Author Topic: Bright lights on a CB750K2  (Read 1540 times)
« on: August 22, 2018, 03:02:33 AM »
I went for a ride last night - across Boston, over to Wollaston Beach, down Furnace Road Parkway, through the Blue Hills before heading home. I was struck by how good my headlight was after upgrading to a Phillips Xtreme vision H4 bulb. I also have a LED light in the tail that flashes when breaking (good for the city). LED lights in the gauges from Superbright. Took this photo in a very dark garage at the end as I was so impressed by the light.
cheers
Andy
Re: Bright lights on a CB750K2
« Reply #1 on: August 22, 2018, 05:06:19 AM »
Yeah, H4 and relays to lit it makes a huge difference.
Offline Erny
« Reply #2 on: August 22, 2018, 06:29:43 AM »
Looks good.
I have LED in tail (but not flashing), it is definitely improvement of safety, when brake light on/off is very sharp
I have also dash control lights as LED, much better visibility compare to bulbs.
I plan to go for LED in side indicators, where I expect significant power saving and better safety.
And I still plan to change current nonsme H4 to Philips Xtreme vision soon. Maybe think about gauges too
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: August 22, 2018, 08:10:07 AM »
I did something similar on my 550, LED headlight, front turn/marker lights, gauge lights, and tail/brake light. I didn't bother with the lights that are only on occasionally like the rear turn signals and warning lights.
Offline PatrickZ
« Reply #4 on: May 26, 2020, 08:25:40 PM »
What LED headlight did you pick, if I may ask?
Offline Alaxy Galaxy
« Reply #5 on: May 27, 2020, 07:59:44 AM »
Have you guys found a LED tail light that has a good contrast between DRL and brake light? The amazon special I tried didn't seem to change much in intensity between the two.
« Reply #6 on: May 27, 2020, 12:01:37 PM »
Look for the ones made by CREE. While Chinese (like all LEDs today), they are the brightest, currently.
Offline Deltarider
« Reply #7 on: May 27, 2020, 12:16:31 PM »
IMO you've posted a good reason to keep the old bulb. In Europe it's 21/5 Watts btw. To increase contrast, I decided to disconnect the taillight in my DRL scheme. On entering a tunnel I just slide the RH switch to 'P' to add the taillight and instrument lights. The latter are simple 4 X 3 Watts Ba9s - exactly what Honda designed - which with a classy soft glow illuminate the gauges evenly. Not the cheap looking and annoying bright Leds that even fail to illuminate evenly.
CB500K2-ED Excel black
