Author Topic: When compressed air ain't enough..  (Read 12768 times)
Re: When compressed air ain't enough..
« Reply #50 on: May 29, 2017, 06:52:34 PM »
I think the MC will go way higher than that. Terry if you pump repeatedly, and dont blow up any seal it will make more pressure.
Had to do it on a master cylinder, think it was coming out the feed hole.
You know those grotty rear MC,s on the F model.. The ones where the snapring and washer are a rusted together blob......them ones.
« Reply #51 on: May 29, 2017, 06:52:50 PM »
Terry, go stand in the corner. >:( The OP used his MC with a minor leak to pump the piston out. :D
« Reply #52 on: May 29, 2017, 07:19:14 PM »
Oh no, I'm getting the "Pete treatment"! Come back Pete, I'm no good at confrontations! ;D
« Reply #53 on: May 29, 2017, 07:22:39 PM »
I've had my '72 Honda XL250 cafe' in long term storage for the past six years.
That is a sweet looking bike, but I would think it's more of a late '60s TT style than cafe. The hump seats were called TT seats back in the days before Carpy. ;D
« Reply #54 on: May 29, 2017, 09:07:01 PM »
Doesn't WD40 have silicone in it?  That could contaminate your brake fluid, DOT 3 or 4 do not like silicone.  But, whatever works for you...
Another trick with stuck rusty fastener, etc.  If you can immerse it in a pan you can melt paraffin wax (the kind used with canning - Gulf is one brand) Use a double boiler and recommend you do it outside on a grill.  The wax is dangerous as it can give you a severe burn and water in the wax pot can cause the wax to splash out.  By double burner you boil water and use the steam to melt the wax you cut up into strips so it can melt easier.  More surface area is why you cut it into pieces.  "Boil" the part in the hot liquid wax for about 30 minutes.  Don't boil your water away...
The wax will wick its way into the rusty parts and usually it will allow the parts to unscrew or be separated if a sliding fit.  Just let it cool enough to handle with heavy padded gloves or with tongs to move it to a vice or other fixture to unscrew or push it apart.  It works when penetrating oil and heat don't get it done.  The wax also tends to leave a light film making it to unscrew of be separated.
You can use other objects in the pot to take up more space so it does not require as much wax.
David
« Reply #55 on: May 30, 2017, 01:36:39 AM »
You better come and stand in the dummkopf corner with me mate, because, according to the WD40 website, "While the ingredients in WD-40® Multi-Use Product are secret, we can tell you what it does NOT contain. WD-40® Multi-Use Product does not contain silicone, kerosene, water, graphite, or chlorofluorocarbons (CFCs)."
https://wd40.com/faqs
See, the internet makes you smarter.......... ;D
Offline Lostboy Steve
« Reply #56 on: May 30, 2017, 03:17:48 AM »
David
Yes, I just learned this trick the other day. Very cool.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Jimray23
    • none
« Reply #57 on: May 30, 2017, 04:54:53 AM »
Back when i use to trap for fur, we put the wax straight in the pot of water; brought it to a boil and put the trap in. That way it still penetrated the the springs and jaws but left less build up
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline nvr2old
« Reply #58 on: May 30, 2017, 09:36:36 AM »
Actually the leaking mc wouldn't originally push the piston and pad out.  I swapped a new one in place with the combination of penetrating oil to finally get it move.
Thanks also for the kind words on the bike.  It was a totally thrashed and stripped down woods bike that a friend gave me, free.  Everything was in need of repair, except the engine which had been bored out to a 305cc with a mild cam.  It ran great, looked like hell.  I originally had it set up as a retro motard with a thicker seat and motocross bars.  Rode it that way for a couple of years before changing it to more of a cafe' style.  The tail piece is either loved or reviled by people, but it was a ton of work to make it fit, so I'll keep it.  :)
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
« Reply #59 on: May 30, 2017, 01:56:54 PM »
See that's what I thought you meant mate, before Scott sent me to the corner! Free at last, free at last! ;D
« Reply #60 on: May 30, 2017, 02:06:34 PM »
How fast can the 305 go ? I got a XL 410 cc.
