Author Topic: Cool Tools.  (Read 66100 times)
Re: Cool Tools.
« Reply #25 on: February 05, 2023, 07:11:53 PM »
Rebuilding tilting steering column was one of the hardest jobs I ever did.  This tool made it possible.  As far as I remember it presses hinge pins out.
My buddy that had a shop used a slide hammer dent puller except with a machine screw in it. I helped him make it when I needed the loose screws in my tilt column tightened up.
Offline Tim2005
Re: Cool Tools.
« Reply #26 on: February 06, 2023, 03:27:54 AM »
My kids bought me one at COSTCO a few years ago. Circular LED lamp with a large magnifier in the middle. It’s on a 24” + 24” articulated arm and clamps to one end of my bench. I’ll take a picture, next shop day. Fantastic device, I use it constantly. Even when not using it, I keep the top cover closed, but turn on the light for extra brightness!
Is it similar to this one that I had spotted, except for the clamp base? Looks pretty good to me. I had also wondered about the type that you wear, as per the second link below. It's tricky to know which type would be best to use
https://www.ebay.co.uk/itm/224564286351
https://www.ebay.co.uk/itm/364077185409
Offline newday777
Re: Cool Tools.
« Reply #27 on: February 06, 2023, 03:42:58 AM »
Does anyone use any kind of magnifier? Ageing eyes and shrinking electrical & carb parts seem to make one more useful than ever nowadays. I do have a big Sherlock Holmes style one, and a little jewellers one, but often think something hands free would be better, one that's either on a stand or wearable. Has anyone found any good types?
I used to have an old round florescent lamp/magnifier like you described that my dad had on his fly tying table, one that took 20-30 seconds holding the button to start the lamp......but the bulb finally died and in a move, it got tossed.
Now, my eyes are dimmer than in my younger days and could benefit from a lit magnifier these days..... I guess I'll have to keep a watch out for another
Stu
My current rides
Prior bikes....
Re: Cool Tools.
« Reply #28 on: February 06, 2023, 05:56:18 AM »
Check goodwill and thrift stores for the magnifier lamps…sometimes they show up there.
Harbor freight used to carry them if you want to give them money…
Offline BenelliSEI
  • 1969 cb750
Re: Cool Tools.
« Reply #29 on: February 06, 2023, 10:05:16 AM »
Here’s the one I have. Clamps to the bench and has a flip down cover to protect the lens. The bulb is actually two rows of small LED lights, circling around the lens. VERY USEFUL.
Offline Tim2005
Re: Cool Tools.
« Reply #30 on: February 06, 2023, 02:34:36 PM »
Yes that looks really good, I like the clamp-on idea too,  can then use it clamped under the car bonnet etc too. I'll go hunt amazon & ebay for deals now. Cheers
Offline BenelliSEI
  • 1969 cb750
Re: Cool Tools.
« Reply #31 on: February 06, 2023, 08:34:14 PM »
You won’t be disappointed. Today that rig helped me find the markings on a set of piston rings that seemed to have “disappeared”!
« Last Edit: February 07, 2023, 06:07:30 PM by BenelliSEI »
Offline CycleRanger
  • No comment about being an
Re: Cool Tools.
« Reply #32 on: February 07, 2023, 07:49:11 AM »
I need one of these badly. I've looked up various models, I just need to pull the trigger.
Offline BenelliSEI
  • 1969 cb750
Re: Cool Tools.
« Reply #33 on: February 08, 2023, 01:08:21 PM »
Today I used this MAC tool kit my son gave me. One of my wife’s broken appliances (melted wire where it joined a spade connector) was held together with Philips screws that have only THREE slots..... WTF is that all about? Looked through the box and there’s was a full set X four sizes of these weird bits!
Very handy set.
« Last Edit: February 10, 2023, 07:20:09 AM by BenelliSEI »
Re: Cool Tools.
« Reply #34 on: February 08, 2023, 01:30:43 PM »
Are those called Tri-wing, they are a security bit, designed for tamper resistance. Or job security until Harbor Freight and all the other tool places started carrying the security bits..
Before only the repairman would have those bits.
Re: Cool Tools.
« Reply #35 on: February 09, 2023, 01:21:29 AM »
Today I used this MAC tool kit my son gave me. One of my wife’s broken appliances (melted wire where, it joined a spade connector) was held together with Philips screws than have only THREE slots..... WTF is that all about? Looked through the box and there’s was a full set X four sizes of these weird bits!
Very handy set.
I have a set of torx bits with a hole in the middle.  I had to buy them for some work on Volvo.  Torx heads should not exist, imho, this was just another level of beef I have with them.   ;D
Re: Cool Tools
« Reply #36 on: February 09, 2023, 01:33:13 AM »
In December I spent the money and added japanese waterstone to my Tormek.  Quite amazing.  It polishes the edge of a knife/chisel/plane blade to scratchless mirror. It sharpens to level I was never able to achieve by hand - yes, I am lazy  ;D.  I also use it to restore straight razors.
