Author Topic: 1975 CB550K Restoration  (Read 37555 times)
Offline HondaAddict
    • Videos on my CB550K restoration and other projects
Re: 1975 CB550K Restoration
« Reply #50 on: September 08, 2017, 10:32:18 AM »
Fork covers.
1976 Honda CB400F
1975 Honda CB550K (sold in 2020)  Project thread | Videos
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1984 Honda V65 Sabre (sold in 2020) Project thread on V4Musclebike.com | Video
1986 Honda Z50R
Offline Can550
« Reply #51 on: September 09, 2017, 12:23:35 AM »
Hey nice work
Love the way you polished forks and calliper arm.
How did you remove rust off fork ears ? I tried CLR and couple more but couldn't get rid all of rust
Offline Can550
« Reply #52 on: September 09, 2017, 12:25:00 AM »
If you are interested in original pipes, the way I got my set was to buy as and when whatever is available. I ended up with 7 pipes have 3 in my garage. If you are interested pm me. I'm in Ontario
Offline HondaAddict
« Reply #53 on: September 09, 2017, 05:09:59 AM »
Hey nice work
Thanks.
I use Evapo-Rust on parts such as the fork ears. Just soak them for a day or two and all rust is gone. Evapo-Rust is a bit pricey, but it can be used multiple times and I've never found anything else that works as well.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #54 on: September 09, 2017, 05:12:23 AM »
I am interested - thanks. PM on its way.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #55 on: September 09, 2017, 07:24:51 PM »
Steering stem.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline Can550
« Reply #56 on: September 09, 2017, 07:50:00 PM »
Great looking work
Which paint
Offline HondaAddict
« Reply #57 on: September 10, 2017, 06:05:47 AM »
Great looking work
Which paint
Thanks.
I'm using Krylon semi-gloss enamel on Krylon primer. Likely not the ideal paint and the color match won't be perfect, but it's priced right and I've had good luck with it on other projects. Some of these parts will also get a clear coat.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
« Reply #58 on: September 10, 2017, 06:51:41 PM »
Very nice restoration work.  Love polished aluminum...
Offline HondaAddict
« Reply #59 on: September 15, 2017, 05:37:29 PM »
Thanks!
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #60 on: September 17, 2017, 02:27:07 PM »
Front portion of the frame.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline The Machine
« Reply #61 on: September 17, 2017, 06:29:43 PM »
Great job! What methods or what did you use to get them looking so good (fork tubes). Besides lots and lots of time & elbow grease lol. Great resto BTW, looking forward to seeing completed.
« Last Edit: September 17, 2017, 06:34:13 PM by Machine »
Offline HondaAddict
« Reply #62 on: September 17, 2017, 06:54:36 PM »
Thanks!
I sanded the fork tubes (220 grit, 400, 600, 800, 1000), then buffed with a few stages of compounds. I finished them with Wicked Metal Polish.
« Last Edit: September 18, 2017, 02:25:03 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #63 on: October 14, 2017, 09:14:50 AM »
Finally starting to reassemble the front end.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #64 on: October 22, 2017, 08:09:14 AM »
A few B/A shots of the inside of the front fender with undercoat and braces.
« Last Edit: October 22, 2017, 08:10:51 AM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
« Reply #65 on: October 27, 2017, 08:11:48 AM »
Looks good!  But may want to order some black rubber?
Offline HondaAddict
« Reply #66 on: October 28, 2017, 06:32:20 AM »
Thanks.
Do you mean tires? I've been shopping, but I need to wait for the bank account to catch up.  :)
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #67 on: October 28, 2017, 03:00:18 PM »
Rear shocks.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #68 on: November 22, 2017, 10:00:55 AM »
Control housings and rear fender.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #69 on: December 26, 2017, 06:15:50 AM »
Alternator cover.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
« Reply #70 on: December 27, 2017, 11:27:31 AM »
Beautiful!  Does the motor need a respray?
« Reply #71 on: December 27, 2017, 12:32:10 PM »
Did you sand blast or bead blast your fenders?  The chrome is nice.  Mine is going to gone with the tiny black dots where the chrome is reacting with the steel.  They are dissimilar metals and have galvanic corrosion.  I wasgoing to ask if you did new fenders until you showed the undersides.
Very nice work.
« Reply #72 on: December 27, 2017, 12:42:16 PM »
Usually the shocks are gone and you could tell how bad they were with springs removed.  The Hagons and Ikons are excellent replacements, better to spend that much to get a good shock, you won't regret the expense.  Consider it a safety item like tires and a good helmet.
there are sintered caliper pads available from EBC, worth choosing.
With a lathe you can fab several things.  Look up FunJimmy's Cafe Interceptor build, nice resto mod front end.
You could do that hub work and earn a few $ doing it for others.
RaceTech gold valve emulators for your forks if you stay with original forks are recommended.
likely your fork springs are toast and need replaced.  Most were needing replacement with 12-15k miles max.
You can skim the center of your fron hub's raised cooling ribs as the front does not need that and a cut and polished hub center is very nice.  Waxing the back of the fork ears helps keep rust at bay and wax on chrome will make it easier to wash and clean and maintain the shine.
Offline HondaAddict
« Reply #73 on: December 27, 2017, 08:35:03 PM »
Thanks!
Yes, I'll be refinishing the entire engine. I put the alternator cover back on just to keep everything closed up until I get time to do the rest of the engine.
« Last Edit: December 27, 2017, 08:39:25 PM by HondaAddict »
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
Offline HondaAddict
« Reply #74 on: December 27, 2017, 08:38:48 PM »
Very nice work.
Thanks!
No blasting for the fenders. I soaked them for a few days in Evapo-Rust. It also removes any surface rust on the chrome. I use Autosol to polish chrome, which seems to work well.
1976 Honda CB400F
2008 Honda GL1800AL
2016 Honda CB500F
2018 Honda CB300F
1986 Honda Z50R
