Author Topic: CB350F (car full of stuff X2) build  (Read 4657 times)
Offline wolf550
Re: CB350F (car full of stuff X2) build
« Reply #50 on: November 05, 2022, 04:08:13 PM »
getting there
74' CB550 (Sold)
71' CB500/550 (Sold)
Offline grcamna2
« Reply #51 on: November 05, 2022, 05:09:38 PM »
the 400 carbs look bad but no real corrosion on the bodies but one of the metal bows that fit on the main jets was eaten through and there is just all the mac and cheese powder and well I don't know if this was a thing back in the day but the main jets have some stuff that looks to be wax around them like someone did a solder with wax? I dont know but if it worked then hey.
I imagine the tank had it's share of rust inside  :o
75' CB400F/'bunch o' parts'
Offline wolf550
« Reply #52 on: November 06, 2022, 09:04:04 AM »
ah you had to bring up the tank! yeah I gotta get a barrel of that evaporust ordered later to get on both of the tanks. luckily one of them is already black and the wife likes the black on it so it can stay but I gotta see how the inside is going to turn out. the other tank has a 70's custom faded paint job on it that I don't mind but the inside smelled like varnish and rust too. after this build i might get the other parts bike worked on and just keep it like that but that of course is in the we will see future.
74' CB550 (Sold)
« Reply #53 on: November 06, 2022, 09:41:45 AM »
Don't overlook using POR-15 on the tanks after the de-rust operation. It will 100% prevent it from happening again.
Offline wolf550
« Reply #54 on: November 06, 2022, 03:20:39 PM »
thanks Hondaman I don't want to have to do the tank thing again after these any time soon.
when I get there Ill definitely take pics of the before and after.
they did not look to have any holes as they both were still filled with fuel but im sure after cleaning them both up I will see.
74' CB550 (Sold)
Offline wolf550
« Reply #55 on: November 06, 2022, 03:24:36 PM »
more work on the carbs throttle bodies.
alot of gunk in the sleeves and in between the shaft and needle clip holder.
after spraying with the carb cleaner and let if all collect in a bucket I had to go back again and see what I missed.
going to buy more carb cleaner and do it again.
74' CB550 (Sold)
« Reply #56 on: November 06, 2022, 03:26:43 PM »
Using something like vinegar really invites pinholes as it eats all metal as well as rust...evaporust type products only chelate the rust which doesn't impact any good metal. Not that pinholes aren't possible. A liner on a tank with more than light rust is generally a good idea I think and agree with HondaMan, POR or Caswell's are the best liners I think. POR being very picky about prep...
You must be sure it is dried out extremely well, you do not want to capture water/moisture under a liner.
Offline wolf550
« Reply #57 on: November 06, 2022, 03:28:34 PM »
opened up all the throttle bodies checking each on to see which are the best.
both the titled and donor carbs had someone in them with the heads wore down.
glad I had my filed down phillips ready to go to town.
all the needles were oem. guess they couldnt get to them and set "im sure they are ok".
74' CB550 (Sold)
Offline wolf550
« Reply #58 on: November 06, 2022, 03:37:06 PM »
thanks RAFster122s it is always good getting the +1 with you, hondaman and the others on these type of things.
I had the fun of giving that vinegar bath a try when I was doing the 550 tanks. after pouring it out I made the baking soda potion after pouring all the vinegar out instead of having it ready made. when I went to pour it into the tank I saw all the flash rust and thought to myself holy hell did the vinegar even do anything!? only after reading the directions about it did it finally work. glad It came out okay cause Im sure I would have two holey tanks if I didn't double check that thread.
I will not be doing that again. definitely going the evaporust option and see how it turns out.
74' CB550 (Sold)
Offline wolf550
« Reply #59 on: November 06, 2022, 03:39:26 PM »
on those titled throttle bodies where either the PO or the mechanic who put all the gasket silicone on the engine popped them up with a bit or something stupid.
74' CB550 (Sold)
Offline wolf550
« Reply #60 on: November 12, 2022, 05:53:21 PM »
still waiting on some orings for carb jets but cleaning up all the parts that have the least amount of grime and that are not altered from ham fists.
74' CB550 (Sold)
Offline wolf550
« Reply #61 on: November 12, 2022, 05:55:08 PM »
again most of the parts are aftermarket. not sure where they are from so I will give them a try.
74' CB550 (Sold)
Offline wolf550
« Reply #62 on: November 12, 2022, 05:58:22 PM »
I got most of the gunk and grime off the bodies and rack without dissassemble all the way. it just kept coming off with each spray.
74' CB550 (Sold)
Offline grcamna2
« Reply #63 on: November 12, 2022, 08:44:25 PM »
better and Better  8)  ;)
Offline wolf550
« Reply #64 on: November 29, 2022, 06:10:24 PM »
hope everyone had a good thanksgiving.
always sucks going back to work when off for a week.
74' CB550 (Sold)
Offline wolf550
« Reply #65 on: November 29, 2022, 06:13:21 PM »
carbs are put back together.
one of the outer float bowl screw hole is stripped so going to do the size bigger and tap it.
74' CB550 (Sold)
Offline wolf550
« Reply #66 on: November 29, 2022, 06:15:15 PM »
got these bench syncd and ready to go to see where they are.
will get these put on and moving on.
74' CB550 (Sold)
Offline wolf550
« Reply #67 on: November 29, 2022, 06:19:22 PM »
I was checking about that 400f clutch cover.
going to take it out of storage so I can fab up a clutch adjust cover for it (finned of course) and slap it on.
I guess the next up is the electrical.
74' CB550 (Sold)
Offline grcamna2
« Reply #68 on: November 29, 2022, 07:18:37 PM »
How many 'road ready' racks of carbs will you be able to build from those others?
Looking good  :)
Offline wolf550
« Reply #69 on: November 30, 2022, 12:40:26 PM »
the other two sets should be rebuildable.
I figure as I finish the 350 up I will go through both sets, try and learn the ultrasonic clean process for them
replace bits and pieces that are old from used stuff on ebay
74' CB550 (Sold)
Offline wolf550
« Reply #70 on: December 02, 2022, 04:00:14 PM »
put a couple of goodies on the 350. they look awesome.
74' CB550 (Sold)
Offline wolf550
« Reply #71 on: December 02, 2022, 04:01:53 PM »
had these on Ebay but didnt sell.
74' CB550 (Sold)
Offline wolf550
« Reply #72 on: December 02, 2022, 04:04:43 PM »
they are on their new home.
74' CB550 (Sold)
Offline Shtonecb500
    • Youtube profile
« Reply #73 on: December 02, 2022, 04:18:23 PM »
the covers look good, wolf.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline grcamna2
« Reply #74 on: December 02, 2022, 05:04:21 PM »
wolf,the 4 covers in your avatar picture:the one on the top/right looks like it has blood stains on it ?
