Author Topic: Caliper Piston  (Read 6948 times)
Offline Johnie
Caliper Piston
« on: January 03, 2017, 01:34:07 PM »
Who is the member that sells new caliper pistons?
Thanks
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline grcamna2
Re: Caliper Piston
« Reply #1 on: January 03, 2017, 01:37:42 PM »
Thanks
Johnie,
I know that godfferry sells a much lighter version that will improve handling by lowering unsprung weight & I plan on getting one;I think he also may sell others,he sold me a used oem replacement piston.
75' CB400F/'bunch o' parts'
Offline Johnie
Re: Caliper Piston
« Reply #2 on: January 03, 2017, 01:51:14 PM »
Thanks Bill...will check him out.
Oshkosh, WI  USA
Offline grcamna2
Re: Caliper Piston
« Reply #3 on: January 03, 2017, 02:37:21 PM »
Johnie,
I messed-up on spelling his forum name,it's: 'godffery'
Offline jamesw
Re: Caliper Piston
« Reply #4 on: January 03, 2017, 02:50:22 PM »
I got mine from JT Marks.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline Johnie
Re: Caliper Piston
« Reply #5 on: January 03, 2017, 02:52:43 PM »
Thanks Bill...I got it from the members list. Found out he is located not far from me.
Oshkosh, WI  USA
Offline 540nova
Re: Caliper Piston
« Reply #6 on: January 03, 2017, 03:40:57 PM »
Thanks
Johnie,
Improved handling? That's a stretch.
Offline grcamna2
Re: Caliper Piston
« Reply #7 on: January 03, 2017, 03:46:03 PM »
Thanks
Johnie,
You don't think so ?  Any reduction in the 'unsprung weight' of the wheels or suspension components that're attached to the wheels improves handling in vehicles and less 'spinning flywheel weight' equals quicker acceleration;similar to running w/ heavy boots or trousers on compared to shorts and lightweight track shoes.  ;)
Do a Google search on it then see if you still doubt it.. or better yet install some weights to your lower fork legs and take it for a fast ride on your favorite twisty,winding road,then take the weights off of the lower fork legs and do that same ride again and tell me which way is better for you.
« Last Edit: January 04, 2017, 08:21:12 PM by grcamna2 »
Re: Caliper Piston
« Reply #8 on: January 03, 2017, 03:53:05 PM »
+1 on godffery, good, fair seller.
Offline 540nova
Re: Caliper Piston
« Reply #9 on: January 03, 2017, 05:17:34 PM »
Grcamna2, I understand about sprung and unsprung weight, and technically, you're absolutely correct. I just don't believe that there is enough weight difference for the average rider to tell a difference.
Offline grcamna2
Re: Caliper Piston
« Reply #10 on: January 03, 2017, 05:22:16 PM »
I imagine it would depend on how bad the terrain is and how fast the vehicle is moving.
Offline AlabamaCB750
  • Competent CB750K2 Owner
Re: Caliper Piston
« Reply #11 on: January 03, 2017, 07:37:38 PM »
Plus, the difference in unsprung weight would be about the same as cleaning your wheels...just saying...
Offline jonda500
Re: Caliper Piston
« Reply #12 on: January 03, 2017, 08:07:31 PM »
I have solid stainless steel pistons in my bikes- they are a LOT heavier than the hollow oem ones - had I realised this I probably wouldn't have bought 3 of them!
I can't say i've noticed any difference in handling though,
John
A starter clutch thread:
Offline grcamna2
Re: Caliper Piston
« Reply #13 on: January 03, 2017, 08:28:42 PM »
When I spoke w/ godffery/Jeff he told me that there's the difference of a couple pounds of weight between the stock and his 'Phenolic' front caliper piston,if I remember correctly..
Re: Caliper Piston
« Reply #14 on: January 03, 2017, 09:21:36 PM »
There can be no way that there is a 2 pound weight savings between the two pistons. My Oem piston doesn't weigh 2 pounds by itself!
Re: Caliper Piston
« Reply #15 on: January 04, 2017, 01:35:12 AM »
The benefit of the phenolic is less heat transmitted to the brake fluid and it will not pit from rust.
Offline grcamna2
Re: Caliper Piston
« Reply #16 on: January 04, 2017, 05:58:22 AM »
Let's hear from Jeff/godffery.
Re: Caliper Piston
« Reply #17 on: January 04, 2017, 11:46:48 AM »
I will post the weight of a German stainless piston from AllenBolt Frank...shortly..
With lightened drilled discs and lighter pistons, it could be two lbs.
** Stainless hollow for 750 is 150.5 grams.
« Last Edit: January 04, 2017, 12:21:55 PM by 754 »
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #18 on: January 04, 2017, 12:09:42 PM »
 Hey Gang,
I was pointed to this discussion and thought I would try to help some with the details that I have for my parts.
 The Stock pistons weigh about 7 ounces and My Phenolic Pistons are about 2.5 ounces.
(+or- because I have a cheep scale) =)
 The Stock 550 Rotors are about 6 pounds (plus some for the 750) and my Drilled & thinning process takes them down to about 3.5 pounds.
Offline grcamna2
Re: Caliper Piston
« Reply #19 on: January 04, 2017, 01:09:09 PM »
I apologize for making a mistake on the weight of the caliper piston,I was 'weigh/Way'! off on that one  :o ::) :-[
I want to save as much weight on those parts as i can and misunderstood what godffery told me...
« Last Edit: January 04, 2017, 01:14:55 PM by grcamna2 »
Offline grcamna2
Re: Caliper Piston
« Reply #20 on: January 04, 2017, 01:12:58 PM »
Offline Johnie
Re: Caliper Piston
« Reply #21 on: January 04, 2017, 01:39:38 PM »
Jeff was very helpful and shipped same day. Good seller and a benefit to our board and bikes. Thanks Jeff.
Oshkosh, WI  USA
Re: Caliper Piston
« Reply #22 on: January 04, 2017, 02:20:44 PM »
How much do the caliper pistons cost ?
Offline Johnie
Re: Caliper Piston
« Reply #23 on: January 04, 2017, 02:26:32 PM »
Total with shipping was $52.69.
Oshkosh, WI  USA
Offline Godffery
  • Godffery's Garage
Re: Caliper Piston
« Reply #24 on: January 04, 2017, 02:31:43 PM »
They are $44 each + shipping to where ever you are.  =D
Here is a link to my web site: http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/  for the brake parts, click on the parts & service album.
(FYI; it's not set up for direct purchase off the site, To order send an email at jstephens7@wi.rr.com ).
