Author Topic: CB550 Project Start  (Read 16028 times)
Offline tacc13
Re: CB550 Project Start
« Reply #50 on: November 16, 2019, 01:08:20 AM »
Got the pistons sorted and installed and have the barrels on. Waiting for the heads to get back from the machine shop and also get ceramic coated. The Stahlwille piston ring tool may never get used again until I need to go up a size on the pistons, but it's a very cool piece of equipment.
ARP 12 points are from Allens Fasteners who are great people to deal with.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #51 on: November 16, 2019, 09:15:57 AM »
Looks great, keep the posts coming!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline djpwiebe
« Reply #52 on: November 18, 2019, 09:40:16 AM »
Bit the bullet and decided to run the bar wiring internally. I got some advice from the blokes at Revival Cycles as there is a small amount of modification required. I drilled a 4mm hole at the end of the bar and had to enlarge the internal diameter slightly. I used two cheap ebay tools for about $5 each. I need to make the exit hole a bit neater and larger so I can run the braided covering.
I'm also planning some internal wiring in the same Tomaselli bars with Motogadget mini switches for my CB750. Did you use the m-button relay to send a single wire to the m-unit? I'm curious if the m-button relay can fit through the hole drilled in the end of the bar where you installed the signal. Alternatively, were you able to separate the threaded bar from the elbow? From the other end of the elbow it looks like the bar itself is threaded into the elbow. I'm not sure if I can turn that out or if adhesive was used to fix the threads and I'm worried I might cause damage if trying to separate those parts.
Offline tacc13
« Reply #53 on: November 18, 2019, 12:12:41 PM »
I eventually went with different bars.  The Tomasellis were problematic, the internal diameter is very tight.  I didn't separate the bars from the elbows and don't think the m-button would fit. I ended up buying standard clipons and two 6061 solid rods that I got bored out to maximise the wall thickness. Standard bars have thin walls and I was concerned the internal wiring holes would weaken them.
Sent from my ZTE A2017G using Tapatalk
Offline tacc13
« Reply #54 on: December 22, 2019, 11:51:55 PM »
I ordered two new oil control valves which finally arrived today.  Everything went together well,  including the Cam chain tensioner,  which I didn't previously know had a slot to sit in.  Good advice that! Cam goes on tomorrow and then pull the chassis down so I can drop the frame over the engine.
Offline tacc13
« Reply #55 on: December 23, 2019, 03:42:42 AM »
Yeah, I'm not running the M-Button, just running independent wires from each switch.
Offline tacc13
« Reply #56 on: December 26, 2019, 03:03:01 AM »
Have managed to make a lot of progress over the last two days, as per all the photos. Apart from the wiring there's a ton of small things to do that I noticed while I was bolting everything together. I'm also not entirely happy with the seat. It's an AirTech Dick Mann replica that I lengthened slightly, but it leaves a gap under the tank with about half of the electrics tray exposed. It also sits completely flat on the frame which doesn't leave any room for wiring. The upholsterer also did a pretty average job, which is a surprise because he is well known locally in the custom car world. Will strip it back and keep the hump, but mould a new base that has about a 1.5cm lip. Still not sure what to do about the bit under the tank, am very open to suggestions. And obviously I need to paint the fairing.
Offline tacc13
« Reply #57 on: March 06, 2020, 09:45:24 PM »
Doing my wiring harness again from scratch.  I've been able to get all the proper Honda colors and I think my skills have improved a bit since I built the last harness three or so years ago.  The Motogadget switches are every bit as tedious as I remember, and I've lost one of the microscopic screws on the floor.  Waiting for Mizu P25 and Deutsch connectors to arrive in the mail.  Nothing can be bought over the counter in this country. Found a replacement screw in the back of a calculator!
« Last Edit: March 07, 2020, 02:31:13 PM by tacc13 »
Offline ctcycleworx
« Reply #58 on: March 17, 2020, 08:03:06 AM »
Coming along very nicely!!
Offline kerryb
  • Not a very
« Reply #59 on: March 22, 2020, 05:28:01 AM »
I applaud your tenacity!  This will one very fine machine.
