Author Topic: m.Unit Wiring Diagram  (Read 15416 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: December 27, 2022, 01:42:50 PM »
Anyone have an m.Unit Wiring Diagram for my bike? It's a 1977 Honda CB750 K.
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline Ellz10
  • ZZ
Re: m.Unit Wiring Diagram
« Reply #1 on: December 28, 2022, 08:10:10 AM »
There isn’t a specific diagram for a bike. The wiring is based upon your accessories, gauges, indicators, switch gear etc.
List your gauges, what indicators you have, brake light, left and right controls. I’m sure I have something close in my library.
Lithium ion rec/reg, bates style LED taillight, m.blaze disc turn signals (L&R), motogadget m.lock, motogadget m.stop, 12-volt horn, mo.switch 3 button switches (L&R), 6.5" LED Projector headlight, Daytona Velona speedometer, Daytona velona Tachometer. think that's about it.
Offline CB750R
  • 77 CB750F
« Reply #2 on: December 28, 2022, 11:21:38 AM »
Offline Ellz10
  • ZZ
« Reply #3 on: December 28, 2022, 10:39:14 PM »
did you see this post?
http://forums.sohc4.net/index.php/topic,190806.0.html
I saw that but I don't have the m.Button or an key ignition switch, nor do I have rear turn signals. I also am using points, not an electronic ignition
I'm also curious as to what I need to buy to make my front brake blend with this m.Unit system - My front brake combo is the Brembo 19RCS Corsa Corta. How do I go about tying that into the electrics?
Offline CB750R
  • 77 CB750F
« Reply #4 on: December 29, 2022, 05:09:45 AM »
Buy the brembo brake light switch and wire it in as shown, that’s a good start, the rest your going to have to do your homework, odd wanting to fully rebuild a wiring system and retain points. You’re going to have to find out if that’s possible.
Offline Ellz10
  • ZZ
« Reply #5 on: December 29, 2022, 08:16:50 AM »
It's not one bit odd and I already know it's possible. Why waste money on electronic when I can have the reliability and longevity, not to mention save money, with points. I've also got Mark's transistorized ignition to wire in.
« Last Edit: December 29, 2022, 09:29:42 AM by Ellz10 »
Offline Ellz10
  • ZZ
« Reply #6 on: December 29, 2022, 08:20:12 AM »
I'll just take the diagram from that Rhona guys post and delete all the stuff on it that I don't have nor need (i.e the m.Button, rear turn signals, ect) and I'll see how that goes. Thought I'd get a bit more help from people in this section of the forum lol - I guess trying to learn has become more difficult.
I admit I'm not very adept in the electrical aspect of anything really, which is why I'm here asking for help from the fellas that are skilled and knowledgeable and have done these things.
« Last Edit: December 29, 2022, 08:30:31 AM by Ellz10 »
Offline CB750R
  • 77 CB750F
« Reply #7 on: December 29, 2022, 05:28:01 PM »
Sorry man, I didn’t see the point of going to a new wiring harness and control unit without modernizing your ignition, I see you have modernized it to some degree.  Have you at modernized your reg/rectifier? From the little I know of the M-units they like a specific range of voltage, it would suck to fry one due to the old regulators.
I’ve installed a couple brembo RCS M/C-s  on other more modern bikes, the brake switch is pretty basic so when you ask questions of that level I kinda assumed that was the level of technical electrical knowledge. Unless you happen to find someone with the exact same list of modifications you have, the best your going to get is someone else’s wiring diagram, unless someone is willing to make one for you.
Offline CB750R
  • 77 CB750F
« Reply #8 on: December 29, 2022, 07:40:57 PM »
You are mistaken, the mUnit does not have a condition dependent upon the Reg/Rec. It’s looking for 12v plain and simple. A lithium battery does however have a preference for modern charging components as they have very different charging curves than lead acid batteries.
Ok good to know, I must’ve taken that lithium info out of context.