 My buddy has a XXL , its 480 cc....
« Reply #61 on: May 30, 2017, 02:22:18 PM »
You'd need a XXXXXL wouldn't you Frank? ;D
Offline nvr2old
« Reply #62 on: May 30, 2017, 04:52:17 PM »
According to the CB550 speedo, it hits..80-85mph.  It's sweet spot is 65, though.  It'll run down the freeway, but it's such a small bike it feels scary to be surrounded by cars on it.  It handles great on back road twisties which is pretty much where it belongs.
« Reply #63 on: May 30, 2017, 05:08:28 PM »
They're great fun, I've got a 1983 XR500R with 41 BHP. It'll easily do the ton, and it doesn't weigh much more than me! ;D
Offline SKTP
« Reply #64 on: May 30, 2017, 05:18:22 PM »
Why not just pump it out with brake fluid?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #65 on: May 30, 2017, 05:25:54 PM »
Shade tree actions rule.
What are you? Vulcan?  That is simply too logical for earthlings.
« Reply #66 on: May 30, 2017, 05:59:23 PM »
If the master cylinder is working. Sometimes as we all know when work begins for restore on an old abandoned bike that has sat for years most anything with fluid such as brakes are going to be in sad shape and need a rebuild or major attention. I use the master and fluid to remove the pads/pistons on roadworthy machines whenever possible but it is not always a quick and easy available option to break down an old caliper for resto prep on certain project examples.
« Last Edit: May 30, 2017, 06:01:49 PM by ekpent »
« Reply #67 on: May 30, 2017, 06:06:49 PM »
Yep, this whole thread started because the OP couldn't pump it out with his leaking MC....... ;D
« Reply #68 on: May 30, 2017, 06:18:21 PM »
Well he wasn't going to use his rebuilt caliper with the leaking mc, was he?  So overhaul the mc first.  Then pump out the caliper piston with the now non- leaking mc.
No air cannons or grease glob fittings required.  I wonder if there is a Jeff Foxworthy joke in there somewhere?
« Reply #69 on: May 30, 2017, 06:32:44 PM »
I have two grease adaptors.. I use them on the bench..bike would likely be outside somewhere.
Or a cusomer brought in the caliper, or I found it in a box somewhere, or laying in the dirt at the boneyard..
Not worth blowing out an aging caliper to me, to find out.. I have seen them heal up , but not by running at max pressure..
 If anyone needs stock mc cores, i have lots,. Would like to sell quantity..
« Reply #70 on: May 30, 2017, 06:37:50 PM »
Yep, it must be wonderful to live in a perfect world........  ::)
Offline jonda500
« Reply #71 on: May 30, 2017, 06:44:53 PM »
Sounds like some members may be lacking in their hoarding skills - I have 5 spare masters & four of them are still able to pump fluid, so I have never needed to fill any of my callipers with grease :)
A starter clutch thread:
« Reply #72 on: May 30, 2017, 06:59:57 PM »
Cheaper to replace a 12.00 grease gun, than have to buy an Mc kit..
 Oh wait, the grease gun hasnt broke.
I have lost sales due to removing stuck pistons to find out they are bad....better though than selling a shipoing one that they have trouble getting apart, only to find out its not useable..
 But that was just part of the service I provide.
« Reply #73 on: May 30, 2017, 07:20:42 PM »
Then there is the sensual elation of writhing about in grease, not to be confused with Greece.  Which is a quite different experience.  Who doesn't enjoy a good mud wrestling bout, eh?  Even a mini encounter is so ... Ooo....ahh slippery.  Got to be womanly bits in here somewhere nostalgia.  And then in the afterglow, there is the heady, intoxicating aromas of cleaning solvents AND grease while visiting the disposal pit.  Ahh good times.
Posted for your humorous enjoyment.
Lloyd, you have a sick mind.. ::)
« Reply #74 on: May 30, 2017, 08:38:42 PM »
personally would much rather writhe about in grease than brake fluid...so don't try to tell me there is anything "neat" or "clean" about brake fluid splashing all over the place.  Brake fluid gives me the creeps and the less I have to touch it, the happier I am.
