Author Topic: 1975 Honda CB750F Oil Pumps  (Read 1682 times)
Offline RodSOHC750
  • Restoring Vintage Honda Motorcycles
« on: May 15, 2016, 01:07:31 PM »
Searching EBAY for used 1975 CB750 oil pumps.  I don't understand the HM751, HM345B, HM184, HM305, HM128B, HM640 etc. in the pump descriptions. What are these codes?
1979 Honda CB750L Limited Edition
1975 Honda CB750F Super Sport
1972 Honda CL450
1970 Honda CT70
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
Re: 1975 Honda CB750F Oil Pumps
« Reply #1 on: May 15, 2016, 01:21:16 PM »
I think that those numbers are just what the seller uses to label his parts. There is only one seller that uses them. It's a salvage yard. I've bought from them a bunch and that code means nothing to you.
Sent from my Nexus 5X using Tapatalk
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
Offline RodSOHC750
« Reply #2 on: May 15, 2016, 01:27:15 PM »
OK. That makes sense.  Couldn't believe Honda would make so many variances of the oil pump in one model year.
1972 Honda CL450
1970 Honda CT70
« Reply #3 on: May 15, 2016, 03:40:56 PM »
b
Correctomundo
Offline Bigsam302
« Reply #4 on: July 02, 2016, 09:45:23 AM »
There's nothing like being stuck on the side of the road after my antigravity battery exploded today. The scariest thing is sitting here fanning my bike and hoping that it doesn't catch on fire.
Offline chewbacca5000
  • I polish covers!
« Reply #5 on: July 02, 2016, 09:52:52 AM »
I got a nice one out of a 76f with 17,000 miles.   $50 to your door.
Offline RodSOHC750
« Reply #6 on: July 02, 2016, 10:13:57 AM »
Thanks. I was able to make a good one out of three.  None of the three pump lobe tip clearances met the Honda spec of .002 inch.  Most ranged from .004 to .008 inch.  Not much choice since I can't buy new lobes. Picked the smoothest lobes and replaced all rubber parts.
1972 Honda CL450
1970 Honda CT70
« Reply #7 on: July 02, 2016, 08:43:53 PM »
Where did you find a Honda spec of 0.002" for the lobe tips? All my Honda manuals have shown this at 0.0138" since 1970, with up to 0.030" side clearance to the cover/body walls. From experience, I know that once the lobe tips are more than 0.010" the PSI drops to about 55 at hiway speeds on hot days (20w50 oils) and 25-30 PSI at idle (900 RPM) when hot. The only thing that seems to actually impact the oil flow is the side cover clearance: so long as this stays under 0.020" the pumps' overcapacity keeps plenty of oil rolling thru the engines (750 engines, not the 500/550, here...).