Offline Ellz10
  • ZZ
« Reply #9 on: January 26, 2023, 08:56:23 PM »
Any particular way I should set my tray up that would be more beneficial/easier, before I drill the holes and weld the bolts?
This is what I came up with. I obviously don't have the mo.stop in there, but it's tiny enough not to make a difference in space.
Offline Ellz10
  • ZZ
« Reply #10 on: January 27, 2023, 07:53:27 AM »
Provide as much airflow around the Reg/Rec as possible. Perhaps even make some drilled holes below it with a 1/8” drill to create a “screen” for more air.
That's a good idea, I'll do that tonight, thank you!
Offline Ellz10
  • ZZ
« Reply #11 on: March 01, 2023, 09:52:45 AM »
So I went ahead and borrowed Revival Cycles diagram (credit to them) because it's quite close to what I have going.
Obviously I edited it to suit my bike.
You can see I left the "Key Switch" emblem on there with its accompanying red and brown wires. I, however, am going keyless, with the m.Lock which has red, brown, and black.
Perhaps a dumb question (or rather common sense), but are the red and brown wires from the m.Lock going to where the red and brown wires would go with the "Key Switch"? And then the black wire on the m.Lock gets grounded?
« Last Edit: March 01, 2023, 09:54:24 AM by Ellz10 »
Offline Ellz10
  • ZZ
« Reply #12 on: March 01, 2023, 06:08:38 PM »
From recall, Red is power, Brown to mUnit LOCk, Black to ground.
That's what I figured, thank you.
Next question - I'm testing out the m.unit to make sure it operates and functions correctly and for some reason AUX 2 light goes on and stays on. I've tried troubleshooting and there's no mention of it. Any ideas?
Offline Ellz10
  • ZZ
« Reply #13 on: March 02, 2023, 09:50:59 AM »
It’s merely indicating that power is available on that port as an output source.
So the AUX 2 light will always be lit up when the m.Unit is in operation because there's available power at that port?
The video I watched showed the gentleman doing the same process, setup and all, and his AUX 2 wasn't lit up, that's why I thought to ask.
« Last Edit: March 02, 2023, 11:54:49 AM by Ellz10 »
Offline Ellz10
  • ZZ
« Reply #14 on: March 02, 2023, 01:42:59 PM »
It may be in the software setup that either you or he doesn’t have AUX2 similarly.
Oh I didn't think about that. I'll be sure to update to the newest software once I get it synced to Bluetooth.
Next question - in the wiring diagram their starter solenoid shows the 2 main wires going to battery and starter - then 4 individual wires going to START, BAT, REG/REC, and GROUND.
My starter solenoid only has 2 wires, instead of 4. Obviously my green/red goes to START, but where does my red/yellow go to, to BAT or GROUND?
« Last Edit: March 02, 2023, 04:48:56 PM by Ellz10 »
Offline Ellz10
  • ZZ
« Reply #15 on: March 02, 2023, 02:22:07 PM »
Semi-unrelated question for you Cal - if I get my electrics tray powdercoated, will the powdercoat interfere with the grounding of the m.unit on the tray or no?
« Reply #16 on: March 02, 2023, 02:59:11 PM »
If you are powder coating a tray or part that bolt's to another part, bare metal contact is needed between the bolt on part and the frame...if that isn't achieved then you need to sand or scrape it it bare metal to make contact with the object you are screwing into and battery or frame ground. Battery and frame ground points have to be at the same level or problems can develop.
Case in point, if the headlight bucket ground isn't maintained then the bike often will use the steering neck bearings as an electrical path which can lead to scorch marks spots on the bearings.
« Last Edit: March 02, 2023, 03:01:32 PM by RAFster122s »
Offline Ellz10
  • ZZ
« Reply #17 on: March 02, 2023, 03:11:31 PM »
Okay so when I weld the threaded part of 2 bolts to my electrics tray and tape off the threads so they don't get powdercoated I should be fine, because both sides are getting clamped down with a bolt screwing into the frame?