Re: Cool Tools.
« Reply #37 on: February 10, 2023, 09:55:39 PM »
i have a big glass hand held magnifying glass in the tools,bloody handy once ya get a bit older,see jets numbers or score marks etc,i also have a set of weirdo bits that fit weirdo screws that weirdos dont want you to undo,i got it free when i bought a decent multimeter years ago,been handy!also a few custom made bent/buggered and modified tools to suit certain things,im sure you can buy the real ones but wheres the fun in that?that little bent 6 side ring lets you bleed rear drums on Holdens with wide wheels without taking the wheels off,this bent 9/16 ring with the 1/2 drive socket head unlocks the dissy holding bolt on V8 Holdens with the dissy right hard against the fire wall like chevys have,these 1/2 drive sockets cut into fingers undo the clutches on a few chainsaws,too easy.
« Last Edit: February 10, 2023, 10:06:22 PM by dave500 »
Re: Cool Tools.
« Reply #38 on: February 10, 2023, 11:13:47 PM »
Dave, those pins on the end of the modified sockets. Similar ones work to undo clutch pack nuts on some Honda bikes.
Re: Cool Tools.
« Reply #39 on: February 10, 2023, 11:29:32 PM »
Yeah,i used to have the genuine honda tool for the xr75 oil spinner you had to remove to swap out the clutch,dont know what happened to it?it was a four fingered deep recess thing with a fixed tee bar,i still have a genuine honda fly wheel ignition puller with a left hand main thread thats also fitted yammys.
Offline BenelliSEI
  • 1969 cb750
Re: Cool Tools.
« Reply #40 on: February 11, 2023, 05:44:31 AM »
Dave.... I need that bleeder for the back of my FORD F350.Will make one before I crawl under there again!
Offline BenelliSEI
  • 1969 cb750
Re: Cool Tools.
« Reply #41 on: February 26, 2023, 09:35:38 AM »
My son spotted this at a garage sale in Toronto. No other parts, but he thought it looked familiar! Great way to drag a SOHC cb750 engine around the shop?? Sad end to a frame...... Hopefully it wasn’t a Sandcast!
« Last Edit: February 27, 2023, 11:53:49 AM by BenelliSEI »
Re: Cool Tools.
« Reply #42 on: March 12, 2023, 10:28:57 AM »
Picked for $10 at local Habitat for Humanity. I already own 3 planers, just couldn't leave them behind.
Re: Cool Tools.
« Reply #43 on: March 12, 2023, 02:51:18 PM »
 I have two of those, one attached to my engine stand and one attached to a small HF furniture dolly. Rusty, split and no title = engine holders.
Offline C317414
Re: Cool Tools.
« Reply #44 on: April 17, 2023, 02:39:09 PM »
I got tired of cheap oil drain pans, so I did a bit of research, a found this one from Matrix Concepts.  It's made from strong plastic, it holds enough for one or two oil changes, and it fits underneath most bikes.  Moreover, it's US made.
Re: Cool Tools.
« Reply #45 on: April 17, 2023, 02:54:14 PM »
I like that!
I bought me a bead roller - to finally put a fender on the sidecar.  Love that thing but I am afraid I will be now looking for projects to use it on.
Offline Kelly E
  • Geriatric Hooligan
Re: Cool Tools.
« Reply #46 on: April 21, 2023, 09:10:18 PM »
I've been using the same Blitz 15qt oil drain pan for the last 20 years. Luckily the cap is the same thread as the caps on Rotella T4 oil jugs so I can replace the cap when it starts to leak.
At the moment my favorite cool tool is our 1/4" cordless DeWalt Impact driver. I've removed a bunch of stuck case cover screws with it that would have been an issue without it.  8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline C317414
Re: Cool Tools.
« Reply #47 on: April 23, 2023, 11:41:09 AM »
Here are two tools that I rarely use, but they are invaluable when I need them:
The first one is an exhaust spring puller that came in the OEM toolkit of my 85 Husky 510.  The bike is long gone, but I continue to use the tool. The wire is made from heat-treated high strength steel, and won't bend under load.   I use it on exhaust spigot springs, as well as side and center stand springs.
The second is a ratcheting, right angle screwdriver. I've used it a number of times to loosen screws without having to completely disassemble the interfering assembly.
Offline BenelliSEI
  • 1969 cb750
Re: Cool Tools.
« Reply #48 on: April 23, 2023, 04:19:45 PM »
Today I used a new tool, for the first time. Found it in some junk I bought ages ago. It’s a thin, wire cable (looped end, rubber covered) that screws into an inner tube valve stem, when the valve is removed. You feed it through the rim hole first, then into the valve body. Pulling the valve through is a snap.
WHY DID I NOT BUY ONE OF THESE 50 YEARS AGO!
Offline newday777
Re: Cool Tools.
« Reply #49 on: April 23, 2023, 07:51:50 PM »
I remember those.
Stu
My current rides
Prior bikes....
