Author Topic: What's the length of this part?  (Read 756 times)
Offline Deltarider
  • I'm back
« on: July 24, 2024, 04:18:56 AM »
Question in the German forum: what is the length of this collar used on the CB550Fs?  https://www.cmsnl.com/products/collarrrwheel_42311390000/
CB500K2-ED Excel black
Offline pekingduck
Re: What's the length of this part?
« Reply #1 on: July 24, 2024, 10:11:26 AM »
The 42311-390-000 spacer is outside of the actual wheel assembly.  It is pressed between the left wheel bearing and the swingarm/chain adjuster, going through the sprocket carrier and seal. No idea why it only fits the '75-77 550F Supersport models, except their swingarms are also unique to this model.
I would get my hands on one from a CB500/CB550 K model (42311-323-040) to try - same ID and OD, and likely very close if not the same in length.
Just came across this that may offer more insight:
http://forums.sohc4.net/index.php/topic,148877.0.html
« Last Edit: July 24, 2024, 10:31:13 AM by pekingduck »
Offline Deltarider
  • I'm back
« Reply #2 on: July 24, 2024, 12:16:44 PM »
Thank you both. Domp in the UK site came closest: http://www.sohc.co.uk/index.php?topic=31309.msg301923#msg301923
Have forwarded the info on both collars to the gentleman in the German forum.
Offline pekingduck
« Reply #3 on: July 24, 2024, 02:40:50 PM »
Can you post the info here just to have it?
Offline Deltarider
  • I'm back
« Reply #4 on: July 25, 2024, 12:18:35 AM »
Sure.
courtesy: DomP
« Last Edit: July 25, 2024, 12:20:55 AM by Deltarider »
Offline pekingduck
« Reply #5 on: July 25, 2024, 08:51:23 AM »
Thanks. How does that compare to the regular 500/550 part?
