Author Topic: Desperately need a CB500 Clutch Pushrod (advicell needed)  (Read 3569 times)
Offline etout00
« on: March 20, 2017, 06:04:53 PM »
Sure enough, I pulled out my clutch push rod and it's broken in 2 pieces (73 CB500). The bike was shifting fine before I pulled the cover off to polish it....but none the less, the clutch pushrod is broken in 2 pieces (nice clean break).
Does anyone have a source for these or custom make them?
Honda Part # 22850-323-000
Offline drumstyx
Re: Desperately need a CB500 Clutch Pushrod (advicell needed)
« Reply #1 on: March 20, 2017, 06:08:29 PM »
Offline etout00
« Reply #2 on: March 21, 2017, 04:51:27 AM »
Thanks or the reply. I saw that post as well from last year mentioning DSS having stock....but they are sold out unfortunately.
Did anyone decide to make their own? I saw a few posts where members were planning on machining a few to sell?
« Reply #3 on: March 21, 2017, 06:32:07 AM »
 Looks like the same rod was used on a couple different models if your searching on E-bay. Might find one of these out there-- http://www.chinonthetank.com/2011/02/cb500-clutch-rod-replacement/
Offline etout00
« Reply #5 on: March 21, 2017, 06:54:07 AM »
Thanks for all the advice....it looks like there are a few options for CB450 and CL450 push rods on EBay if they are in fact a direct fit?
Offline Deltarider
  • I'm back
« Reply #6 on: March 21, 2017, 07:36:54 AM »
Then... why bother and not leave it as it is? Look... you now have two pushrods.  ;)
« Last Edit: March 21, 2017, 07:58:05 AM by Deltarider »
CB500K2-ED Excel black
Offline Smudgemo
  • Maker of Stuff
« Reply #7 on: March 21, 2017, 08:20:31 AM »
Probably only worthwhile if you've got a lathe and a torch, but I think I'd try brazing it together.  Maybe drill a bit out of each section and insert a pin before brazing it.  I'd give yours a go if you were close by and didn't care what the end result was (since it's already no good.)
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline BassHog
« Reply #8 on: March 21, 2017, 10:53:02 AM »
Why not just get a piece of 8mm Stainless Steel rod and cut to length and round off one end?
Somewhere around here I saw a length of 255mm posted. Check that though, I could be wrong.
I know you can pick up 12 inch lengths of 8mm rod for pretty cheap, like less than $5. 255mm is a tad longer than 10 inches so it should be plenty.
Offline Bailgang
  • Scott
  • Indiana
« Reply #9 on: March 21, 2017, 02:23:45 PM »
I used 2 pushrods from an old Pontiac V8, I used a steel pin where the 2 pieces met to keep them concentric and straight, welded it up and turned the weld down on my lathe. The Pontiac pushrods were about .002" bigger in dia than the original cb500 pushrod but worked perfectly.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #10 on: March 21, 2017, 04:14:59 PM »
You guys sound like a bunch of cheap skates. It's only a $50 part...spend the money and do it right!
Offline drumstyx
« Reply #11 on: March 21, 2017, 05:15:45 PM »
*only*....I mean, is there any reason not to use any old rod? I use generic 6mm nuts and bolts all the time (not 8mm though, they're 13mm heads unless you get them from the dealer)
Offline 78whiteorbs
« Reply #12 on: March 21, 2017, 05:33:10 PM »
^ +1
Offline Smudgemo
  • Maker of Stuff
« Reply #13 on: March 21, 2017, 06:40:52 PM »
And proud of it!  Plus I just like to see if I can fix things.
-Ryan
« Reply #14 on: March 21, 2017, 08:29:36 PM »
I can respect that but do you have a torch and a lathe to make a proper repair?
Offline Smudgemo
  • Maker of Stuff
« Reply #15 on: March 21, 2017, 08:41:26 PM »
Indeed, plus a few other items that would be useful for this sort of fix.  I actually very much enjoy brazing and occasionally gas welding.
-Ryan
Offline Moosey
« Reply #16 on: June 04, 2017, 02:18:13 PM »
I just took apart my cb500 and I have one in great shape. It came off of a 1971.  $30 plus shipping.
Offline jonda500
« Reply #17 on: June 04, 2017, 05:10:09 PM »
This seller has one.  I have bought other parts from him.  Make an offer...
http://www.ebay.com/itm/OEM-Honda-Clutch-Lifter-Rod-CB450-CL450-CB500-CB500T-CB500K-22850-323-000-NOS-/192124351864?hash=item2cbb80f578:g:T~wAAOSwWxNYwEeZ&vxp=mtr
When I first saw this link, I immediately grabbed one of these new alloy ones just in time before they swiftly sold out - I have two spare broken ones, they can work fine but can also get jammed. I now also have a spare steel one if there's more than one person interested in procuring one, John
A starter clutch thread:
Offline etout00
« Reply #18 on: June 04, 2017, 06:00:14 PM »
I ended up getting a CL450 pushrod on eBay, which seemed to fit just fine. I haven't tested it on a ride yet though as I'm still in the middle of my restore.
Anyone else use a CL450/CB450 pushrod?
Offline jonda500
« Reply #19 on: June 04, 2017, 07:19:01 PM »
I believe the 450/500 twins used the exact same pushrod with the same part number (22850-323-000). The ones I have vary in length slightly, but there is more than enough adjustment available to make up for the differing lengths.
John
Offline Gman
« Reply #20 on: June 04, 2017, 07:36:20 PM »
Check the for sale - Moosey has a cb500 pushrod for sale.
http://forums.sohc4.net/index.php/topic,166242.0.html
Peace,
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline HondaYo
« Reply #21 on: June 06, 2017, 12:15:52 AM »
Me and my dad made one from 8 mm roundbar for my K1 and I´ve clutched my bike for about 800 km, no worries. Not sure about the length though. If I recall mine is 265....but I´ve been wrong once before...I´m told
Offline Deltarider
  • I'm back
« Reply #22 on: June 06, 2017, 05:41:55 AM »
If you make your own, make sure you use hard iron and not stainless steel (too soft). The hardened steel on the end of the original aluminium Honda pushrod is there for a reason. It takes quite a load.
Offline Smudgemo
  • Maker of Stuff
« Reply #23 on: June 06, 2017, 11:10:11 AM »
Drill rod is a very consistent diameter material, comes in 8mm, is machinable and could be hardened at the ends w/o much trouble.
-Ryan
