Author Topic: Started on the 1978 HONDA CB750F restoratin project  (Read 22041 times)
Offline Honda Hansel
  • Sherwood Park AB
« on: October 16, 2023, 05:08:00 PM »
Hi all members
So I got started on the 1978 HONDA CB750F and there is a lot to do
pulled the bike apart and send every thing out for powder coat
waiting on some more parts to come back from powder coat as I figured out that painting is not what in going to waist my time on
Also send a bucket of bolt's and nut's out for coating. Got a bit fancy this time
plating all the bolts makes a huge difference on the out come of the restoration
I'm going to post the results as I progress with the project
Here is a couple pictures
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
#8 1978 Honda CB550K
#9 1968 Kawasaki A1SS 250 cc Two stroke smoker
Re: Started on the 1978 HONDA CB750F restoratin project
« Reply #1 on: October 16, 2023, 06:01:04 PM »
You have your hands full  ;)  It'll come out nice.
  • Sherwood Park AB
« Reply #2 on: November 05, 2023, 03:46:09 PM »
Hi
Just picked up a parts bike
Tank is clean and no rust at all inside
Got the missing gauges and other parts I need
Wheels are in beautiful shape and they are not marked up as bad as the set that came om the 1977 bike
Its a runner (need carbs done) no idel on cylinder  #2 spray with carb cleaner and it comes on board
Bike sat for 12 years and all the oil had drained in to the engine (need oil pump rebuild stopper not sealing)
I did prime the engine before I tried to turn it over and changed oil filter. Checked for junk in filter and it's clean
Hooked up my oil accumulator (best thing I have bought ) and primed the oil and filled the filter
Can hear the air being pushed out of the oil galleys and up to the top end
Good thing to do before startup
here is a couple pictures of my priming oil accumulator and the heap of junk I bought
Honda Hansel
Honda Hansel
Offline newday777
« Reply #3 on: November 05, 2023, 04:36:28 PM »
I like idea of the use of the oil accumulator to prime the system before startup.
Stu
My current rides
Prior bikes....
Offline majorzozo
« Reply #4 on: November 06, 2023, 04:15:22 AM »
Hey Hansel,
Looks like a great start.  Especially having all the parts and nuts and bolts ready to go.  I did mine as I went and it has taken a long time.  Please post more pictures as you progress and good luck.
  • Sherwood Park AB
« Reply #5 on: November 12, 2023, 08:08:36 AM »
Time for a update on the CB750F
Got the tank liner installed POR15 Kit
Took me 6 hours to do and looks good
Cleaned the rear brake reservoir. so faded from the sun and looking bad
1# glass blasted it very lite low pressure just to remove the sun faded plastic
2# Clear coated and sanded and looks good. Used the RUST-OLEUM for use on plastic
Seat is done with new cover and repaired and painted seat pan
Got some more stuff mounted on the frame
side covers are on order from FB-STUFF store They look good on the pictures
Paint is booked for November 20 th and that is going to cost a fortune
Hansel
Honda Hansel
  • Sherwood Park AB
« Reply #6 on: November 26, 2023, 09:04:59 AM »
Time for a update
The front forks are installed and fender. Need to clean front rim and replace the tire
Head light bucket and all wiring is done
Handel bars are installed and all handle bar switches and new OEM Honda mirrors (made in Japan by HM )$$$$
Have a look at the head light mounting ears
They are powder coated in SUPER chrome .The chrome was in bad shape and the cost to have re chromed here in Canada
is very expensive. I do have a new NOS RH side looking for a LH side NOS will find one I hope
Just received the new side covers from FB-STUFF store on Friday.They look good and fitment is nice
Thanks FB-stuff for making a good Quality re-production cover
Tank and covers and tail in going for paint tomorrow after work
and the painter will install the tank stripe and clear over the stripe
hoping the to have the bike ready to go in to the bike show in January. CVMG/NORAL is having a display in the show ??
Might have to be on display as a project bike. Less engine if i cant get it done
Honda Hansel
Honda Hansel
Offline newday777
« Reply #7 on: November 26, 2023, 09:42:53 AM »
That's good progress.
The super chrome looks good from the distance in the picture. How about some closeups?
Stu
My current rides
Prior bikes....
  • Sherwood Park AB
« Reply #8 on: November 26, 2023, 01:30:07 PM »
Here is a couple closeup pictures
Of the super chrome powder-coat with lots of clear on top
Honda Hansel
Honda Hansel
Offline newday777
« Reply #9 on: November 26, 2023, 01:35:37 PM »
Honda Hansel
Is the clear also powder coat?
