Author Topic: Stuck Caliper Bolts ?  (Read 1606 times)
Offline rddcw
« on: June 16, 2015, 11:31:16 AM »
Picked up a used Caliper and Mount off of ebay from a 73 CB750. Was a real bear to remove the bleeder bolt, but after several days of soaking it with Liquid Wrench it finally came loose.
Problem I'm having now is trying to separate the 2 caliper halves held together by 2 allen head bolts. Trying to loosen those bolts, but not budging ? Do you Guys have any suggestions ?
I read on the internet that mixing equal parts of ATF and Acetone works the best, so soaking the 2 bolts right now to see if that works.
I don't want to bugger the allen head, so using good tools to accomplish this.
Offline edwardmorris
  • Youngish
Re: Stuck Caliper Bolts ?
« Reply #1 on: June 16, 2015, 11:42:07 AM »
Heat gun works well.
« Reply #2 on: June 16, 2015, 11:48:18 AM »
What he says ^^^.
Bake it in the oven at 200F or so and try again.
Offline rddcw
« Reply #3 on: June 16, 2015, 11:56:15 AM »
I don't know if my wife will allow me to stick the caliper in the oven but I do have a Heat Gun. I'm assuming that your trying to heat the caliper and not the bolts?
« Reply #4 on: June 16, 2015, 11:58:03 AM »
Steel on Aluminum,  any heating will do since the heat expansions is different.  It brakes the bond between the bolt and the thread.
Offline rddcw
« Reply #5 on: June 16, 2015, 12:15:39 PM »
I'll give it a shot with the Heat Gun and will report back. Right now I'll soak it overnight and see if that will assist with loosening.
Thank you "All" for your comments !
« Reply #6 on: June 16, 2015, 01:51:32 PM »
No offense intended, but this board is for complete PROJECTS, not on troubleshooting a portion of them.  You should post these topics on another board like SOHC4 Bikes.
Like the Global Moderator says:
http://forums.sohc4.net/index.php/topic,58514.0.html
« Last Edit: June 16, 2015, 01:53:38 PM by CB750 Cafe Racer Fan »
