Author Topic: Ducati forks?  (Read 5184 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Ducati forks?
« on: October 04, 2016, 02:42:59 PM »
Went on a fantastical wild goose chase last night.
Wondering what the possibility if sticking ducati fork tubes and lowers into a cb triple tree were.  Saw some on ebay and other brands use 35mm tubes too.
Are the 35mm ducati forks any better than the old cb?
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Ducati forks?
« Reply #1 on: October 04, 2016, 03:08:14 PM »
I can't imagine a huge increase in performance. The reason most people go with newer forks or GL forks is to get larger diameter for more strength and stability. Sticking with the same diameter forks won't accomplish much.
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #2 on: October 04, 2016, 04:30:13 PM »
Not knowing much about the ducati internals, I had hoped there was a magic gizmo in there that honda left out of the 550 design.
Offline toytuff
  • "watching the pinheads"
Re: Ducati forks?
« Reply #3 on: October 04, 2016, 04:46:52 PM »
Link here with specs.
https://docs.google.com/spreadsheets/d/1keK_LSbg5Co32uRXTnu82Fik4dHShfJOehxW-biA2Aw/pub
Depends on which forks of course. I have a set off a S2R800 sitting in the shed. Had 3K on them when I did my upgrade.
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: Ducati forks?
« Reply #4 on: October 04, 2016, 05:25:23 PM »
The question was specific to 35mm forks TT.
Re: Ducati forks?
« Reply #5 on: October 04, 2016, 06:19:56 PM »
Depends on the forks, which model, sme where Ceriani, some were Marzocchi..
 Do you know year,model, or have a pic ?
If they were Ceriani GP , i wood be all over them..
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #6 on: October 04, 2016, 06:35:42 PM »
There are two sets of marzocchi 35mm ducati forks on ebay right now.
Re: Ducati forks?
« Reply #7 on: October 04, 2016, 06:58:31 PM »
They look pretty good, but
If you search Betor 35mm there is a Set for 100bux and a Husky set for i think 150 or 200.
The cheap set is just north of you at bent bike. Has a BIN on it.
Expect to change springs and make a stem.
« Last Edit: October 04, 2016, 07:01:36 PM by 754 »
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #8 on: October 04, 2016, 07:03:50 PM »
Part of the (youthful) hope was to retain the stock trees and controls/cluster of the cb.  And simply slip the new tubes and lowers onto the bike with an appropriate wheel setup etc.
Re: Ducati forks?
« Reply #9 on: October 04, 2016, 07:07:46 PM »
Usually the trees on those forks are lighter and much better looking,,build the guage bracket, and maybe steering stop. That Husky one, nothing to mount a disc brake, the other has mounts on one side so probably doable.
« Last Edit: October 04, 2016, 07:10:05 PM by 754 »
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #10 on: October 04, 2016, 08:05:56 PM »
At that point, may as well consider the gsxr/cbr/wang swaps.
One of these days I'll dig in deep on a build.  That day is not today.
Re: Ducati forks?
« Reply #11 on: October 04, 2016, 08:22:16 PM »
Instrument bracket... Handdrill,  a few files , hacksaw, and a few beers .
 Stem should be under a hundred, at lest the ones i made.
But if you get early CanAm betor legs with fender mounts, use you heavy trees,
The Marz are easier to mount brakes. To but way more money.
Which brakes were you thinking of using ?
« Last Edit: October 04, 2016, 08:26:22 PM by 754 »
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #12 on: October 04, 2016, 08:42:46 PM »
I'd be hopefull to get an aft mounted brake.  Since the forward mounted brake on the cb is notoriously squeaky.
Re: Ducati forks?
« Reply #13 on: October 05, 2016, 09:08:54 PM »
You can easily turn yours around , and go dual disc but they are heavy .which fork do you have now ? How many bolts hold the caliper bracket on ?
You mentioned in another post you had bushings, so It sounds like you have early forks with the C bracket mounting the caliper to the fork.
Almost any fork will work better than the sohc 750 forks.
« Last Edit: October 05, 2016, 09:14:38 PM by 754 »
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #14 on: October 05, 2016, 11:55:26 PM »
The aft mount mod is journaled here somewhere.
I need to check that brake disc for age/wear, i'll look in the daylight
Offline DaveBarbier
Re: Ducati forks?
« Reply #15 on: October 06, 2016, 04:31:02 AM »
Aft mounted is as squeaky in my experience. I think it mainly comes down to pad make up and vibration damping. Though I'm using EBC pads, maybe OEM is less prone to the squeal?
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #16 on: October 06, 2016, 10:01:29 AM »
Who knows, the caliper arm and fork leg setup probably act as some sort of tone arm and primitive phonograph combined
Offline DaveBarbier
Re: Ducati forks?
« Reply #17 on: October 06, 2016, 02:11:13 PM »
Is this the beginning of the SOHC4 band?
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #18 on: October 06, 2016, 03:32:04 PM »
If we can tune our brakes to the same relative tone scale maybe.  Nutcracker suite anyone?
Offline DaveBarbier
Re: Ducati forks?
« Reply #19 on: October 06, 2016, 03:36:04 PM »
I think we should start slow. Chopsticks maybe...Japanese bikes and all.
  • Holy Cow! I'm a
Re: Ducati forks?
« Reply #20 on: October 07, 2016, 12:21:09 AM »
Someone has to play the wheel spokes  ;D for effect
Offline DaveBarbier
Re: Ducati forks?
« Reply #21 on: October 07, 2016, 04:09:58 AM »
Haha, yes that's perfect
