Author Topic: Jakal cb550 project  (Read 46634 times)
Offline Darren Jakal
Re: Jakal cb550 project
« Reply #50 on: January 11, 2017, 06:37:27 AM »
Thanks RAF for the information on the generic MC.
I am really happy to hear that this one may be re-used with a bit of clean-up as it looks pretty much brand new and the fluid looked fine (no sludge), so thanks for that tip Goddfery.
Hey Goddfery is it you that sells the stainless lines? My plan was to replace these, but I haven't gotten around to sourcing them yet, so if you can help with the piston and lines I would be grateful.
Cheers, Darren
Offline Godffery
  • Godffery's Garage
« Reply #51 on: January 11, 2017, 11:35:06 AM »
Cheers, Darren
I sell just about everything (Pistons, Seals, Calipers & Masters) EXCEPT the stainless lines. For that I go to Shawn (fellow SOHC4 member) you can contact him directly at http://www.slingshotcycles.com/
 Here is a link to my Parts & services page: http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/  To order, just email me directly at jstephens7@wi.rr.com
« Reply #52 on: January 11, 2017, 01:07:23 PM »
Jeff's phenolic pistons are pretty cool. Not only do they save some weight, they are nearly indestructible and do not corrode.
Offline Godffery
  • Godffery's Garage
« Reply #53 on: January 11, 2017, 03:27:39 PM »
Well, they can be chipped or scratched before they are installed if you're not careful.  But once they are in, yes, pretty much.
« Reply #54 on: January 11, 2017, 09:08:26 PM »
OK got it Goddfery, thanks for your help. Thanks Fan!
It was slow at work today so I was able to make a centring jig for the turntable and drilled the disc. It went surprisingly easy. Did a little work on the handlebar control switches. Coming along, slow and sure.
Cheers, Darren
« Reply #55 on: January 12, 2017, 05:47:51 AM »
Right. I remember reading about that here, so I did a very minimal de-burr.
Cheers, dj
« Reply #56 on: January 20, 2017, 03:19:04 PM »
Tapered Roller Bearings NOT ALL BALLS
Thanks to everyone that comments in these threads, it’s what makes this place so great. I generally like to do my research and then ask here before I start a project. So now I’m ready to take the bike down to the frame and I’m tackling the steering system next. I might also post specific questions in the main forum.
I have the triple tree out and will remove the races from the frame and steering tube soon. I have new roller bearings from TwoWheelsFrank (also known as Kenosha_kid on ebay) and I’m going through the steps to hopefully do this once and forever.
These bearings are labeled JMT (Hamburg, www.jmproducts.eu) and are called
Lenkkopf-Kegelrollenlager
Steering stem taper roller bearings
The back of the package also says:
Kegelrollenlagersatz SSH 750
Honda
CB 250/350/400/550/650/750
CBX 550 etc
The two bearings are different in diameter and are labeled:
N/H2G4815 (smaller) &
N/H305014 (bigger).
The kit came with a single large washer and no instructions.
I emailed TwoWheelsFrank and he told me that if he remembers right the washer goes beneath the lower bearing. By all the accounts I have seen (ALL BALLS anyway) this appears to be the norm and that is where I will put them unless anyone thinks different.
What the package does NOT contain are any dust seals and this is a question I have.
Should I try and save the old dust seal and reuse it?
Find a new one somewhere?
Make my own?
Don’t worry about it?
Anyway, I’ll take my time and hopefully do it right the first time. I will post updates as they occur and thanks for any help!
Cheers, Darren
« Last Edit: January 20, 2017, 03:38:11 PM by Darren Jakal »
« Reply #57 on: January 24, 2017, 09:37:03 PM »
I've been able to some work done on the bike and it is now down to the frame. The head stock races are removed and I will install the new races once the frame has been finished.
I have also removed the swingarm and the bushings are out. Unfortunately, even though there appears to be low milage on the bike, the swingarm "collar" (as it is known in the parts fiche or also referred to as the pivot) it out of tolerance.
Anyway, I'm looking for either a good used one (there are two used parts places near by and I can measure them in person as I don't like the idea of buying a used part like this online where the specs are pretty tight) or I will find a new one (I have seen some already). If it comes to it I may try to make or modify something to get things to spec, buy buying new old stock would be easiest and it seems possibly an upgrade.
The research I have done (thanks Hondaman) tells me that I have the inferior later style collar with no grease groves and only one grese fitting in the centre of the swing arm.  It looks like any of the older style collars that have grease grooves and use a bolt with grease fittings on either end will work in this bike. The bushing I have bought from TwoWheelsFrank should work on any of the collar styles (looks like 4 different ones in total). This makes me want to find one of the older style ones.
If anyone knows a place with decent prices that ship to Canada I would appreciate hearing about it.
cheers, Darren
Hondaman picture from this thread:
http://forums.sohc4.net/index.php/topic,46432.0.html
« Last Edit: January 24, 2017, 09:39:02 PM by Darren Jakal »
Offline firebane
« Reply #58 on: January 25, 2017, 05:17:18 AM »
Making good progress and I feel you on the cold. Even with a portable heater my shop doesn't warm up.
Would you be interested in drilling another brake disc?
« Reply #59 on: January 25, 2017, 07:11:58 AM »
Hey firebane
I could do some drilling. You supply the drill bits and hopefully don't want some swiss cheese disc (I did 9X3 or 27 holes and it wasn't too bad) and we could work something out.
Later, dj
« Reply #60 on: January 25, 2017, 08:27:36 AM »
looking good, I just caught up on your project...
