Author Topic: Frame-up cb350f restoration, hunk o' junk transformation  (Read 63505 times)
Offline markreimer
Re: Frame-up cb350f restoration, hunk o' junk transformation
« Reply #150 on: March 12, 2016, 04:50:45 PM »
Hah!
Today was a day for riding. 10C outside and errands to run. I put on about 40 miles and a few nice things happened. The white exhaust smoke disappeared entirely, even on later startups. Also my tach started working again, hah! It now moves freely throughout its entire range.
I also took it onto a short bit of highway, pushing it to the redline. Real nice feeling bike. It's kinda like a single speed bicycle - if you want to go fast you have to maintain momentum and a high cadence.
I also had my first request to sell the bike, in the form of a note stuffed into the seat strap lol.
The engine is pretty buzzy below 5K. Since I haven't balanced the carbs yet I'm going to point my finger at that as the culprit. I'll deal with that soon.
Offline MoMo
  • Ride like you're invisible
« Reply #151 on: March 12, 2016, 05:19:09 PM »
the bikes are buzz boxes, doubt carb sycn will do anything as that only affects idle
Offline carnivorous chicken
« Reply #152 on: March 12, 2016, 06:15:25 PM »
These things thrive in the 5K-rpm and higher range, don't be afraid to take it up there. I think some of "buzziness" is your exhaust, if you get that sorted it might not seem so buzzy. A carb synch will help it run more smoothly through its range.
Offline markreimer
« Reply #153 on: March 16, 2016, 09:01:27 PM »
Well... I was thinking tonight might be a good night to work on the bike... Looks like Mother Nature has other plans. Apartment life...
« Reply #154 on: March 16, 2016, 09:28:27 PM »
What's that white stuff all over the ground?  We don't have that stuff in Los Angeles.
Offline markreimer
« Reply #155 on: March 22, 2016, 01:02:39 PM »
Slow progress as the snow still hasn't left entirely. It's hovering around zero for the last week.
The emgo dunstall style muffler arrived today but doesn't for the 4-1 header. It was listed as fitting 1 3/4" but is at least 1/4" smaller than that. I'm going to take advantage of the free return and exchange policy and replace it with the emgo shorty 17" pipe instead. It should actually fit... With some better glass pack than stock I think it'll be a nice loud but not tooooo loud sound.
In other news, my wife passed her learners motorcycle written test today and subsequently signed up for the riding course! She'll be taking that in May. So I've got two more months to dial this bike in 100%
« Reply #156 on: March 22, 2016, 02:50:42 PM »
I mean this in the most respectful way.  Have you thought of installing crash bars for the almost inevitable novice tip-over?
Offline markreimer
« Reply #157 on: March 22, 2016, 02:52:20 PM »
That is a very excellent suggestion which I oddly hadn't thought of. I dumped my 750 a few times in parking lots while learning, no crash bars... Bad decision. I think I even have a pair kicking around somewhere. Thanks!
Offline whizzer
  • Be safe
« Reply #158 on: March 27, 2016, 07:36:44 PM »
Great project, I am following each step.  When you share more pic's, can  you include the kick starter mod?  I think you got it done without 550f kick starter?
72 cb350f
66 cb77 sold
72 Suzuki gt750 given away
59 Vespa given away
06 Whizzer sold
« Reply #159 on: March 28, 2016, 10:34:00 AM »
I've got a set of crash bars for a 350F that I don't need, let me know if you're interested...
Offline markreimer
« Reply #160 on: April 08, 2016, 09:22:13 AM »
Yes, interested in the 350 crash bars!
Whizzer - I haven't done the kickstart fix yet. It will work though, i've found examples online. I haven't been paying much attention to the bike the last two weeks because it snowed again... but next week calls for +18C so I'll be back at it.
« Reply #161 on: April 08, 2016, 12:27:35 PM »
PM me your address, I'll send photos. Will need to pull them.
Offline markreimer
« Reply #162 on: April 15, 2016, 07:28:42 AM »
I may have found a pair of crash bars locally from a friend with a 400F. Not sure if they'll match up yet, but I'm going to try that first.
The weather has been warming up and I've made some better progress on the 350F.
A few days ago I adjusted the valve clearances for the first time. No real surprises or issues there, although it certainly is easier on the CB750. These valves are so small, and there isn't an obvious way to hold the little square-headed screw in place while tightening the locknut down. Anyway, I got them all bang-on.
Last night I replaced the muffler with a little Emgo cocktail pipe. Wow, it looks bad ass! The smaller muffler with a little up-sweep really suites the 4-1 header in my opinion. The only issue is that the stock hanger bolt on the pipe won't work - it hits the swing arm, so I had to lob it off. That means it's not supported at the moment. Less than ideal. So I'll figure some way to support the pipe at the clamp between the header/pipe next shop night. Also I'll need to make some kind of cap to put over it when parked in the rain....don't need water pooling in the collector box and rusting out my beautiful header. Check the video!
