Author Topic: CB750 AHRMA Superbike Heavyweight Racer  (Read 40676 times)
Re: CB750 AHRMA Superbike Heavyweight Racer
« Reply #125 on: August 13, 2019, 07:00:14 PM »
I had my f3 set up with a similar profile seat, and  renthal dirt bike bars, and man I could really throw that thing around...just needed rear sets to be perfect.  Riding position was really good for me, but you are a bit taller.  Hope the lower saddle does not make you too scrunched up.  It felt awesome  to be sitting more "in the bike" as opposed to "on".
...man, now you got me super excited to get that f3 engine rebuilt and back on the road!
DSCN0801 by Sean Barney, on Flickr
Offline slikwilli420
  • Master of Disaster
« Reply #126 on: April 15, 2020, 08:30:51 AM »
Happy quarantine from Michigan! I have found a ton of time on my hands with the recent shutdown, and am in week 5 of being at home with my wife Ashley and 5 year old Jackson. That means I have time to work on bikes!
I have been slowly collecting parts and pieces for this one. When I last left off there was a frame with a few bits bolted to it and not much else. I came across a set of Astralite wheels hubs for the rear so the set is now complete.
Needless to say, the waterjet machine at the local machine shop has been busy. Brakes are mounted on custom brackets, spacers for the front wheel are done and I only need to turn them down some to shave some weight and make caliper bracket spacers for the other side, and it's a wrap. The rotors are custom ISR units that I ordered last March that showed up a few months ago.
The calfab swingarm install is all but finished as I am still playing with spacing for the pivot collar to get it just right so there is no play when tightened up. The axle adjusters are a 3 piece design bolted together and came out really good. They just need a bit of finish work then they can be installed and I can get chain alignment done properly, and finally make spacers for the rear wheel. The shocks are vintage Ohlins that were serviced by a place out in California. Pretty pissed they jerked me around for almost 14 months before they were done and returned to me, but they look great and I have the right one installed. This is a late F frame so the right shock mount is longer, putting the top out of alignment with the bottom, so some frame surgery is in order to fix that. I will fix that along with all the other frame bracing all in one go after I cut the tubes for braces and make up the oil cooler mount. With shutdown going on, I have no idea when I will be back to the welding shop to get it all burned together.
Items next up:
Finish rear wheel install, spacers, swingarm pivot and axle adjusters
Mount front fender
Oil cooler/number plate/headlight bucket mount
Cut down front axle to proper length
Mount a set of gutted gauges, block off speedo gauge and mount digital tach in other
Cut/fabricate frame braces for front down tubes, at the "V" above the swingarm and between tubes above swingarm
Spin-on oil filter adapter (refuse to pay $100 for one so will make my own)
Detab the entire frame
Start building the oil tank
Offline kap384@telus.net
« Reply #127 on: April 15, 2020, 12:31:24 PM »
Sweet bike.  I'd like to see that! Start the rebuild!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« Reply #128 on: May 24, 2020, 06:29:52 AM »
Subscribed. Anyway to fix the old photo links?
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
« Reply #129 on: February 25, 2021, 12:15:34 PM »
This one is still alive and well too!! I have been focusing on this one a bit lately until a few weeks ago when I needed to get really focused on my S750 bike for the upcoming season.
I have the frame all welded with gussets, frame kit, rear set bungs and all of the oil cooler/number plate stuff up front. Of course I had to blow it all apart from the first rough mockup to get there and now its time for the second and last mockup before things come down one more time for final assembly.
Started knocking up a new oil tank, similar to the one on my other bike, but deeper for more capacity:
Stock alternator cover and after cutting 30mm from it to narrow it:
Gauges from Speedhut fitted and ready to go. I used the Joker Machine rings to clamp it all back together. Very early superbike inspired if I do say so.
Working on the conversion of the left side engine lug to bolt on style. Why? Because I can and it looks badass.
Oil cooler/number plate mount made and tacked on, ready for final welding
Beautiful Auto crank ready to be sent off for some de-stroking work at Marine Crank
Lots more to come but it should be a badass ride.
Offline Ramrod_Racing
« Reply #130 on: February 25, 2021, 12:26:14 PM »
Also, this is the Vintage Cup class for next year; so time to get crackin'  ;)
« Reply #131 on: February 25, 2021, 12:27:04 PM »
That lit a bit of fire under my butt for sure.
« Reply #132 on: June 10, 2021, 08:55:47 AM »
Lord have mercy, its time for an update. So many things have happened since the last update that it will be hard to document everything but Ill try. Prepare yourself for a stream of consciousness post filled with pictures that may be out of order but it needs to be documented so here, we, go.
I am t-minus one week until I need to be loaded and headed for beautiful Southern New Jersey for the next round of AHRMA racing. This is the first time I will have 2 bikes to field and should be a really special event, as George will be there to bare witness to the whole thing.
