Author Topic: 1973 CB350F Build Log -- First Bike -- FINALLY FINISHED!!!  (Read 22201 times)
Re: 1973 CB350F Build Log -- First Bike -- Looking Like a Bike Again
« Reply #75 on: August 24, 2015, 07:43:13 PM »
Those badges look great -- just the right amount of wear/patina.
Offline GizmoDuck
« Reply #76 on: August 25, 2015, 06:56:37 AM »
Thanks!  Went to put them on last night and one of the posts had broken a little when I cut the original clip off so then replacement clip isn't grabbing to hold it in place.  Should I use an adhesive on the back of the badge so it doesn't fall off or maybe try to make a new post to secure the clip to?
Also is there a recommended process to smooth out some of the bends in the tank badges so they fit the contour of the tank?  There are a couple of bends from when I pulled them off to paint.  Thinking of taping the tank and then just heating and gently bending them a bunch till they match then remove the tape and clip them on.
« Reply #77 on: August 25, 2015, 07:33:11 AM »
I would cement in a replacement mount tab. Otherwise the adhesive may either fail or damage the paint (if you need to remove the badge for whatever reason).
The badges come flat new. I would recommend bending them carefully. Some heat may help prevent breakage.
Offline GizmoDuck
« Reply #78 on: August 26, 2015, 02:28:34 PM »
Entering the home stretch.  Wiring everything up and have to boxes headed in this week with some few odd parts to get it finished!
Offline GizmoDuck
« Reply #79 on: September 19, 2015, 07:14:36 AM »
Labeling my aftermarket controls
Modifying and rebuilding the right hand switch to have electric start, kill switch, but no headlight control as this is now on the left
Modifying a switch for the headlight and getting everything wired up
Waiting on a few parts and then need to build my seat.  The end is finally in sight!
Offline GizmoDuck
« Reply #80 on: October 08, 2015, 12:57:02 PM »
Making progress!!
Rear turn signals were bent so I hammered some deep sockets in to even them out
Rebuilding front brake
Got the carbs back on
Offline GizmoDuck
« Reply #81 on: October 16, 2015, 03:42:50 PM »
PROGRESS!!!
Left to do:
--Front brake is still squishy. Rebuilt MC and found out it was too corroded inside to seal so I bought a new MC but brakes are still squishy.  Bled brakes some bubbles came out but not a lot.  Wrapped a rubber band around brake lever to hold it open over night hoping that will allow bubbles to come out and will wake up to solid brakes tomorrow.
--Install brake light.
--Figure out why headlight wont turn on.  Light works and wiring looks fine so I am puzzled
--Build seat and have it upholstered.
Offline dbbrian350F
  • dbbrian350F
« Reply #82 on: October 16, 2015, 07:26:38 PM »
PROGRESS!!!
Left to do:
Hey that's lookin good! The black pipes with the very dark tank that looks almost black looks kinda mean.  If my pipes don't clean up reasonably well I may end up painting them black too.
Bound and determined to restore my...
1974 CB350F1
Lucky new custodian of...
1978 XS1100E
Offline GizmoDuck
Re: 1973 CB350F Build Log -- First Bike -- Finally Finished!!!
« Reply #83 on: June 30, 2016, 04:14:10 PM »
Brakes Finished and Headlight Sorted
Upholstering Seat
Offline GizmoDuck
Re: 1973 CB350F Build Log -- First Bike -- FINALLY FINISHED!!!
« Reply #84 on: June 30, 2016, 04:16:48 PM »
DONE
Finally finished everything up this week, fired it up for the first time since disassembly, ran through all the gears, and it runs like a dream!
Special thanks to everyone here on the forums for helping me when I got stuck trying to sort things out.  My kids and I had a blast and they are already begging to build another one!
« Last Edit: June 30, 2016, 04:18:38 PM by GizmoDuck »
Offline dbbrian350F
  • dbbrian350F
« Reply #85 on: June 30, 2016, 04:24:13 PM »
Congratulations it looks great!  And you have the best part of the summer to ride it too.   ;D
1974 CB350F1
1978 XS1100E
Offline mannydantyla
    • dannix.net
« Reply #86 on: July 06, 2016, 07:18:56 PM »
Awesome build! Really great work!
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
« Reply #87 on: July 10, 2016, 05:10:01 PM »
Great job!
