Author Topic: CB750K7 cafe racer build.  (Read 12169 times)
Offline stou
    • Stoudesign
« on: October 24, 2018, 11:50:46 AM »
My build is completed...almost, since we always have a little something to do! During the build, I took many pictures, so I tought it could be interesting to do a thread about it.
I bought this 1977 CB750 from a friend a little more than 2 years ago. He had this bike since something like 20 years under a pile of junk in is garage. Everytime I went at his home, I asked if he want to sell it to me. He always said that he want to do a project with it. But at one point during one of my visits, he decided to sell it to me! :D
The bike was in a very bad shape and not running. So I decided that this will be a cafe racer project.
Here's the bike when I bought it. It came with many old spare parts and another engine.
The first step for me was to clean it and have it running to pass the inspection to be able to put it on the road. Here in Quebec, we need to have the bike with no frame modification, with blinkers, horn, mirrors and not too loud exhaust to pass the inspection. So I decided to have it done before modified it into a cafe racer.
So I start with the carburetor, they was very, very dirty! And I bought a new battery.
I order a carb rebuild kit, and I borrow and ultrasound machine from a friend.
Before and after:
My wife made a seat cover, and I painted the tank to have a clean look to give me more chance to pass the inspection.
I went for the inspection and it went through easily.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
KTM 890 Adventure R 2021
My CB750 build: http://forums.sohc4.net/index.php/topic,174710.0.html
Offline stou
    • Stoudesign
Re: CB750K7 cafe racer build.
« Reply #1 on: October 24, 2018, 12:07:07 PM »
When I worked on it to have it running, I took the cylinders compression and it was very low. So it will need to be oversized. The front fork was also in bad shape. Scratches and rust on the fork chrome tube. I looked around to have it rechromed, but I found it expensive. The lower leg was not in good shape either. I decided to go for a front swap with an upside down fork. I found a GSXR 600 complete front end, at a not too bad price. So I started to work on that. After looking at the GSXR fork and CB neck, I decide to use the CB steering stem and install it in the GSXR triple clamp.
I grinded the stem of the CB triple clamp. It had a little bit smaller diameter than the one of the GSXR. I putted some welding on the stem and had it to the right diameter on my lathe. Then I welded a big washer at the buttom.
I also made an adjustable fork stopers
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline stou
    • Stoudesign
« Reply #2 on: October 24, 2018, 12:18:48 PM »
I wanted to keep the spokes wheels and with 2 front rotors. I needed to mad some spacers the have the rotors place at the right place for the radial front brakes. I also needed to made some bushings to have the wheel centered.
When I putted everything together, I had a bad surprise. The calipers was rubbing on the outside wheel spokes. Not a lot but it wasn't acceptable. After looking at the problem, I decided to respoke the wheel with all the spokes on the inside of the hub. It worked!
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline stou
    • Stoudesign
« Reply #3 on: October 24, 2018, 12:35:16 PM »
Next, I worked on the cafe racer back end. I bought a frame loop on the internet. I then cutted and welded the new back end of the frame. To make sure it was solid enough, I machined some parts to go in the frame.
Next, I made a seat form from some floral foam. This stuff is easy to work with.
Then I did it with fiberglass. The brake light and blinkers will be a LED bar that I bought on the internet.
The font will go into this part and the back will be hold with 2 bolts.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
« Reply #4 on: October 24, 2018, 01:37:39 PM »
Great job so far, Stou!
To date, this is the first front end conversion I've seen where someone has mated a modern front and calipers and still used the old CB brake rotors.  The modern calipers are designed to work with floating rotors, whereas the CB rotors are fixed.  I am not sure if this may cause any issues.  That said, you did a good job machining the spacing adapters for the rotors and the wheel.  You did a fantastic job on your fiberglass seat, too.
Looking forward to seeing the progression on this bike.