Engine assembly and cam timing:
Finally in its home:
Oil tank finally complete (what a pain in the a$$ to make)
So, what the he11 is done:
Wiring
Oil lines
Engine assembly/install
Chassis all assembled and most everything that needs to be drilled for safety wire is
Bodywork painted and set up to be installed
What's left in the next 6 days:
Bleed brakes f/r
Install carbs and fuel lines/cables
Cut chain to length
Plumb breather/vent lines
Setup Dyna 2k ignition
1000 other little things I will get to when I see them
That's all for now but its still many hours of work, but I'll get there come he11 or high water!!
« Reply #133 on: June 10, 2021, 10:17:32 AM »
Oh yeah!!!  ;) ;D
Offline Old Scrambler
« Reply #134 on: June 10, 2021, 07:22:16 PM »
Lots of Lube ;D ;D ;D
Nice looking oil tank ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline johno
« Reply #135 on: June 10, 2021, 11:39:15 PM »
Man, Looking very sexy, that is one nice looking bike, well done and good luck with finishing off the project.
Your workshop is an encouraging environment to work in.
Cant wait to see how the new cam chain tensioner fares.
cheers johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline turboguzzi
« Reply #136 on: June 11, 2021, 02:20:09 AM »
all looks delicious! good luck putting it all together in time...  sounds like you have some all nighters ahead...::)
Offline gschuld
« Reply #137 on: June 11, 2021, 08:19:42 AM »
Well I can say for sure that Matt has been busting his butt to get this bike ready.  And it’s chock full of custom pieces.
George
« Last Edit: June 11, 2021, 08:46:25 AM by gschuld »
Online PeWe
« Reply #138 on: June 12, 2021, 07:59:19 AM »
Very interesting reading with photos.
I look forward to see the dyno chart(s) ;)
And result when riding the bike!
Offline gschuld
« Reply #139 on: June 15, 2021, 05:31:33 PM »
I’ll let Matt give the details.  But I’m happy to announce the new bike is up and running, got broken in,  and made a successful lap or two around the block.  All signs are positive….
Good job Matt….and Ashley for being so supportive.
George
« Last Edit: June 16, 2021, 07:14:47 AM by gschuld »
« Reply #140 on: June 15, 2021, 07:46:34 PM »
Very nice indeed :) :)
So sometime on Friday we should expect to hear the results of how it 'howeled' on on the dyno ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline gschuld
« Reply #141 on: June 16, 2021, 03:47:02 AM »
Yes, I suppose so.  Let’s not get hopes up too high here.  This engine is essentially a street bike engine perfectly capable of running pump gas and doing road trips being used on the track.
The engine Kenny built for his superbike racer was FAR more of the full kill variety.
George
Online PeWe
« Reply #142 on: June 16, 2021, 05:50:07 AM »
100whp is expected if compression is enough? ;D
Offline gschuld
« Reply #143 on: June 16, 2021, 07:22:39 AM »
Well I’m hesitant to guess as dyno results regarding power numbers can be inconsistent between dynos depending on setting, corrective factors etc.
We are primarily concerned with a nice air/fuel mixture through the range, and getting the timing dialed in for a nice even strong power curve that this layout of engine(and cam) is capable of.
I’m not sure how much time we will have on the dyno to fiddle with things beyond the basics.  The more time we have the more likely we will be able to get it closer to a ideal setting.
George
« Reply #144 on: June 16, 2021, 09:22:34 AM »
I only see one of the Hall bros on the pre-entry list, so not sure the dyno will be at NJMP this time.
Online PeWe
« Reply #145 on: June 16, 2021, 11:02:51 AM »
Yes, OK A/F mixture all over the throttle/rpm range is no. 1.
Offline gschuld
« Reply #146 on: June 16, 2021, 01:46:15 PM »
Not using Hall Bros at the track.  We have an appointment offsite:
https://www.xtrememachines.us/learn-about--factory-pro-dyno
« Reply #147 on: June 16, 2021, 02:19:28 PM »
Ahhh, y'all fancy huh?
Offline gschuld
« Reply #148 on: June 16, 2021, 03:14:09 PM »
Oh we are a Caviar and Champaign group for sure😁😁😁
The eddy current Dynos are quite different from the inertia dynos like the Dynojet models.
They state outright that these dynos typically report noticeably lower power numbers compared to inertia dynos. It’s another reason I’m not overly interested in the power numbers, but more in getting the air/fuel and timing dialed in.
George
Offline bear
  • Leeton in Australia
« Reply #149 on: June 16, 2021, 05:14:54 PM »
George
In my opinion that's definitely the right way to approach it George. Set-up and balance are far more important than outright HP. It's very easy to over power a racetrack on a bike based on fifty year old technology. Balance is the key.
None of us are a Mick Doohan or Kenny Roberts.
« Last Edit: June 16, 2021, 05:20:05 PM by bear »
