Author Topic: West Texas CB550  (Read 5877 times)
Re: West Texas CB550
« Reply #25 on: June 01, 2016, 09:22:33 AM »
CB750 CR Fan - I picked up a 4 fuse modern block like you described.  It is a bit larger than the original, but I may be able to make it work.  Thanks for the suggestion!
Cityscapedview -
It is an amazing collection.  The video only shows part of it...
RAF122s - thanks for the advice!  I did go ahead and order a replacement slide for my #4.
It's nice to know with the blade fuse block that you can get a spare fuse almost anywhere, whereas tube fuses are definitely more scarce.
