Author Topic: Cr 750 conrods  (Read 3246 times)
Offline garyhcb750
Cr 750 conrods
« on: October 14, 2016, 01:19:37 PM »
Anyone know these conrods? I want to use them in a modified CB 750 SOHC motor. Were they made for the original CR 750 motors?
Re: Cr 750 conrods
« Reply #1 on: October 15, 2016, 06:07:29 AM »
Junk. I have one set and one of the big ends has 3 bearing tang slots. ::)
Re: Cr 750 conrods
« Reply #2 on: October 15, 2016, 11:19:16 AM »
I have 6 of them and can't get a set of 4 with similar enough weights. They are NOT HONDA CR rods.
Offline Nose736
Re: Cr 750 conrods
« Reply #3 on: March 25, 2017, 11:57:38 AM »
If your going to use them I would have them re-balanced, Should be able to get them within 1/10th of a gram.
Online PeWe
Re: Cr 750 conrods
« Reply #4 on: March 25, 2017, 02:15:34 PM »
Are these rods old from the 70's or new cheap and poorly made  in china and similar stuff?
Re: Cr 750 conrods
« Reply #5 on: March 25, 2017, 03:23:14 PM »
They are garbage. OK if you want to make some kind of internal combustion artwork Per.
Offline Big Jay
    • CBRzone
Re: Cr 750 conrods
« Reply #6 on: March 25, 2017, 11:48:15 PM »
New rod coming by the summer. Stay tuned.
Online PeWe
Re: Cr 750 conrods
« Reply #7 on: March 26, 2017, 03:28:14 AM »
Aha, I saw an ongoing engine build with those in this winter. It is assembled now. 836 with ported head, cam. I hope not weaker than CB750 OEM. If weather will be warm enough for a ride I might visit the guy.
The head was beautifully ported with other inlet spigots.
Re: Cr 750 conrods
« Reply #8 on: March 26, 2017, 06:11:39 AM »
One can only hope Per. It's all about the bolts....the ones in those rods look crude. Plus the rods themselves are heavy. A reworked OEM rod (polished, balanced, shot peened ) with late style bolts would be a better option IMO.
Online PeWe
Re: Cr 750 conrods
« Reply #9 on: March 26, 2017, 09:39:44 AM »
OK, that sounds bad. He should open the  lower case and replace rod bolts with F2 version then....
For power monster  engines or something between OEM and Carillo?
A relatively cheap and durable combo with balanced crank would be fine. If slightly lightened even better ;)
« Last Edit: March 26, 2017, 09:43:21 AM by PeWe »
Re: Cr 750 conrods
« Reply #10 on: March 30, 2017, 03:21:18 PM »
Any info you can give as to how they compare to Carrillos or Cycle X Super Rods?
Online PeWe
Re: Cr 750 conrods
« Reply #11 on: March 31, 2017, 05:56:47 AM »
Hopefully a good and low cost setup. My APE crank in my K6 is very addictive. Difficult to close the cases in my next K2 project with std crank/rods
