Author Topic: Any ideas on how to get this oil filter bolt off?  (Read 15557 times)
Offline Dos
  • Owner of a cb350f
« on: March 01, 2018, 03:18:47 PM »
I’ve just been using the clamp/wrench but as you can see only making it worse
Offline spotty
Re: Any ideas on how to get this oil filter bolt off?
« Reply #1 on: March 01, 2018, 03:26:13 PM »
Two ways...
One weld a socket or nut to it
Two, use a hack saw or dremel to cut a slot in it and use a flat steel bar to turn it
The advantage of method one is that you can then reuse the bolt for the time being to at least keep the bike on the road until a new bolt turns up
i blame Terry
Offline DaveBarbier
« Reply #2 on: March 01, 2018, 03:44:23 PM »
Yup, weld a big nut on it. Mine was stuck real good on my 650. Welded a nut on it and I still use the same bolt today.
Offline Dos
  • Owner of a cb350f
« Reply #3 on: March 01, 2018, 03:56:47 PM »
I don’t have acces to a welder unfortunately
Offline Flyin900
« Reply #4 on: March 01, 2018, 04:23:50 PM »
Lefty loosey and righty tighty... just in case!  :)
If you don't have access to a welder and you have a large crescent wrench and angle grinder you could grind each side of the bolt flat so you have two large surface areas for the wrench to flatten against. Some heat may help, although it has to pass through the case and filter to get to the crankcase.
Option 2
If the bike is still rideable then get a large nut that you have a socket for that fits with preferably a 6 point socket and take it to a garage with a welder and have them weld it on there for you. A good long breaker type bar/wrench is a must have tool so you can get decent leverage on the hard to remove nuts and bolts.
« Last Edit: March 01, 2018, 04:30:29 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline uksparky
  • Track days
« Reply #5 on: March 01, 2018, 04:24:36 PM »
No welder take it to a muffler shop they should weld a nut for about five bucks.....Or ...You need a good file and plenty time ..use the edge file and make it into a new nut head, done this before but not on a 550....use metric socket should be about 12/13/14 mm tapping it on tight, should come off
Present bike 1982 900C Custom
Offline Swoop
« Reply #6 on: March 01, 2018, 04:27:44 PM »
I have drilled a large hole and used an easy out with success.
Steve
Offline DaveBarbier
« Reply #7 on: March 01, 2018, 05:10:06 PM »
I’ve found that it’s not normally the threads that are seized, but the head of the nut seized to the filter housing (so many stuck bolts and screws on motors that I drill the head off and the remaining threads spin out by hand). Possibly a lot of heat from a propane torch, a penetrant of some flavor and smacking it with a hammer with the grinding of the flats as suggested above, that might do it.
Offline 77379
« Reply #8 on: March 01, 2018, 05:32:01 PM »
I just dealt with the same problem last week. I tried the chisel and hammer method with no luck. I picked up an 18” pipe wrench at Lowe’s. It was off in a minute. I did heat it up first and applied some pb blaster first. Good luck with it.
Gregg
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #9 on: March 01, 2018, 05:33:51 PM »
looks like the 17 mm hex head.  if it is hammer an 16 mm on there evenly.  if it's the small oem bolt i think it's a 13 mm so hammer a 12 mm on.  whatever the original size was hammer the next smaller size on.  it worked for me.  ran it like that for months until i bought a new bolt.
« Last Edit: March 02, 2018, 04:19:25 PM by evinrude7 »
cb750 k6 - ugly
« Reply #10 on: March 01, 2018, 06:35:13 PM »
 Over complicatijng things, unless you did the  following..
Jeez guys just grab it with visegrips at a slight angle..
 Then when you got it off, weld a short 3/8 drive socket to it..
« Last Edit: March 01, 2018, 06:56:33 PM by 754 »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #11 on: March 01, 2018, 06:50:52 PM »
I used a mallet and a medium size cold chisel. The flange behind the bolt is quite thick so there is plenty of metal for the chisel to bite into without damaging the filter housing.
« Reply #12 on: March 01, 2018, 07:14:34 PM »
new bolts are widely available...so if the head of the bolt goes bye bye, the filter cover comes off and the rest of the bolt spins out easy...reassemble with new bolt
Offline Airborne 82nd
« Reply #13 on: March 01, 2018, 09:36:48 PM »
Bingo even a dremel and a couple of cut off disk will take that bolt head off in less than 10 min. But I would try 754s idea first just for the speed. Then throw that crap away and get a new bolt. What next try to save the filter ;D and what is a clamp/wrench?
« Last Edit: March 01, 2018, 09:38:33 PM by Airborne 82nd »
« Reply #14 on: March 02, 2018, 01:50:07 AM »
im with banker,use a cold chisel,in the undo direction,you might knock it loose a coupla times and watch if it does turn a little,then use vice grips,a combination of the two.
Offline Hotwheelbill
« Reply #15 on: March 02, 2018, 05:05:33 AM »
A number of places , even Harbor Freight, sell sockets with teeth just for that.
I love to make my bikes worthless due to high mileage!
2004 ST1300A .... the fast one. And dragging pegs on a CT.
1972…parts bike
1974…. Rusty frame but runs
1974 CB750..... Powder coated frame and parts, waiting for $$ hot rod motor.
1972 with 1975 old school drag motor
« Reply #16 on: March 02, 2018, 05:20:56 AM »
those multi teeth or multi pin sockets are #$%* man,they wouldn't pull a loose tooth out,good idea but just don't work,they roll over and not grip on that short amount of left over hex!just chisel punch it around a little,then vice grip it the rest of the way.
« Reply #17 on: March 02, 2018, 05:31:32 AM »
Worked on every bolt I have used them on. But, thats just my opinion.
1972…parts bike
« Reply #18 on: March 02, 2018, 05:58:15 AM »
heres anyones opinion?
Offline DurangoCB
« Reply #19 on: March 02, 2018, 05:59:30 AM »
I was thinking the same thing.  Aren't those bolts like $8?   :o
1971 CB500 Four- current project http://forums.sohc4.net/index.php/topic,170622.0.html
1978 CX500- next in line
« Reply #20 on: March 02, 2018, 06:25:02 AM »
Maybe but if you don't destroy it with a chisel, and weld on a socket, you will never have trouble again..
Nada...zip.. never..
That is why I dont think the big head is always a good idea, makes the uninformed think it needs more torque than it does.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #21 on: March 02, 2018, 06:28:53 AM »
Dave...
  Are you inferring opinions are like #$%*s, everyone has one? ;)
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline evinrude7
  • not a kung-fu
« Reply #22 on: March 02, 2018, 06:35:52 AM »
if you've stripped one and you do it again you're probably more than uninformed.
cb750 k6 - ugly
Offline RandomOrbit
« Reply #23 on: March 02, 2018, 07:19:37 AM »
Mine was kinda buggered up after a couple of decades of abuse. Maybe not quite that bad, but I found if I hammered on a slightly smaller 12 point socket, it would give me enough bite to get it off. I then replaced it with a new bolt at the next oil change.
CB750k6 owned since 1991
« Reply #24 on: March 02, 2018, 07:40:53 AM »
That is usually my first go to plan also to get those off.
