Author Topic: New regulator/rectifier not charging  (Read 10970 times)
Offline rupaulpierce
« on: May 20, 2018, 10:19:25 AM »
Stock one was putting out 15v+ at speed. Put in this combo unit, identical to the one sold by 4into1.
https://www.amazon.com/gp/aw/d/B077BRBTDB/ref=mp_s_a_1_fkmr1_1?ie=UTF8&qid=1526835798&sr=8-1-fkmr1&pi=AC_SX236_SY340_QL65&keywords=regulator+rectifier+12v+cb400f
Now not topping 13v at speed... cleaned connections, examined everything. Defective unit?
Re: New regulator/rectifier not charging
« Reply #1 on: May 20, 2018, 11:14:23 AM »
More details:
This bike has 8 wires:
Rectifier plug:
-Yellow #1
-Yellow #2
-Yellow #3
-Green
-Red
The yellow wires are all putting out around 10v AC when bike is running. They all have less than 1 ohm resistance. No shorts to ground. 13v across battery regardless of RPM, no change or fluctuation.
Regulator:
-White - 0 DC volts key off, 1.4 mV key on.
-Green - 1ohm resistance.
-Black - 0 DC volts key off, 12.6 volts key on.
Offline rotortiller
« Reply #2 on: May 20, 2018, 03:41:35 PM »
Simple to follow. Always accurate:
Field coils for example on various bikes do not fall within the range in that general document so it is not always accurate. Best to use the applicable manual for resistance values before failing any OEM component.
« Reply #3 on: May 20, 2018, 04:43:43 PM »
It seemed to be "working" before I put in the combo rectifier regulator. Is there something i'm overlooking about the wiring of the new unit?
Using this guide, one thing that seems off is constant voltage from the white wire to the regulator. It's not getting battery voltage with the key on or off.
http://motorcyclemd.com/how-to-fully-troubleshoot-your-motorcycles-charging-system/
« Last Edit: May 20, 2018, 04:46:48 PM by rupaulpierce »
« Reply #4 on: May 20, 2018, 06:45:47 PM »
How did you connect the wires from the new unit to your stock bike? Start there. Asking “what’s wrong” with details of what you’ve done doesn’t provide much guidance.
The loose WHITE, BLACK and GREEN are the Regulator side of the unit. They provide the power to the field coil (White), the Ground for the Regulator (Green) and the battery status (Black). White should have no power to it without the key ON.
Every time I use those type of units, I swap the loose White with the RED in the plug, and then run RED to the battery POS directly. That way the WHITE from the stator harness matches color-color to the Reg/Rec.
The new unit matched the wiring of stock harness. It has three male spades for the regulator that match the female connectors from the stock harness.
Online scottly
« Reply #5 on: May 20, 2018, 08:47:38 PM »
Regulator:
The white should be much higher than 1.4 millivolts. ;)
« Reply #6 on: May 21, 2018, 04:56:04 AM »
Regulator:
White is positive from field coil and should read battery voltage?
« Reply #7 on: May 21, 2018, 07:41:28 AM »
Regulator:
Apologies, a little confused. Does the white wire send power from the regulator TO the alternator? The wiring diagram suggests that the white wire only travels between these two points.
Online scottly
« Reply #8 on: May 21, 2018, 07:47:09 PM »
The white wire supplies power from the regulator to the field coil, which is grounded on the other end. With a stock regulator, with the key on and the motor not running, you will see very nearly the same voltage on the white wire and the black wire. A solid state regulator will have some voltage drop, so with 12.6 volts on the black wire, it may read 12.0 volts, or maybe even a little lower, but certainly not down into the Milli-volt range.
« Reply #9 on: May 21, 2018, 07:50:24 PM »
So should I be testing white downstream from the regulator at the alternator plug?
I took the mV reading on the harness with the reg disconnected, along with the green and black.
« Last Edit: May 21, 2018, 07:52:34 PM by rupaulpierce »
Online scottly
« Reply #10 on: May 21, 2018, 08:26:29 PM »
No, measure the voltage at the junction of the white regulator wire and the white harness wire, with All wires connected.
« Reply #11 on: May 21, 2018, 08:31:34 PM »
I’ll re-test in the morning, thanks scottly.