« Reply #5 on: October 24, 2018, 01:56:34 PM »
Following
Offline stou
    • Stoudesign
« Reply #6 on: October 24, 2018, 02:34:57 PM »
Thanks Cafe Racer Fan! You're right about the rotors, but we'll see how they'll worn out. It will be either the bolts or the hubs that will worn out.
I forgot, I also drilled the rotors. I thought it was to be very hard to drill but with a cobalt drill, it worked fine.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline stou
    • Stoudesign
« Reply #7 on: October 24, 2018, 02:45:37 PM »
The side covers was all cracked, so I start to look for new one. Meanwhile, I was thinking that I want something different. A day while I was looking at my old 1974 CR125 (that I restored), I had an idea!
I tried the side covers of the CR on the CB! I was looking good and the base shape fit well to the CB. So I decided to make some special number plate side covers for the CB!
I made molds from plaster
And made them in fiberglass a bit wider than the CR covers
Machined some aluminium to fix the covers in the CB holes
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline physician
  • old school...
    • photo galerie
« Reply #8 on: October 24, 2018, 06:13:05 PM »
Thats great! Where are you in quebec? Moi je suis de st-hyacinthe.
Great work so far. Looking forward to know about the rotor setup
k2 chassis k7 engine resto mod
k7 cafe/fighter/brat
Offline stou
    • Stoudesign
« Reply #9 on: October 25, 2018, 04:07:23 AM »
I think you’d better check for tire clearance on the rear with suspension compression. That hoop looks to land right atop the tire...
Already checked! Those Progressive shock have only 3.8" of travel. There's enough of clearance between the hoop and the tire ;-)
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline stou
    • Stoudesign
« Reply #10 on: October 25, 2018, 04:09:13 AM »
Thanks Physician! Je suis à Laval, Quebec
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline stou
    • Stoudesign
« Reply #11 on: October 25, 2018, 04:22:41 AM »
I didn't like the tank of the '77 - '78 with the cover on top of the gas cap. So I decided to remove the cover and install a flush mount gas cap. I ordrered a kit and started to work on the tank.
I cuted the cover to be able to position the cap at the right height. I then did some weld tacks, removed the cover and welded the cap on the tank. The welds must be well sealed to avoid gas leak from the top.
Here's what it look like once welded, sanded and primed.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline stou
    • Stoudesign
« Reply #12 on: October 25, 2018, 06:30:06 AM »
calj737, no there's no overflow tube. There's no need of it because everything is sealed. If there is a spill, it will run ou from the gas cap. I did a few pressure test to be sure everything is really sealed.
I understand what you wrote about the tail section. But the front of the tank is high and what I looked for is to get some regular shapes from front to back. I didn't wanted a high front tank and a small back end. Once painted and the seat on, I think it give a nice overall shape. But everything is a question of personnal taste.
You can see a little bit better what I mean on this picture.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
« Reply #13 on: October 25, 2018, 09:35:46 AM »
As long as it's vented, and he only fills to bottom of filler tube  he will be better off than our 76 and down tanks.
Because of prepay, i over filled my tank a few times this year, scary mess with a hot motor.
One time I stopped after fueling, had a bite asked for directions and the gas expanded and overflowed.. messy.
 You great job on the bike you think a bit like me I think, the Elsinore cover idea was good.   The way you made the pegs for the grommets is what I would use on an alloy sidecover.   I did a big brake setup for a wire wheel, using wheel like yours for Bert in Quebec using F forks a few years ago.
 Keep up the nice work
« Last Edit: October 25, 2018, 09:38:08 AM by 754 »
Offline stou
    • Stoudesign
« Reply #14 on: October 25, 2018, 10:01:20 AM »
Thanks 754! By the way, I made a good use of your frame kit!
For the sidecover, as you can see I made some groves at the bottom of the pegs to be sure the fibeglass retain them strongly. I puted the pegs in the grommets, then I used some hot glue to position the side covers at the right place on the pegs. Then, I used fiberglass to fix permanently the pegs. It look strong enough.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
« Reply #15 on: October 25, 2018, 10:31:10 AM »
What color do you plan on painting the bodywork?  If the color of the tank and seat match the frame (at least where they come together), the visual gap of the seat to the frame will blend in.  Otherwise, the seat may appear like it is propped up an inch or two off the frame.