Not bad BTW.
Stu
My current rides
Prior bikes....
  • Sherwood Park AB
« Reply #10 on: November 26, 2023, 02:05:25 PM »
All don in powder coat and the clear as well
looks good on the bike
This might be the way to go in the future if chrome is out of reach in the price range
Its very expensive here in Canada
The only place we can have it chromed is Calgary Alberta and the cost is sky high
Honda Hansel
Honda Hansel
Offline newday777
« Reply #11 on: November 26, 2023, 03:32:48 PM »
I might have a friend shoot a couple of K model bracket ears and maybe a fender as a rest run(all are pitted) to see how they look this winter.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #12 on: November 26, 2023, 03:36:31 PM »
Honda Hansel
How did you prep or have the old chrome prepped before applying the powder coat?
Stu
My current rides
Prior bikes....
  • Sherwood Park AB
« Reply #13 on: November 26, 2023, 05:41:25 PM »
OK
The metal has to be clean and the pitting has to be minimal due to the popping of the powder coat
The shop did them 6 times as a test project
The pitting keep popping the powder coat as it boils  when they put it in the oven to bake
What the did to prevent it
They filled the rust pitting with HI temp BJ epoxy  weld and sanded it down
Other thing to do is to fill with low temp Brazing material so the powder coat don't pop when heated /baked at 400 deg
That is some thing I will try next time
Just a shout out to IMPACT COATING in Edmonton Alberta Canada
They did a nice job on all my parts
Honda Hansel
Honda Hansel
Offline kap384@telus.net
« Reply #14 on: November 28, 2023, 08:52:31 AM »
Looking great!  Always awesome to see another 'F'.  And in Alberta!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline BenelliSEI
  • 1969 cb750
« Reply #15 on: November 28, 2023, 03:52:04 PM »
Honda Hansel
I sure like that result in those fork ears. I’ve seen some samples of that “chrome” powder coat (+clear coat) locally and thinking my Rickman CR frame is going that route. Chrome is crazy expensive in Ontario too and I can’t even find any one I could trust to bright nickel plate my frame. That finish is so close, it might just have to do!
Offline BenelliSEI
  • 1969 cb750
« Reply #16 on: November 28, 2023, 03:52:49 PM »
P.S. nice work, project looks great!
Offline newday777
« Reply #17 on: November 28, 2023, 04:10:49 PM »
Honda Hansel
John
I don't know if the Rickman frame is welded or brazed. If brazed, you won't like the result of powdercating as the heat will melt the brazing and you will be left with a pile of loose tubing. Someone tried to do it on a Seeley frame.
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #18 on: November 28, 2023, 06:30:19 PM »
Honda Hansel
John
I’ll have to check that out! I didn’t think powder coating required that much heat!
Offline newday777
« Reply #19 on: November 28, 2023, 06:38:27 PM »
Somewhere about 400°F
Stu
My current rides
Prior bikes....
  • Sherwood Park AB
« Reply #20 on: November 29, 2023, 12:31:50 PM »
Hi
Powder coat is 400Deg F
brazing is 900-1200 deg F
The fork ears are looking a lot better with the head light and the gauges installed
looking from s distance it's a bit darker Sill look good
I'm looking for Engine paint to match the Honda Engine paint
any body know what to use
my plan is to pull Head and cylinder off the engine and re ring and do a valve grind.Then repaint head and cylinder
can't find the right black that has the right color black
If there is some one that has any suggestion pleas let me know
Thanks
Honda Hansel
Honda Hansel
Offline nvr2old
« Reply #21 on: November 29, 2023, 05:19:52 PM »
DupliColor makes a really nice semi-gloss black engine enamel in a spray can.  Any O'Rielly's, Auto Zone or the like will have it.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline BenelliSEI
  • 1969 cb750
« Reply #22 on: November 29, 2023, 06:22:18 PM »
Hi
Thanks
Honda Hansel
That’s what Ithought on the temps. +1 on the Dupli-color semi gloss. Very close match.
Offline newday777
« Reply #23 on: November 30, 2023, 04:20:08 AM »
Honda Hansel
John
My bad rememberer.....
It wasn't powder coating causing the bronze to melt, it was galvanic process to remove the nickle finish that had failed in this post on a Seeley frame.....
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #24 on: November 30, 2023, 06:57:58 AM »
Nice project!
1973 CB 750 K3
10/72 build Z1 Kawasaki
