I was wondering the same.
Below are examples of stacks made for the round top factory cb750 carbs. Two vintage aftermarket stacks, and the factory airbox stack.
The graph at the bottom is the same as a previous post above, from David Vizard’s book on performance Carbs/intakes, the text below that is the text relating to it. That man practically ate and slept in a room with a dyno and flow bench. Given the general length we commonly use for velocity stack on our 750s, the #7 and the #10 shapes seem nose appropriate to our needs. Notice the factory stack is very similar to #3, which isn’t too bad really.
But in general terms for those wondering, shorter stacks tend to favor more high rpm power, longer stacks favor more torque in the low to mid range.
George
