Author Topic: Caliper Piston  (Read 6832 times)
Re: Caliper Piston
« Reply #25 on: January 04, 2017, 06:22:12 PM »
I've got accurate weights of some brake components:
Late 750 42.8mm piston: 215 grams (7.58 oz) Phenolic equivalent: 85 grams (3 oz)
Early 750 38mm piston with domed cap: 202 grams (7.12 oz)
550 38mm piston: 165 grams (5.82 oz)
550 rotor: 2,474 grams (5.455 lbs)
750 rotor: too heavy for my scale, but 6.5 lbs on the scale at the post office. ;)
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #26 on: January 04, 2017, 08:09:40 PM »
Groovy, Thanks!
I got'a get me a decent scale. =\
Re: Caliper Piston
« Reply #27 on: January 04, 2017, 08:13:48 PM »
Thank you Jeff, for the phenolic pistons!! ;D
Re: Caliper Piston
« Reply #28 on: January 04, 2017, 08:49:07 PM »
I just use a triple beam, they seem to be cheap, the model i got but only weighs 599 grams.
Used to work next door to a guy with killer digitals..
Re: Caliper Piston
« Reply #29 on: January 04, 2017, 09:03:37 PM »
Frank, my triple beam goes up to 610 grams, but with optional counter-weights goes up to 2610. I made my own 500 and 1000 gram counter-weights, calibrating them with 500 gram weighed standards.
Re: Caliper Piston
« Reply #30 on: January 04, 2017, 09:07:32 PM »
Where do you hang the counterweights, what do they look like ?
Re: Caliper Piston
« Reply #31 on: January 04, 2017, 09:11:12 PM »
I'll start a new thread with pics tomorrow. ;)
Re: Caliper Piston
« Reply #32 on: January 04, 2017, 09:43:40 PM »
Piston seal then? Will it survive longer with a specific piston?
Re: Caliper Piston
« Reply #33 on: January 04, 2017, 10:47:37 PM »
There are aftermarket seals for the 38mm pistons and they are a couple $ cheaper than Honda OEM.  OEM the last time I priced it was under $10.
South Sound Honda in Olympia, Washington area is a dealer that ships inexpensively and  offers a very good discount.  Likely cheaper than a generic aftermarket piston seal.
Offline grcamna2
Re: Caliper Piston
« Reply #34 on: January 05, 2017, 08:15:44 AM »
I think you're asking how smooth the sliding surface of the Phenolic piston is(shiny or glossy?)compared to the stock Honda steel piston ? godffery,do you have any pics of your Phenolic ?
75' CB400F/'bunch o' parts'
Re: Caliper Piston
« Reply #35 on: January 05, 2017, 08:40:35 AM »
Piston seal life should be similar if not same, it is a smooth polished surface, not high gloss but a gloss.
Wish they had the phenolic piston for the common dual piston caliper used by lots of 80s and some 90s bikes.
Offline strynboen
Re: Caliper Piston
« Reply #36 on: January 05, 2017, 12:22:32 PM »
have made some rustfree steel pistons..drilled aut and turned the inside diameter..massive is just to heavy...and hold the heat in the system..so it vill boil the fluid..not bu first stop..but at the time you not vant it to fade
i hate all this v-w.... vords
Offline strynboen
Re: Caliper Piston
« Reply #37 on: January 05, 2017, 12:24:07 PM »
after have maked the inner diameter..i made a shaft..and glued the piston on that...and then made the autside diameter and the groove for the dust seal..running at a dummy shaft...after the lathe vork the pistons need some polishing..to run smooth in the bore
the seal vill hold to the rubber gets old..and not return the piston so vell..theu dont Wear aut..
..pistons get rusty..and get pittet...so they grow stock in the bore(korodes )
« Last Edit: January 05, 2017, 12:31:22 PM by strynboen »
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #38 on: January 05, 2017, 08:41:37 PM »
Hello,
I would imagine the seal would last AT LEAST as long with the Phenolic piston, as it would with the steel. Theoretically it should last LONGER due to the complete lack of corrosion & there ultra smooth OD?  To be honest, in all the years I have been using these, I have never had to replace a seal with one yet.
 Here is a link to all the photos I have for the full list of Pistons I make:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/
Re: Caliper Piston
« Reply #39 on: January 05, 2017, 09:34:14 PM »
Hey Jeff would love to see you find the dual piston caliper size for the commonly used in 80s on Honda bikes.
David
Offline robvangulik
  • Honda Fourever
Re: Caliper Piston
« Reply #40 on: January 06, 2017, 02:54:28 AM »
David
Same for my 30mm CBR pistons, I'd take eight at once!
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #41 on: January 07, 2017, 06:27:25 PM »
David
I had considered those, just was not sure how much of a call I would get for them?
I have batches of some Suzuki & Yamaha Pistons that have yes to sell a single one of.  That gets pretty costly to sit on.  =/
« Last Edit: January 07, 2017, 06:29:19 PM by Godffery »
Re: Caliper Piston
« Reply #42 on: January 07, 2017, 09:06:33 PM »
Jeff, how many would you need orders for to get a batch.  It would require the right FB page and some forums where those calipers were used and you could get some pull for them started.  Tons of bikes in late 70s and 80s (honda) used those pistons.  So, there is a market you have to tap into. Get the search engines to pickup your pistons and then put a few out for samples to some builders of note who do cb and other Honda bikes and it will get noticed. Dual piston caliper with semi sinstered pads are vast improvement.
David
Offline rocket johnny
Re: Caliper Piston
« Reply #43 on: January 08, 2017, 09:07:59 AM »
  :)  i bought one from vintage cb750   it was 35.00
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #44 on: January 08, 2017, 05:38:30 PM »
David
About 24 or so would be needed to spread out the first run design & set up costs.
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #45 on: January 08, 2017, 05:39:27 PM »
In Phenolic, of just metal?
Re: Caliper Piston
« Reply #46 on: January 08, 2017, 06:18:20 PM »
$35 would be a metal piston, likely a K&L brand.  He countered that 4 into 1 had a piston for the caliper for the twin pot caliper.  They do not carry a phenolic piston.
I did not specify and he did not get my implication of phenolic, given you are the only source for them.
David
Offline grcamna2
Re: Caliper Piston
« Reply #47 on: January 08, 2017, 06:18:41 PM »
I just looked on their site and only noticed steel caliper pistons avail.
Jeff,
I want to order one,can I call tomorrow/Mon. morn.? or should i only email ?
« Last Edit: January 08, 2017, 06:22:02 PM by grcamna2 »
Re: Caliper Piston
« Reply #48 on: January 08, 2017, 06:19:52 PM »
Sorry, not 4 into 1 but vintagecb750.
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #49 on: January 08, 2017, 09:28:04 PM »
Jeff,
[/quote]
 Email works best.
« Last Edit: January 08, 2017, 09:30:29 PM by Godffery »
