Author Topic: What's a decent substitute for rubber handgrip cement ?  (Read 2724 times)
Offline Trevor from Warragul
Re: What's a decent substitute for rubber handgrip cement ?
« Reply #25 on: June 20, 2021, 09:22:57 PM »
I had the same problem with my CBX.  The grips are a tad too loose.  My solution was to wind silver duct tape around the bars, just enough to take up the slack, then a smear of Araldite epoxy.  Rock solid now.
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #26 on: June 20, 2021, 10:43:00 PM »
looks like you can still buy em,i got these on the yammy and something similar on the honda,nice thin with diamond no waffle.
https://www.mxstore.com.au/p/Pro-Taper-Full-Diamond-Soft-Black-Grips/PT02-4845
« Last Edit: June 20, 2021, 10:45:11 PM by dave500 »
Offline Alan F.
« Reply #27 on: June 21, 2021, 05:30:47 AM »
I've looked for the Bar Snake for a long time now:have they entirely discontinued it??
I just googled it and came up with a lot of pages, the "secure order form looks like it ha a number to call and place an order with a real person. I also googled the phone number and it looks to be connected to the company.
http://www.barsnake.com/order/secure.html
« Reply #28 on: June 21, 2021, 06:49:45 AM »
These days I'm a little older and will probably go with a set of Itallian made GT grips, they're fatter and more comfortable.
I also like the GT grips, have them on my '66 X6 Hustler.  Great period looking grip...
Offline grcamna2
« Reply #29 on: June 21, 2021, 09:19:24 AM »
Stev-o,I like those original Italian grips quite a bit too.I wanted the originals,Made in Italy about 8 years ago and all I could get were some light blue ones:they didn't look 'cool' on a 350 I had but I sure love how they feel when you 'get a grip'  :D
75' CB400F/'bunch o' parts'
« Reply #30 on: June 21, 2021, 11:43:35 AM »
Nicknamed Titty Grips back in the day
Offline grcamna2
« Reply #31 on: June 21, 2021, 11:59:45 AM »
Especially a 'young/fresh pair' of them ! Lol
Offline Kelly E
  • Geriatric Hooligan
« Reply #32 on: July 28, 2021, 08:23:15 AM »
I've been using PB Blaster on the grips since I figured out that it gets sticky when it dries. I spray some into the grip and it slides on really easy. Once it dries they're stuck on good but I can still pull them off with a blast of air.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #33 on: July 28, 2021, 09:38:42 AM »
 I have the Randakk grips on my GL. To me they feel like the euro grips but are softer. solvents will dissolve them however so be careful what adhesive you use. https://www.randakks.com/randakk-s-gen-ii-amazing-grips.html
« Last Edit: July 28, 2021, 09:42:28 AM by Don R »
Offline grcamna2
« Reply #34 on: July 28, 2021, 10:00:46 AM »
Don,Do they hold tight to the bars;how do they feel when riding ?
« Reply #35 on: July 28, 2021, 10:52:51 AM »
 They are soft and stay on pretty well, they feel fat in the middle although don't appear that way and they're easy to keep ahold of without re-gripping a lot.   Before my hand surgery for trigger finger I cramped up really bad and these helped a lot with that. I use the cruise control latch less often these days.
   I used to run the chrome and foam grips because they came on the GL and were large OD but they fell apart and off often.
Offline grcamna2
« Reply #36 on: July 28, 2021, 01:40:30 PM »
You are right ! I just called and spoke with the owner Carter and he's up and running now.  ;)
Offline Alan F.
« Reply #37 on: July 31, 2021, 01:12:54 PM »
Sweet, I hope it helps a few of us out.
Offline grcamna2
« Reply #38 on: July 31, 2021, 01:27:32 PM »
The owner Carter tells me it'll keep me from getting that problem with nerve damage in my hands that happens when we ride with the vibration.
Offline goodtryer
« Reply #39 on: July 31, 2021, 04:22:28 PM »
Nobody using safety wire?
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #40 on: July 31, 2021, 05:31:42 PM »
Or hairspray
« Reply #41 on: September 23, 2021, 08:52:25 PM »
 I had the left one sliding around so I cleaned it inside and used brakeclean on the chrome then some old really sticky weatherstrip adhesive on both sides. It may be permanent now but I'm going to the drag strip and can't have it coming loose.
 Will report results later.
« Reply #42 on: September 24, 2021, 04:15:44 AM »
I agree with the ProGrips Stevo, last bike I put any regular & serious millage on I used ProGrips 719's
I have similar ones on the 900, like them a lot.
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #43 on: September 24, 2021, 05:37:15 AM »
I just took off those Italian GT grips and replaced them with the Progrip 714s. The GTs felt a little to fat to me with gloves on.
I use WD40. They slide right on, and seem to tack underneath and don’t move around at all.
« Last Edit: September 24, 2021, 06:55:49 AM by KennyRedman »
  • Gusto mo titi ko?
    • project
« Reply #44 on: September 24, 2021, 05:44:11 AM »
Hairspray
« Reply #45 on: September 24, 2021, 09:12:53 AM »
 Hairspray works if you have some.
Offline grcamna2
« Reply #46 on: September 24, 2021, 05:40:56 PM »
The OURY soft rubber grips give me some shock/vibration resistance,only thing seemed to hold them on is that designated Grip Cement.I would try something like weatherstrip cement:put the weatherstrip cement then install the grip right away before it has time to set-up.
« Reply #47 on: September 24, 2021, 06:41:58 PM »
 I did. It's old and I had to hurry. L0L
