Author Topic: Project Learning Curve  (Read 7993 times)
Offline mbryan
Re: Project Learning Curve
« Reply #25 on: May 11, 2020, 07:38:50 AM »
Do you guys know where I can get a set of tappet cover seals?  The covers are fine.....looks like the seals need replacing though.
Offline flatlander
« Reply #26 on: May 11, 2020, 07:59:39 AM »
cmsnl or davidsilverspares have OEM stuff. or look up the part number in the partslist and stick in google, then you get all sorts of hits.
for these kind of things i normally buy OEM as those fit best and last longest.
Offline mbryan
« Reply #27 on: May 12, 2020, 07:07:56 PM »
ok.....the good.... started to clean the carbs tonight with my son.  Got the kit from 4 into 1.  Has bowl gasket, top gasket, float neadle, and various round gaskets.  All going well except I think the carb cleaner got to me a bit (had a fan on but still ......wow).
https://photos-1.dropbox.com/t/2/AACeJl0TLw-zoT1-rsXbjwl0vCnWm7dHIS3UX4BD1Uk45g/12/3159652576/jpeg/32x32/1/1591927200/1/9/20200512_194843.jpg/EIDkm6kcIAooCg/BdBQcY1wWysXSAg4_vWDY7tkyvnKoMJYzSKjvTXIc-qnW1BQurW4_5S6sCdX2ToW2nmbn9gO6-3JffmxA9SHnfP-XrVIKPkYJkvG1vtsDk59fuQXU-VP8-_9E6ZFfEyH0Lc?size=32x32&size_mode=2
The not so good.......when taking the components apart, I noticed that fuel mixture screw washer and gasket on carb 3 is not there.....and the kit does not have a washer (it does have a gasket though)......and it is the size of an atom so I cant find it!!!!
https://previews.dropbox.com/p/thumb/AAywqT_YtF4mTqV8AeQZ150yvKdGao7YhdwWBDMcXrLTTe4Rtr0D5VQzSH0BkiK4zconAR8LgTFvtdBvD7CgnPAskGO906uksLXv_QSRs1GdPIbJZyNBcOiJRpuFQuEF6FRXR13rdI01rQDpmZPUrFcpcU8mv4hN7uf9uw9kCQ2VRs2iGK88FfYEiPZjzqviuUbKEPn3wkrY-0nm-ZRl-Cn-4i8zIrXMM9rJcgJKTov_PK2NXJ5K6zxFNRBUMkvj-L295dN6EaPTSSqGrCJQOEXMok8J0l41imV8nO57ovszHr1omDhkLIpaZrj8we0i623ju56FsGkmsDB8Ei5RMcYnbhEu8_gj4NPzqqSwqSUzkg/p.jpeg?fv_content=true&size_mode=5
Soooooo......anyone know where I can get this one washer.....or 4 of them....or?
We wanted to try to clean them, set them up, and try to install them to see if the bike would at least start (have not been able to do that yet)
Offline mbryan
« Reply #28 on: May 12, 2020, 07:16:12 PM »
Offline mbryan
« Reply #29 on: May 13, 2020, 05:41:40 AM »
Found the part(s) at David Silver
https://www.davidsilverspares.com/parts/by-part-number/partnumber_4951/
will order 2 to be sure I have enough.....or to say it another way.....in case I loose one again!!
Looks like my oil leak is coming from the cam cover/tappet area.  The bike sits on its kick stand (I dont have a stand to sit it upright yet) and even not running the oil will pool at the top of the head on the first fin which is where gravity will bring it in this position.  I will get a top end gasket set and see if just changing those very top end gaskets will help.
Offline flatlander
« Reply #30 on: May 13, 2020, 06:15:07 AM »
if oil gets on the top fin, a pretty likely cause is from the cam shaft end cap. there are 2 o-rings on the studs that keep the end cap located in the rocker shaft holes. and there's a bracket that the cap is screwed on to. there are washers on the bolt keeping the bracket in place, check the partslist for that. the washers need to be sealing ones, e.g. from copper.
Offline mbryan
« Reply #31 on: May 13, 2020, 06:46:18 AM »
Got it.....one question about putting that cover back on( I was going to get a kit and replace the breather cover and cam cover gaskets).  I see on the service manual it shows to torque the bolts to 6-9 ftlbs .....how about the screws on top?  My motor has a combination of JIS screws and bolts holding all of it down.
Offline mbryan
« Reply #32 on: May 13, 2020, 08:28:05 AM »
well.....I got everything (for now) except that copper washer.  I think it is this one...
https://www.cmsnl.com/honda-cb550k-1978-usa_model7222/washer-65-mm_90485001000/#.XrwRQmhKiUk
I looked here and at David Silver and babbits.....will keep looking.
Offline flatlander
« Reply #33 on: May 13, 2020, 08:42:01 AM »
any 6mm copper washer will do. it doesn't have to be OEM honda.
the honda ones are actually more fancy, i don't remember what exactly - maybe brass coated with zinc? but copper works fine there, and is easier and cheaper to get. also on the rocker cover, those bolts that have oil behind them need sealing washers so better just get a few of them.
the bolts holding down the rocker cover:
i'd replace the jis with allen heads. be careful with torque on all 6mm bolts that go into alu on these blocks. it's very easy to strip the threads, especially with a torque wrench. it's enough to carefully nip them tight by hand.
