Author Topic: 1975 CB550 "Jocelyne"  (Read 8377 times)
Offline Camrector
Re: 1975 CB550 "Jocelyne"
« Reply #25 on: September 08, 2017, 04:27:53 PM »
Yes and Yes!!^^^
« Reply #26 on: September 08, 2017, 06:46:04 PM »
See that. Customers waiting!
Offline SHORTROUND
« Reply #27 on: September 09, 2017, 08:17:40 AM »
Any thoughts to make and sell these parts?
I still have the molds for the ignition switch, front fender, rear hugger, and seat. These parts are 100% carbon fiber. No layers of fiberglass to add thickness. Most people wouldn't pay what's it worth for me to go through the trouble.  The seat weighs less than the four seat bolts that hold it down.
Offline SHORTROUND
« Reply #28 on: September 09, 2017, 08:18:54 AM »
One more before Irma gets here.
Offline innovativems
    • Innovative MotoSports
« Reply #29 on: September 09, 2017, 08:26:28 AM »
Amazing work.  Can you post a pic of your hugger?
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline SHORTROUND
« Reply #30 on: September 09, 2017, 08:57:45 AM »
Trimmed and sanded awaiting clear.
Offline Camrector
« Reply #31 on: September 09, 2017, 09:57:11 AM »
Short round, we are not "most people" I'll take a seat, rear hugger x2, and let's talk about a tank and this airbox!
Offline SHORTROUND
« Reply #32 on: September 09, 2017, 10:20:30 AM »
Sorry. I didn't mean to imply you guys are "most people". Air box would be tricky. Especially since I don't have one. Rest is easy.
Offline SHORTROUND
« Reply #33 on: September 09, 2017, 10:28:25 AM »
These were "Jocelyne's" carbon fiber sisters
Offline SHORTROUND
« Reply #34 on: September 09, 2017, 10:31:56 AM »
Hugger straight out of mold. Fits cb500t cb550 cb450 cb350 might fit a cb750, not sure.  Fits the cb550 super sport
Offline Camrector
« Reply #35 on: September 09, 2017, 11:27:00 AM »
Loving the tank shape on the blue bike! Can you do one like that again?
Offline SHORTROUND
« Reply #36 on: September 09, 2017, 01:25:59 PM »
Couldn't resist.
Offline Gene
  • Chat enuf you too can be a
« Reply #37 on: September 09, 2017, 01:36:35 PM »
Interesting that carbon fiber work hasn't been more prolific in the "classic" moto scene - the tech has been around a long time, especially with bicycles. Nice to see it here and such good work.
Maybe it's more prevalent than I know?
*1973 CB750K3 (Bow)
Offline SHORTROUND
« Reply #38 on: September 09, 2017, 01:42:47 PM »
Gauge mount will be fitted with set screws to keep  the gauge from spinning
« Reply #39 on: September 09, 2017, 02:07:38 PM »
Keep in mind it is expensive...
Offline SHORTROUND
« Reply #40 on: September 09, 2017, 02:11:59 PM »
I can't make anymore tanks. The resin isn't EPA Compliant. It's no longer allowed in the US. i can make a tank but it's gonna leak. All fuel in the US has injector cleaner, emulsifiers, etc. it will dissolve the tank over time. Even if it doesnt break through, resin gets into the fuel and your spending more time cleaning carbs than ridding. Ethanol just makes it worse. I'm lucky I live in FL; well not right now with hurricane Irma, I can buy ethanol free gas. But I never leave it in a composite tank. Always drain it when I get home, fill up with new on the next ride. Run the old stuff in my mower; Brigs and Stratton. It would probably run on salad dressing.
Offline Gene
« Reply #41 on: September 09, 2017, 02:14:59 PM »
I get that, but a lot of ppl spend a lot of money on things that don't actually improve mileage and performance (i.e. weight loss). I'd be interested in carbon fiber wheels, just for an example. Probably can't afford 'em, but it seems like they should exist.
*1973 CB750K3 (Bow)
Offline Camrector
« Reply #42 on: September 09, 2017, 02:33:26 PM »
Understand. I only use ethanol free in all my bikes.
 I'm still in for 2 rear huggers and a seat then. If you are. Good luck with the storm.
Offline calj737
  • I refuse...
« Reply #43 on: September 10, 2017, 05:47:11 AM »
Shorty- a solution for the tank is to line it with Caswell. Other producers do this already as it is the only means to prevent the issue you're describing, as well as it prevents the fuel from leaking out during a crash (should the tank crack or split open).
So that might be an option to isolate the tank material from the fuel and Carswell is less than $50 for a tank our size.
Offline SHORTROUND
« Reply #44 on: September 11, 2017, 01:31:28 PM »
It's not just the sealer but the vinyl ester resin. That's why carpy also doesn't sell his tanks any longer. Fiberglass tanks should be compression molded, gel coat on both the inside and outside nice smooth surface without pin holes. Makes an ok bonding surface for caswell. Carbon fiber tank isn't gel coated on either side. Cast well, por15, doesn't matter.  It's not gonna seal it permanently. Carbon is to expensive to make mistakes, especially on large pieces. I don't do this for a living, so I'm paying retail for supplies. It's not just the ethanol, every gallon of gas in the US has fuel injection cleaner in it. Composites dissolve in that stuff.
Offline SHORTROUND
« Reply #45 on: September 12, 2017, 01:09:16 PM »
Clear coated fuel tank.
« Reply #46 on: September 12, 2017, 01:53:29 PM »
Offline Camrector
« Reply #47 on: September 12, 2017, 06:43:56 PM »
So nice!
Offline nbcam
« Reply #48 on: September 13, 2017, 07:22:55 AM »
that carbon fiber seat and tank is bad ass  8)
Offline CBertels
« Reply #49 on: October 12, 2017, 06:12:24 AM »
Fantastic Work!  Love the carbon bits.  Where about in FL are you.  I'm in Orlando and recently finished up my own CB550, albeit with a lot less custom fab work than you've done.