Up next was a really squeaky swing arm. I tried pushing grease into the zerk but my grease gun doesn't much care for the Japanese fitting. I pulled the pivot bolt aaaaaaand bone dry! Not one iota of grease in there. Glad I checked that. I pulled the zerk out, drilled the bolt and tapped it for a metric fitting, blew the bolt out with compressed air, threaded the new zerk in, and pushed a ton of grease through to clean out any remaining metal chips. Back in the swing arm now, and more grease pumped in. The swing arm is dead silent and moving free and easy.
I wanted to sync the carbs and check the timing as well, but it was almost midnight. We had a late 70's R100S in the shop as well, which was getting a valve adjustment, fluid change, and timing adjustment at the same time. Busy night.
So, next week is carbs, timing, and that DAMN STIFF CLUTCH.
Offline markreimer
« Reply #163 on: April 15, 2016, 07:29:46 AM »
« Reply #164 on: April 15, 2016, 09:07:03 AM »
Sounds like progress.
For adjusting those valves, Honda made a special tool with a little square head. You can also buy a tool that's has the 8mm lock nut size with a screwdriver type tool that fits inside in order to hold the square head in place while tightening down the lock nut. I honestly alternate between the two -- sometimes I find the old Honda tool is easier, sometimes I just use the two-in-one tool.
Don't let that muffler hang. Everytime you hit a bump that thing will bounce and you risk bending it or affecting the seal where it mounts to the head. A cheap piece of steel bracket at a hardware store, a grinder to cut it to size, and some metal drill bits and you've got a temporary (or not) bracket.
Offline markreimer
« Reply #165 on: April 15, 2016, 09:49:27 AM »
100% agree. The exhaust is really light but when it's cantilevered way out there it doesn't make me feel good. Even a bush league bit of strapping is better than nothing till I can make a more eloquent solution
Offline MoMo
« Reply #166 on: April 15, 2016, 04:42:42 PM »
I have that special HOnda tool but I seem to gravitate to a box end wrench and pair of flat nose pliers to hold the square adjuster...Larry
Offline markreimer
« Reply #167 on: April 21, 2016, 09:29:38 PM »
A bit more progress on the bike tonight. I rebuilt the clutch again but still no luck, just so stiff. Finally I tried a new cable routing with the tank off - in front of the gauges and a smooth arc down to the clutch. Basically as straight as possible. Voila! Silky smooth and light clutch action. So it's the cable.
It's a new motion pro cable. I pumped it full of lube till it drained out the bottom, but as soon as I returned it to stock routing it was really hard to use. I could feel the cable grinding in the housing. No routing solved this other than the one I described earlier.
Anyone have experience with other cable brands besides motion pro? Or a specific cable lube to recommend?
Offline markreimer
« Reply #168 on: April 29, 2016, 07:10:38 AM »
Well 4 into 1 is taking their sweet time to deliver my new clutch cable and braided brake line, so I haven't made any progress in the last week. Instead I've just been riding, oh bummer!
I sent an email out to a local seat guy to see what he can do with the stock seat pan. That should really make the bike look better. Also looking into some mirrors that aren't so huge. Anyway, here are some photos as it stands. It's pretty dirty, did some gravel riding recently
Offline markreimer
« Reply #169 on: May 02, 2016, 02:19:18 PM »
Looks who went for her first ride EVER! She was starting and stopping over and over for half an hour. Only stalled twice. Didn't get to shifting yet, that's Wednesday's lesson. But she's hooked for sure. Hasn't stopped talking about it since.
New clutch cable and brake line is in the city, so should have those parts installed by the weekend as well.
Offline MoMo
« Reply #170 on: May 02, 2016, 09:27:57 PM »
 8) 8)
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
« Reply #171 on: May 03, 2016, 12:38:30 AM »
Great progress man and that muffler sounds awesome!  Keep the updates coming, glad all parties are enjoying the bike as well ;)
Offline iiAtlas
« Reply #172 on: May 03, 2016, 11:05:01 AM »
Looking good!  Time to pick up another CB350F... ?  ;D
Offline markreimer
« Reply #173 on: May 03, 2016, 11:13:03 AM »
Haha, actually....I have another one. I have a frame, the front end off some other bike (maybe a 450, it has a front wheel that's 1" larger), and I just got a complete 350F engine for free. That project is not happening anytime soon though. I need to finish this up, do a bunch of routine stuff on my R80, and then rebuild my cb750 engine again first.. Maybe in the spring!
Offline markreimer
« Reply #174 on: May 05, 2016, 09:34:00 PM »
Clutch is fixed!!
It was the cable. I used a genuine Honda cable in the stock routing position and the clutch is smooth and light. It's perfect. This is a dramatic improvement to the ride quality.
I had a stainless brake line but didn't install it tonight as I misplaced the hydraulic bank bolt switch. Hmm... Sure it's around here somewhere.
I also had the gas cap gasket start leaking, pouring fuel al over the front of the bike after a hard stop. That's a first. I rotated the seal a few times, closed the cap and the problem stopped. Odd...
So next up is the brakes and more riding lessons for Cindy this weekend. She can shift now!