Forgive my quick awful drawing.
« Reply #18 on: March 02, 2023, 03:29:16 PM »
If your bolt is making contact to the metal of the frame, then yes, otherwise it could be weak ground or not grounding to the frame if the holes through the frame are powder coated...they (those holes) insulate the tray from the frame then...
Offline Ellz10
  • ZZ
« Reply #19 on: March 02, 2023, 03:33:49 PM »
Okay perfect! I appreciate the info very much!
Offline Ellz10
  • ZZ
« Reply #20 on: March 02, 2023, 08:40:50 PM »
Your welded threads donut’s connect via bare metal to the frame. Sure, the threads are viable connections for a ground from the mUnit, but the tray needs to have other bre metal holes that bolts connect to the frame (where the frame itself is bare metal).
Red/Yellow is the wire from the START button to the mUnit, then from the mUnit to the solenoid. The Green/Red is the stock Starter Safety Switch preventing the bike from starting vi electric start unless the clutch is pulled. Just run the Gr/Red to. Ground if you are not using a SSM but be damn sure you don’t forget to be in NEU or pull the clutch when hitting the starter button (and anyone who might ride your bike!).
So I'm running my wiring based off the color code in the m.unit handbook, it just seemed easier that way since I had purchased their wire bundle kit. So my "red/yellow" is going to be blue going from the START button to Input 'START', I'll just have to make a note of that, then red/yellow to Output 'START' from the starter solenoid I'll just keep the same since it's not a far reach.
Not using a SSM, so I'll be careful. Just out of curiosity, what would happen it'll attempted to start the bike outside of NEU/not having clutch pulled in?
Offline Ellz10
  • ZZ
« Reply #21 on: March 03, 2023, 07:35:43 AM »
It will lurch forward and likely topple over upon you, or hit whatever is directly in front of it. Give it a try if you’d like to start over on some of your rebuild tasks  :o
LOL, no thank you  ;D
Offline Ellz10
  • ZZ
« Reply #22 on: March 03, 2023, 06:04:59 PM »
Back to the diagram.
My Rick's REG/REC has 8 wires just like it should. In the bundle that goes to the STATOR, the colors on my REG/REC are: 3 yellow, 1 red, and 1 green. The remaining 3 loose wires are white, green, and black with a white stripe.
In the diagram I've adopted and edited to suit my needs, their's shows: 3 yellow, 3 black, 1 red, and 1 white. The color of the wires in the bundle that they have going to the STATOR are: 3 yellow, 1 white, and 1 black. The remaining 3 loose wires are 2 black and 1 red.
Obviously the colors for the wires that are in the bundle that go to the STATOR on the diagram don't matter because my REG/REC and STATOR wire colors match up when I look at the bike.
****Edit**** So after looking again I was wrong, the colors do not match up from my REG/REC to the STATOR end. STATOR shows 7 receiving wires: 3 yellow, 1 white, 1 green, 1 blue with red stripe and 1 very light green with red stripe. 3 yellows and 1 green will go together on each end, and white to white, but after that I'm not sure which wire colors go together since they're different. No diagram sheet came with the Rick's box either so no help there. I'm going to dig more into it and read the wiring schematic from the book and see if I can figure it out before I get help here.
My question is, of my 3 remaining loose wires on my REG/REC, which color goes to GND, and where do the remaining 2 colored wires go?
« Last Edit: March 03, 2023, 08:03:34 PM by Ellz10 »
Offline dusterdude
« Reply #23 on: March 04, 2023, 02:43:44 AM »
Dont take this to the bank but,honda generally used green for grounds.if that helps.
Sent from my SM-G973U1 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #24 on: March 04, 2023, 02:50:22 AM »
Green is ground in house wiring and is often the case in other industries and applications....
Did the regulator not come with instructions? Does Rick's have a website with info?
Image a search on Google with site:https://forums.sohc4.net will give you instances of Rick's regulators being mentioned... Then you'd have to sift through the posts to find the info.
