub from spinning.  You may need to drill a little deeper.
I used a star screw driver as a drift and for some reason that worked.  Key is to get the stakes out.
He may need to replace the retainer any how.
Offline Airborne 82nd
« Reply #29 on: February 23, 2015, 07:53:49 PM »
http://forums.sohc4.net/index.php?topic=132409.msg1479566#msg1479566
From  MCRider May 18, 2009
Then, my last tool I made was a flat piece of strap aluminum, about 24 inches long. Drill two holes in it the space of the notches in your retainer. Put two small short bolts in each hole with nuts to hold them there. THis tool should easily turn the retainer. Here's mine about a third of the way down page 29: http://forums.sohc4.net/index.php?topic=36459.420
Mine requires no welding or tools other than a drill. Not my idea, stole it from someone here.
« Last Edit: February 23, 2015, 07:58:54 PM by Airborne 82nd »
« Reply #30 on: February 24, 2015, 05:38:02 AM »
Thanks AB.
Pwdrman: Granted, the bare hub would be harder to work with.
Offline Powderman
« Reply #31 on: February 24, 2015, 07:24:22 AM »
Chewy, I may not have gone deep enough on the drilling of the stakes. Gonna get back at in awhile.
AB, I have pictured in my mind exactly what you describe.
« Reply #32 on: February 24, 2015, 08:35:16 AM »
As a machinist,  i have not drilled the stakes deep enough, I was embarrassed
« Reply #33 on: February 24, 2015, 08:55:09 AM »
Thanks AB.
No sir Thank you I made that tool like you describe and it worked perfect. If I ever need it again I might cut some slots to use it on other jobs.
Powderman if you want to spend money look at this
https://www.davidsilverspares.com/CB750K-FOUR-1978-USA/part_236408/
I don't care for tools that can only do one thing and I only need it every couple of years.
MC has the best bang for the buck.
Offline Powderman
« Reply #34 on: February 24, 2015, 11:29:28 AM »
Alright, I drilled a bit deeper and was able to get all retainers and bearings removed. I will suggest to the customer that the retainers be replaced as well as all he wheel bearings and seals. Are the retainers usually replaced? I know at least one of these (the cush hub retainer) is in good enough shape to reuse and the others may be as well. I'm being to see first hand how expensive a CB750 restoration can be if done correctly.
  • I polish covers!
« Reply #35 on: February 24, 2015, 11:32:25 AM »
Bearings need to be replaced.  Retainers can be reused if not too messed up.  They are only $20 bucks or so.
Offline Powderman
« Reply #36 on: February 24, 2015, 11:38:02 AM »
I assume this bike has sat for a number of years. When I pulled the brake backing plate off the shoe pads fell on the floor,not uncommon as I understand.
« Reply #37 on: February 24, 2015, 11:56:09 AM »
Thanks AB.
   ;D
Offline Powderman
« Reply #38 on: February 25, 2015, 10:05:02 AM »
After drilling the stakes deeper I was able to get everything apart.
« Reply #39 on: February 25, 2015, 10:12:32 AM »
Yay!
  • I polish covers!
« Reply #40 on: February 25, 2015, 10:44:33 AM »
Does this mean you are now offering this as a service? If so got some I will send your way.
