Author Topic: Caliper Piston  (Read 6922 times)
Offline grcamna2
Re: Caliper Piston
« Reply #50 on: January 09, 2017, 06:30:24 AM »
Jeff,
I want to order one,can I call tomorrow/Mon. morn.? or should i only email ?
 Email works best.
[/quote]
I just sent you an email
75' CB400F/'bunch o' parts'
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #51 on: January 09, 2017, 12:59:30 PM »
 While we're on the subject of updating these old calipers, I figure I'll throw this in just for a FYI:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/Anti+squeal+Brake+stabilizing+Insulators_001/
Offline SF
  • I burn gas very well
Re: Caliper Piston
« Reply #52 on: January 09, 2017, 08:32:21 PM »
For you triple guys out there Godffery redid the dual set up on my S2
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline grcamna2
Re: Caliper Piston
« Reply #53 on: January 10, 2017, 07:40:00 PM »
Thank you Jeff for another of your fine quality products,payment sent.
Offline grcamna2
Re: Caliper Piston
« Reply #54 on: January 13, 2017, 11:38:54 AM »
I just received my Phenolic 38mm caliper piston today from godffery  :) Thanks again Jeff !
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #55 on: January 13, 2017, 07:04:43 PM »
 Glad I could help buddy!
BTW; I was out of Insulation instruction sheets when I shipped yours, so here is a copy:
A new Seal is recommended at this time.  Before installing the new Phenolic Brake Piston, be sure to clean the seal groove thoroughly so the seal will seat properly.
(A 90° pick tool works well for removing thick buildup or corrosion in the grove)
Install the Piston into the Caliper with the Open end facing out so it will be in contact with the Brake pad.
 ** DO NOT use the OEM plastic “isolation Washer” between the brake pad and the new Phenolic Piston **
The back of the brake pad should sit flat on the open end of the new Piston. The pad should NOT “rock” on the piston, but contact squarely. Clean any rust or foreign materials off the back side of the brake pad if not replacing with new.
   Attention!
For 69 to 76 models CB750K - Do not use steel cap from stock brake piston;
This new PHENOLIC Replacement brake piston is designed to eliminate the need for the cap.
 Safety First… After installation, reassemble and bleeding, carefully test the braking system to make sure everything is performing properly BEFORE riding.
Offline grcamna2
Re: Caliper Piston
« Reply #56 on: January 14, 2017, 06:57:47 PM »
   Attention!
I appreciate that Jeff  ;)
