Author Topic: KO basket, i think? YUP! Gonna bring back to life......  (Read 23856 times)
Re: KO basket, i think? YUP! Gonna bring back to life......
« Reply #50 on: December 22, 2015, 12:38:02 PM »
Should have warned you , there are springs and rollers in the starter mechanism on the back of the rotor...they lock the gear to he crank when starting.... Might be ok, but rotor should be pulled off to check them later.. ..need a puller for that..
Offline pipeguy
« Reply #51 on: December 22, 2015, 02:44:46 PM »
Thanks for heads up, I am going to pull it once I have the cases clamped on crankshaft.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
1977 KH 400 triple (gone)
1973 CB750 K3 (waiting it's turn)
2000 KLR 650(gone)
2001 BMW 1200RS(gone)
2004 Busa limited(sadly gone)
2003 ZZR250 ninja(gone)
1996 VFR750(gone)
1974 RD350(really sadly gone)
Offline Restoration Fan
  • My wife will never call me
« Reply #52 on: December 22, 2015, 02:53:08 PM »
pipeguy,
Contact Bill Benton (goes by Bill/BentON Racing on the forum) with a private message about the bent exhaust valve.  He has a stash of these bikes and parts that is quite possibly the largest single individual collection in existence.  He sells parts to members of this forum at very reasonable prices and is a heck of a good guy.
« Reply #53 on: December 22, 2015, 06:30:31 PM »
You can use the puller with crank on the bench.. Torque it up , give it a whack.... retighten..whack.. Its off... Usually
Offline mrbreeze
  • Not your average
« Reply #54 on: December 22, 2015, 07:35:31 PM »
Nothing much to say here except I'm wanting to follow along with your build and my name is also Fred. I had a K1 2 years ago for a project but sold it off due to circumstances. Also had a K4....same thing. The K4 would have been easier to get going. The K1 motor was locked and the bike as a whole was in worse shape from sitting out in the elements longer. The K1 would have been the cooler bike of the 2 though. I still have my K5 runner that I've owned since 2000 but it's down for some seal replacement and engine paint at the moment. Have fun with the build.....I'm following.
MEMBER # 257
Offline pipeguy
« Reply #55 on: December 23, 2015, 05:28:40 PM »
Thanks for the valve  Steve, great to meet you today. This is what this community is all about.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Swoop
« Reply #56 on: December 24, 2015, 11:14:46 AM »
No problem. Hope one works for you.
I have a feeling that you may need a couple of more parts.  ;D
Steve
Offline pipeguy
« Reply #57 on: December 24, 2015, 11:59:30 AM »
I'm sure I will Steve. You were right I did find soome bolts with the #8 on them like you said.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Swoop
« Reply #58 on: December 24, 2015, 12:36:47 PM »
Good...hold onto them and reuse them.
Steve
Offline pipeguy
« Reply #59 on: December 28, 2015, 06:41:31 PM »
So after all the turkey from the holidays, I needed to get off the couch, so down to basement I went. I was pleasantly surprised how my rotor came out with that metal rescue stuff. I did some plastiguage measurements and prepped  my cases for painting. What kind of paint do you guys recommend? Should I use self etching primer first, just regular primer, or just the paint? I also removed my exhaust spigots and crush washers and cleaned everything up. Gonna be busy next couple of days, but next I want to grind my valves and put them back into head.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Offline mrbreeze
  • Not your average
« Reply #60 on: December 28, 2015, 07:43:27 PM »
Lots of good info here about painting. Some use primer and some don't. Prep is the most important thing and part of the prep is curing the paint. Get on the search function.......people will give good paint recommendations. The color will be up to you.
Check your guides carefully when doing your valves. There's more to it than seating and adding seals. Also shoot for the good seals. There are better ones out there than what the kit will give you.
Keep up the good work man!!
MEMBER # 257
Swoop
« Reply #61 on: December 29, 2015, 04:11:42 AM »
I don't think that the K0's used valve seals.
Steve
Offline pipeguy
« Reply #62 on: December 29, 2015, 04:50:27 AM »
My head had valve seals. Basket came with 2 sets of jugs, maybe head belongs to second set of cases? I think they are from K2 according to engine #.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Offline pipeguy
« Reply #63 on: December 31, 2015, 05:09:05 PM »
Today got to spend a few hrs on the head. Got valves grinded-lapped and installed new seals. Also got all springs in, head complete. Now just have to clean it nice ready for paint. That Metal Rescue stuff is amazing.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Offline pipeguy
« Reply #64 on: January 01, 2016, 04:01:26 PM »
Today I was taking apart my drive sprocket to clean stuff up, I have 2 complete sets, but this I one that matches the cases I'm going to use. The other sprocket is 15 tooth, this one is 17 tooth. Which one u think is better? Or would matter to see what I'm going to use in rear? I found this nut-bolt on this one, is this what this automatic oiler I've been reading about? I see a pinhole in drive shaft I can only assume that's for oil to come out of? Thanks in advance.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
Offline BPellerine
« Reply #65 on: January 01, 2016, 06:34:28 PM »
the hole in the shaft is for chain oiler,came on the earlier bikes,some block it off cause of the mess,the 17 tooth sprocket would give more relaxed engine speed on the highway.bill
1978 CB 750K ard and webers
another anfob
Offline mrbreeze
  • Not your average
« Reply #66 on: January 01, 2016, 07:09:03 PM »
I've also heard the 15 tooth sprocket was on the earliest bikes and contributed to the chain snapping problems that they had which also cracked the cases. I've also heard of battery acid leaking on the chain. I'd stick to the 17 or even an 18.
MEMBER # 257
Offline pipeguy
« Reply #67 on: January 05, 2016, 05:38:04 AM »
thanks, do I have to block hole? That screw at end looks like an adjuster? Can it be put to 0oil coming out? Thanks, Fred.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
« Reply #68 on: January 05, 2016, 06:53:03 AM »
Yes, it is an adjuster..., just close it off.
Offline edwardmorris
  • Youngish
« Reply #69 on: January 05, 2016, 08:43:40 AM »
If you haven't already done the painting, a thin coat of a zinc based primer is a good idea. VHT makes one I think, I got a can from JEGS and did a very light coat first. This is a dark green color primer, so easy to spot any missed spots. Then I used their aluminum color, which again, was easy to spray over the dark green and not miss any spots. There are some nice pointers on the painting stuff in my K2 thread, I can dig up some links if you need.
IINM, K0 engines weren't painted from the factory (maybe just a clear coat), so just a bead blasted or better yet, vapor blasted look might be cool too.
  • Youngish
Offline pipeguy
« Reply #71 on: January 23, 2016, 08:56:13 AM »
So now getting ready to start assembling transition, just bolted lower case to engine stand.
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
« Reply #72 on: January 23, 2016, 09:49:51 AM »
Put everything into upside down upper case, then install lower..shift forks may need a bit of fiddling.
Offline pipeguy
« Reply #73 on: January 23, 2016, 10:00:37 AM »
But I would still have to assemble some parts in this case correct? One set of gears and the forks no?
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
2000 KLR 650(gone)
1996 VFR750(gone)
« Reply #74 on: January 23, 2016, 10:16:44 AM »
Yes but most goes in upper case..manual wil, show you the order..