« Reply #61 on: January 25, 2017, 08:43:16 AM »
Thanks Stev-o
Coming along, slow but steady.
cheers, dj
« Reply #62 on: January 25, 2017, 11:02:17 AM »
Well I was able to find a good used collar (pivot) at my local motorcycle shop. I was surprised to see that it is within specs and for $30 CDN pesos it was a no-brainer.
It is the newer style without the grease grooves, however. Not sure if I will modify it with grooves or go with it as-is with the new bronze bushings. Still time to decide before the bike is on the road.
Later, dj
« Reply #63 on: February 06, 2017, 04:44:36 PM »
The bike is down to the frame, the headstock races are out and I'm waiting until after painting to install the new ones. The swing arm is also off and I have new bronze bushings and a good used collar. I'll install the bushings once the swing arm is finished. I wanted to be able to work on the body parts and well as the front end, so I made a quick front end stand that can be clamped or bolted to a number of objects (bench, saw horse, etc).
I'm also starting to mock-up the seat/rear cowl and I've just started on making a wooden form to build a seat pan on. I'm still working out the basics of the geometry and determining the final body position (seat height, handle bar type using the stock pegs). The form still needs more work, but you can kind of see where it's going. Like Stev-o named his project a "Park Racer" as he isn't racing to cafes, I refer to this build as a "cafe commuter" as I'll use some cafe styling but I don't plan on going too fast.
I've been looking into different types of bars and ergonomics and found some interesting reads. Check this one out:
http://forums.sohc4.net/index.php/topic,116649.0.html
I'll probably mock-up body positions and build some more working models until I find out what works.
Later, dj
« Reply #64 on: February 06, 2017, 06:10:03 PM »
Hi Cal, Thanks for your comments.
So, that's just a wooden form for making a seat pan. The final seat shape will be built on top. I'm building this so that I can make the patterns for cutting the sheet metal and to then use it to form the bends and hold it for tack welding. I'll then pad and upholster it with leather. I like to experiment so I'll try different ways to make a seat and evaluate.
Making the transitions between the the rear cowl, seat and tank in relation to the frame rails is where I will spend some time (I've been shaping the frame a bit in the rear as I like it exposed). These kinds of details makes or breaks a build in my opinion.
Before I go much further I want to get the handlebars so I can get a feeling for the body position(s) and adjust seat height and length (closer to tank or farther away?) as needed (not looking for a hooligan-type posture, but a second position to get low when at speed I think could work with some bending of the elbow).
Right now I'm drawn to the Norman Hyde M Bar, but finding them locally is not easy (I like to see before I buy). There is place in Nova Scotia that has them on their website that I might try.
Anyway, thanks again, Darren
« Reply #65 on: February 06, 2017, 06:57:03 PM »
I have the M bars on my 550F, like them very much
« Reply #66 on: February 06, 2017, 07:07:39 PM »
Good to know you like them Stev-o. I've read a few members comments on them and I can't remember any disappointments.
I'd like to see a pic of the 550F. Love the Park Racer, too.
« Reply #67 on: February 06, 2017, 09:36:11 PM »
It also reminds me of a dirt tracker seat, but with sharper angles.
« Reply #68 on: February 07, 2017, 06:28:46 AM »
Thanks....here's a pic of my 550F, it is a great running bike.
They are not the most comfortable bars but they look good.
Low bars put a lot of pressure on my wrists which I dont like, but it is a good riding position for short periods
« Reply #69 on: February 07, 2017, 08:05:16 AM »
Great info guys! I appreciate your input.
I'm going to mock up the frame with pegs and seat heights to help determine final hand position and then look for appropriate bars.
Cheers, dj
« Reply #70 on: February 07, 2017, 09:54:29 PM »
I'm looking into bike riding postures and what might work for me.
I like my feet under me, I know that.
So, I kind of like the older style of racer stance with feet under the body's centre of gravity with a forward tilt of the upper body at the pelvis, a C-spine and relaxed elbows.
Something like these guys.
« Reply #71 on: February 08, 2017, 05:39:06 AM »
Oddly enough there is a guy who felt part of what made for a bad long distance seat was the fact you aren't holding your weight on your sit bones of the pelvis. His solution was a little unusual. It was a board with a U in the middle to eliminate pressure for that area of the man anatomy that lots of pressure on for an extended period can lead to lots of health problems and discomfort. It works quite well as it distributes the weight to your thighs/sit bones butt but, it presents a problem when approaching a stop. You have to lift up to remove the board. It needs a tether or bungie to pull it back and not let it go flying off the bike. Your legs would not reach the ground because they were being kept up by the board across the seat.
Just a bit of data...regarding seats and long distance rides.
David
« Reply #72 on: February 08, 2017, 07:00:52 AM »
Great advice guys.
I'm planning to pad the seat (the wooden form to make the pan is still too thick and it will be thinned out so more padding can be put in it). I'm thinking with my feet under the centre of gravity the legs can take some of the load.
And it's a commuter so I won't be doing huge long rides (in fact I'm a bit worried that my commute may not be long enough to get the engine hot enough to drive off condensation in the crankcase).
Cheers, dj
« Reply #73 on: February 17, 2017, 05:21:00 PM »
Still working on the seatpan pattern. Pictures show the wooden form being used to create a pattern in card stock. I'll use these patterns to make a mild steel pan.
The wood is just a form, the pan pattern is the card stock (kind of hard to see). Final seat form to be built onto the pan.
Offline firebane
« Reply #74 on: February 17, 2017, 05:31:33 PM »
Great advice guys.
Cheers, dj
We will just get together and go for some good rides