Offline Airborne 82nd
« Reply #12 on: May 22, 2018, 01:33:28 AM »
Then why did you change them?
« Reply #13 on: May 22, 2018, 02:27:31 AM »
Too much voltage for lithium battery.
« Reply #14 on: May 22, 2018, 05:23:01 AM »
With everything connected, getting 12.5V on both the black and white wires. ;)
« Reply #15 on: May 22, 2018, 05:04:14 PM »
Could the regulator just be regulating the voltage to 13V?
Online scottly
« Reply #16 on: May 22, 2018, 05:50:01 PM »
Possibly, or the battery may be discharged and it may take some time to recharge. Is the voltage steady at 13V, or does it slowly creep up?
Offline rotortiller
« Reply #17 on: May 23, 2018, 04:39:48 AM »
Why not put the original components back in and adjust the regulator down to 14 volts? It works good and lasts a long time.
« Reply #18 on: May 23, 2018, 05:25:09 AM »
Battery was fully charged on a fancy charger with a testing program. Voltage seems to slowly creep down.
« Reply #19 on: May 23, 2018, 05:26:28 AM »
Didn’t know the stock reg was adjustable!
« Reply #20 on: May 23, 2018, 08:52:57 AM »
You do have the shop manual, no?
The stock regulator is adjustable.  Adjust it while battery is at full charge, when the alternator is spinning fast to make as much power possible, so that the regulator can have full control of alternator output.  You do need to verify that the regulator "sees" acurate battery voltage both when all lighting is off as well as on.
The stock lead acid battery has very low impedance due to large plate area.  It absorbs the transient spikes that the stock regulator provides while switching the alternator power on and off to maintain an average battery voltage status.  It is unaffected by the spike transients.   This leaves two concerns for a lithium battery substitution.  1), does the Li battery have the proper impedance to quash the spikes?  And 2), does it have the durability to withstand these spikes for maximum life?
My lab is not yet set up to test such things, I'm afraid.  Getting close though.
« Reply #21 on: May 25, 2018, 06:17:05 AM »
I thought these spikes were one reason manufactures recommend that you use a modern reg/rec unit with the lithium batt.
Just swapped the lithium batt for an AGM... same result. This one is actually reading sub 12V across the battery terminals when running, assuming due to a lower charge voltage.
« Reply #22 on: May 25, 2018, 07:26:53 AM »
Is your agm battery fully charged?
An under charged battery will hold the voltage down until charged.
Does the black wire voltage at the regulator terminals match the voltage at the battery terminal?
Must veryify that the sense pathways don't lose voltage. Both positive and negative paths.
Is your rectifier fully functional?
How confident are you that you voltmeter is accurate?
« Reply #23 on: May 25, 2018, 07:43:53 AM »
Batt is fully charged. Same results with two different fully charged batteries. Both pass a voltage test with the bike off and high beam on.
Also using two voltmeters... a cheapy through ring terminals across the battery, and also via multimeter.
Now i'm going back and forth between the stock units and the new combo unit. Something must have come loose or cooked during the swap.
Stock Units:
Battery voltage key off: 13.34V
Regulator black wire voltage key off: 0V
Regulator white wire voltage key off: 0V
Battery voltage key on: 13.2V
Battery voltage key on w/ high beam: 13V
Regulator black wire voltage key on: 12.5V
Regulator white wire voltage key on: 12.1V
New Combo Unit:
Battery voltage key off: 13.2V
Battery voltage key on: 13.1V
Regulator black wire voltage key on: 12.81V
Regulator white wire voltage key on: 12.77V
Both set ups drop from +13.2V to 13.07V when running and pegged at 4k rpm.
« Last Edit: May 25, 2018, 07:49:53 AM by rupaulpierce »
Offline strynboen
« Reply #24 on: May 25, 2018, 07:46:12 AM »
the stock reg is not so presise...so for sensibel batteries..its fine to get a elektronic unit..the elektronic is voltage regulating..and garente the 13,5-14.8 volt..the mecanic..can go heiger in volt,if the battery need some power...it dont sence the volt..anyvau not presise...accic and gel batteries can easy take a bit overloading..and Work fine vith the old reg...
« Last Edit: May 25, 2018, 01:01:02 PM by strynboen »
i hate all this v-w.... vords