Offline tacc13
« Reply #60 on: March 23, 2020, 02:24:11 AM »
Thank you. The fuel line reducers you sent are brilliant, hopefully when this virus is over I will get a chance to help you plan a trip to AUS and NZ. At least the country will have recovered from the fires by then.
Offline XC204
« Reply #61 on: March 28, 2020, 07:20:06 AM »
Awesome bike what detail!
Gary
Offline tacc13
« Reply #62 on: July 02, 2020, 03:47:45 AM »
Just got my fairing back from the paint shop. Color is Candy Red over a charcoal base. Thinking of getting the channel where the screen bolts on covered in 3M clear tape to protect it from rubbing and stop any squeaking. Just got my second Golan petcock and now waiting on a few bolts from Allens Fasteners.
« Reply #63 on: July 02, 2020, 08:08:51 AM »
The paint looks rich.
Man, those Motogadget micro wires are a PITA.
Offline tacc13
« Reply #64 on: July 04, 2020, 12:52:25 AM »
Had to see what she looks like with the screen bolted on. Waiting on Brembo front master cylinder, air box from Steel Dragon Performance and a shorter 12" muffler from Ripple Rock. Covid is slowing everything down. I have a longer muffler but it fouls the track stand.
Offline tacc13
« Reply #65 on: February 07, 2021, 12:57:05 AM »
Apologies, haven't updated this for a while unfortunately.
Finally got the bike started and to my surprise it ran reasonably well right from the start. It idled high so I redid the valves and timing which both needed adjusting slightly. Added to my tool collection with a set of vacuum gauges and balanced the carbs. Eventually got the engine to idle nicely at just under 1000 RPM. Had to grind away part of the choke lever because it hits the Steel Dragon air box about 2/3 of the way through it's motion.
Two things that have been a problem for a while are hanging the exhaust and working out where to put the rear brake light actuator. I had a micro-switch for the brake light, but wasn't really happy with it.
For the exhaust hanger I got a 10mm rod joiner and used that as a nut on the Cognito rearsets. Made a bracket similar to the Ripple Rock one but a bit longer out of 3mm stainless and used the other end of the 10mm rod joiner as the anchor point. Photo is attached. The clamp on the exhaust is an earlier trial and needs to come off. The rod joiner also makes it easier to take the foot pegs off as the original 10mm nut was recessed in the mounting bracket and a pain to get to.
For the rear brake light switch I got a stainless 90 degree bracket for an SR500 and then used threaded rod through the kickstand brackets to hold it in place.
Hopefully the photos are clear, if anyone wants better shots let me know.
Just need to tidy up the wiring harness and sort out the sensor for the Motogadget speedo.
Offline ceebee ninja
« Reply #66 on: February 18, 2021, 06:56:00 AM »
Awesome bike & rebuild - where did you source the clear screen?
Offline tacc13
« Reply #67 on: March 13, 2021, 01:45:05 AM »
Thanks! The fairing is for a Ducati 900SS. I got it and the screen from a Ducati shop in Sydney, Australia. Air-Tech in the USA would probably have the same parts.
Offline tacc13
« Reply #68 on: May 01, 2021, 06:21:54 PM »
Bike is basically finished, as much as projects are ever fully done. The seat needs to be re-upholstered. Took it for a ride yesterday but couldn't go too far as she isn't registered yet. Just need to give her a good clean and hope she passes inspection for registration.
« Reply #69 on: May 01, 2021, 09:07:22 PM »
Nice job!  That is a lot of really nice stuff coming together there!
Offline Register
« Reply #70 on: May 03, 2021, 12:13:18 AM »
Bike looks terrific, congratulations.
I also inverted the drum lever. Do you see any risk of it self actuating on full suspension travel?
Offline tacc13
« Reply #71 on: May 03, 2021, 06:04:58 AM »
Don't think so, I've seen a few builds done like that and haven't heard of any issues.
Offline Register
« Reply #72 on: May 03, 2021, 07:39:50 AM »
Thanks, I'm minded to agree, I only ask as it was suggested as inevitable on another site.
The way I figure it, the arm and hub are traveling the same arc around the the swing-arm pivot so remain in the same relationship, The brake lever arm at the rear-set is in a variable relationship to the swing arm pivot.
My trigonometry isn't up to the challenge but it could only be a few millimetres.
Can't see myself worrying about it