Offline mbryan
« Reply #34 on: May 13, 2020, 04:30:19 PM »
Will do......
Another question.....I see some people have used a polish on a q-tip and used that to polish the seats in the carburetor.....float seat and fuel mix seat.  Opinions on that.....and if good to go can you point me to a polish?
Offline flatlander
« Reply #35 on: May 13, 2020, 11:06:09 PM »
why do you want to do that? do the carbs leak?
if not, i'd just clean them up, put them back together and see how they do.
Offline mbryan
« Reply #36 on: May 14, 2020, 05:21:54 AM »
Fair enough.....was just trying to do all the good things that should be done while they are apart, but I see your point.
On a side note.....my son cleaned the engine up yesterday with carb cleaner and some degreaser.  Got heavy handed and now the finish is etched on the aluminum and some pait is missing.  Oh whell, learning moment.  Will add that to the list of things to repair.
Offline mbryan
« Reply #37 on: May 14, 2020, 11:51:22 AM »
Got it.....thanks.
So after cleaning and drying over night I went and looked and so far no oil.....again I have not run this bike at all and was getting some seepage along the downward fins as it sat on the side stand.  Also, I think I mentioned this.....but while I was poking around u noticed a bolt loose.  It is the one on the head between the two and three exhaust pipes in the pic.  I snuggled it pretty good.  I wonder if that was my source?  Doesn't explain the top fin though.
https://www.dropbox.com/s/o3qllrk70ijs3y1/20200514_134105.jpg?dl=0
Lastly.....do you know what type of handle bars are these?  Not stock as the wires are not through the handles....and not clip on' as I have learned.
https://www.dropbox.com/s/946asmvvi4ftf8h/20200514_134044.jpg?dl=0
Thanks
Online MauiK3
  • A K3 is saved
  • Old guy
« Reply #39 on: May 16, 2020, 09:22:10 AM »
Seems the link is top secret
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline mbryan
« Reply #40 on: May 16, 2020, 09:25:48 AM »
Can't seem to get this right.....try this...
https://www.dropbox.com/s/0gzzjh2h4o21cni/20200515_155451.jpg?dl=0
Offline flatlander
« Reply #41 on: May 16, 2020, 12:31:45 PM »
i am sorry to tell you but that is not the centre stand  ;)
no clue what that's meant to be. doesn't look like anything that belongs to a 550.
Offline Robbo
« Reply #42 on: May 16, 2020, 01:14:58 PM »
Do those channels align with the downtubes of the frame at the front of the motor?  Could be for a fairing with some sort of engine protector.  Looks homemade
1973 CB350 Four, 1975 CB550K
Offline mbryan
« Reply #43 on: May 16, 2020, 02:25:11 PM »
It does look homemade.
Dont know about yall......but this makes me smile :)
https://www.dropbox.com/s/7r2bz0pmt6ye37d/20200516_162100.jpg?dl=0
Offline Robbo
« Reply #44 on: May 16, 2020, 03:10:02 PM »
Nice to see the concentration
(Or did you mean that the angle of the screwdriver looked like the fuel gauge indicator for his t-shirt) LOL
Offline onepieceatatime
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline mbryan
« Reply #46 on: May 16, 2020, 06:38:18 PM »
Ok.....some progress!!!!
No leaks.....
https://www.dropbox.com/s/7kl2pgnwlfr72ic/20200516_173045.jpg?dl=0
All even at the sealing surface ........
https://www.dropbox.com/s/vrho350uspqdkk0/20200516_173933.jpg?dl=0
And the pay off......sounded rough and found we had 1 and 2 spark plug wires swapped....duh
https://www.dropbox.com/s/4i2ws4uephp2jmn/20200516_184145%20%281%29_1.mp4?dl=0
How about that smile!!!!
Only thing is it is back firing a bit when revved up .......dont know what that's about.....any ideas?
Thanks for all the help getting to this point!
« Reply #47 on: May 16, 2020, 07:37:30 PM »
The homemade device is a fairing mount for a Windjammer fairing I would bet. The angles and orientation look right and the mounting arm holes looked spaced correctly.
Probably could sell it on eBay or here if someone wanted to put a Hammer on a 77-78 cb550. Frames were different on 74-76 but don't know if the changes affected these mounts. I need one for my 74.
Offline flatlander
« Reply #48 on: May 16, 2020, 11:45:10 PM »
where's the fuel level in those carbs? in the pic where you hold up the tubes it looks high to me, but that might just be the angle that the picture was taken at.
congrats for firing it up - that is indeed priceless  :D
the idle sounds high. should be around 1200rpm.
Offline mbryan
« Reply #49 on: May 17, 2020, 05:27:23 AM »
All levels were sitting right at the flange of the bowls.  I did not touch the float adjustment when we cleaned them and this is where it settled to.
Yup that first start from was high and I lowered it to 1000 per the manual after getting the spark plug wires right and restarting.
So 1200 is the correct number?