Offline stou
    • Stoudesign
« Reply #16 on: October 25, 2018, 12:57:27 PM »
Like I wrote in the first post, the build is already completed, so the paint is already done. I don't want to put a picture of the paint now in this thread, but the color is dark and it is blending very well with the frame.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
« Reply #17 on: October 25, 2018, 03:40:52 PM »
Ah, missed that.  Okay, we'll see it sooner rather than later.
Offline stou
    • Stoudesign
« Reply #18 on: October 26, 2018, 07:34:20 AM »
Engine rebuild.
I started by powder coat all the casing in wrinkle black. A big masquing job !
I rebuild it with new bearings (some), new seals, new cam chain. At this point, I checked the primary chain and from the Honda shop manual, it was in the specs. It had 67mm of travel at the chain tender and the shop manual indicate this is good under 70mm. So I didn't replace it since it's an expensive update. (I will regret it later)
I had the cylinders oversized and I installed the 836cc kit
I also had the valves guides replaced and valves seats machined. I installed new valves and seals. The springs was in the spec.
I then putted everything back together.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
« Reply #19 on: October 26, 2018, 09:40:45 AM »
Did you treat the inside of the engine with any coatings.  In your photos, the inside of the crankcase looks gold.
I've heard of builders using red Glyptal to seal cast metal and ease oil flow, but I haven't seen anything in gold.
Offline stou
    • Stoudesign
« Reply #20 on: October 26, 2018, 01:29:12 PM »
No, I didn't do any coating inside the engine. It was already gold like that.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline algophobe
« Reply #21 on: October 26, 2018, 03:12:50 PM »
nice build, only wish you put more detailed pics of your process. lots of fabrication points one can learn from that.
btw, do K7 gas caps seal as poorly as K2s? I know old bikes don't have overflow channels like the newer bikes but i'm curious the slight leak is intentional? (a noob question)
Ducati Hypermotard 950 SP 2020 "Percolo"
Honda cb750 café 1972 "Satmui"
Kawasaki zx6r 2005 "Garuda"
Kawasaki zx7r 1998 "Dharma" (stolen)
Honda Magna V4 1982 (sold)
Offline stou
    • Stoudesign
« Reply #22 on: October 26, 2018, 04:16:04 PM »
Thanks algophobe! I know I should have taken more pictures to better document my build, but I often forgot to take pictures, too much concentrate on my work.
About the K7 gas cap, I can't really tell. I rode the bike only once before I modified the gas tank, and it was only to go to the inspection and there was only a small amount of gas in it. Right after that I started to work on the bike. Now with the flush mount cap, it is well sealed and the vent is really well made in the cap. The only way to have an overflow is if I filled the tank up to the cap. Since I know it, I will take care not to filled it too much when I'll do the fill up.
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
Offline physician
  • old school...
    • photo galerie
« Reply #23 on: October 26, 2018, 04:16:20 PM »
Nice build. Wich 826 kit is that?
I have troubles finding someone to bore out for 836... they all say its too thin... even while i tell them its common they dont want...
Offline stou
    • Stoudesign
« Reply #24 on: October 26, 2018, 04:32:02 PM »
It's a Wiseco kit. I bought this kit because the machine shop who did the work on the engine, already have one in stock. I had a really good price for the kit. It's a bit more expensive to have it bore for the 836 because they have more pass to do to remove all the material. They did a nice job on the cylinder and the head.
This is the shop who did the work: http://jprecision.com/
Wiseco 836 kit: $593 CDN (very very good price!)
Bore & hone : $430 CDN
Work on the head: $426 CDN (new guide, work on the seat and head surface)
Honda CR125M1 1974
Honda CB750K7 1977
Honda TLR200 1986
OSSA TR280i Trial
